Hybrid battery
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by David Sabin, Jul 31, 2022.
  1. David Sabin
    David Sabin New Member
    Union
    In the last couple of days my hybrid battery says it's fully charged but when I start pulling forward the vehicle starts to shutter and shows an empty battery trying to figure out if it is a battery of replacement or is it a inverter replacement thanks in advance for any help
  2. PriusCamper
    PriusCamper Senior Member
    11,056
    4,500
    Pacific Northwest, USA
    Hi David, Does the car drive normally after that? Or unable to drive? Do you have any warning lights on the dash? The warning light will have an error code that we need in order to diagnose.
    Wondering if this is related to our regional heatwave because it says you're in Union? Is that Union, Washington? Anyways, lots of air conditioners use can push the limits of an older battery pack and if you don't have warning lights yet if's something that can be addressed without having to spend too much money.
    As for the shutter you sure that's not the engine?
  3. David Sabin
    Union
    When it happened I had a full Christmas tree on my dashboard and it's saying it went into limp mode. As for Union yes it is Washington and my brother was running the ACThe whole time he was driving my car. I have contacted Toyota about a new battery. And the drivability of the car Shut off the car then it drove somewhat normal just lack of power.
    49,380
    could be the inverter pump, check the reservoir for movement with the car ready and engine off.
    how many miles on her?
    best to get it to the dealer for error code reading and post them here
  5. PriusCamper
    11,056
    4,500
    Well, I'm in the city 40mins south if you ever need help... Get yourself an OBD2 device to keep in your glove box. Something like this: https://www.ebay.com/itm/265484403768 You can then use Dr. Prius app and other apps to take screenshots of error codes and clear them so your car won't go into limp mode while you're driving. Can also provide you a loaner pack while your pack is rebuilt, or help you install OEM pack when it's no longer on backorder. It's a 2 hour job / $100 if I install it. But if a Toyota Stealership installs it'll be a huge rip off. Better yet, if we can keep your Prius going till November, you can upgrade to way better, way higher performance pack from https://projectlithium.com that will boost your MPG.
