Hybrid Cell Voltage
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Ralvals, Jun 4, 2017.
  1. Ralvals
    Ralvals Junior Member
    Vladivostok
    Hello everyone!
    I have a problem with my Prius 2012 plug-in. Yesterday after 1-2 miles my car stopped and showed a yellow triangle.
    The transmission of the vehicle can not move to "N" from "P".
    The error codes that the scanner P1A00 P1A61 P1A64 P1A67 P301A P31AB showed
    Hybrid Battery Cell Low Voltage Stack "B"
    Hybrid Battery Cell Low Voltage Stack "C"
    Hybrid Battery Cell Low Voltage Stack "D"
    The voltage on all cells of the battery is the same 3.73v.
    Also checked the fuse 150a
    Please need help! Errors are not reset and the machine does not start !!
    Paul Root likes this.
  2. mrbigh
    3,686
    699
    Long Island, NY
    How many miles on it?
  3. IMkenNY
    IMkenNY Im just being nosy
    477
    303
    Tropical Buffalo NY
    Four Touring
    Try a reboot by disconnecting the 12v battery and reconnecting. I would measure the 12v while your back there.
  4. Ralvals
    Vladivostok
    Did it. No result
  5. bisco
    49,492
    welcome!
    where is V, and what are you reading the codes with?
  6. IMkenNY
    477
    303
    Tropical Buffalo NY
    Four Touring
    Reboot but before you attempt to start the Prius try to give the traction battery a charge with your evse cable.
  7. Ralvals
    Vladivostok
    Vladivostok. The programm is called Techstream
  8. bisco
    49,492
    thanks, that is the correct software. how is the health of the 12 volt battery?
  9. Ralvals
    Vladivostok
    14v
    doesn't work, not charging.
  10. Ralvals
    Vladivostok
    Also i have other photo with Techstream
  11. Prodigyplace
    Prodigyplace Senior Member
    11,696
    11,318
    Central Virginia
    Did you check the 12 volt battery with the car off after it has not been used for a time?
    If you check when in Ready mode you will read the 14 volts from the inverter that charges the 12 volt battery.
    A good battery usually reads between 12 and about 13.5 volts if I recall correctly.
  12. jerrymildred
    jerrymildred Senior Member
    11,511
    14,113
    Tampa, FL
    It looks like the ground fault interrupter on your EVSE tripped. Does it reset?
    #12 jerrymildred, Jun 5, 2017
    Prodigyplace likes this.
  13. bisco
    49,492
    is there anything unusual about this car, accidents and etc.? have you owned it since new?
  14. Ralvals
    Vladivostok
    Yes, sorry. Without charging 12.1v
    Used car. The car was hit on the front right side but not too much.
    I press reset and then test but nothing changes.
  15. bisco
    49,492
    have you tried a public charger?
    12 volt is low, especially considering that it gets charged every time you charge the hybrid battery.
  16. Prodigyplace
    11,696
    11,318
    Central Virginia
    If you have a GFCI (gound fault) receptacle, they tend to go bad over time.
    Have you tried plugging in a lamp to see is power is reaching your EVSE?
  17. Ralvals
    Vladivostok
    Our country don't have public chargers.
    I think my 12 volt battery don't charging from the inverter because i don't hear the sound of
    triggering relay ((3) on scheme). Also in power cable connecting place to traction battery there is no voltage.
    More in detail please.
    bisco and Mwoo30 like this.
  18. Prodigyplace
    11,696
    11,318
    Central Virginia
    I meant plug a lamp into the 120 volt receptacle you use for the charger to verify electricity is being provided to your charger.
  19. bisco
    49,492
    does it run in hv mode, or not run at all? if the 12v isn't charging, test the voltage after it has been off for a few hours, trickle charge it, test again after a few hours. if it is 12+ try starting the car.
  20. Ralvals
    Vladivostok
    My problem in this video
    I tried with other 12v battery.
    #20 Ralvals, Jun 13, 2017
