Hybrid Cell Voltage
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Ralvals, Jun 4, 2017.
  1. NeilPeart
    NeilPeart Hybrid & PiP Convert
    75
    69
    Bay Area, CA (USA)
    Perhaps it could be an inverter failure? My wife's 2010 Prius III recently experienced something similar and that was the root cause - the dealer replaced the inverter, the fluid, etc at no cost under warranty. She runs perfectly now.
  2. Travis Decker
    Travis Decker Active Member
    139
    116
    Portland OR
    Isn't your car under warranty?
    Nexus 6P ?
  3. Prodigyplace
    12,706
    11,846
    Central Virginia
    What is the Toyota warranty in Vladivostok? I am pretty sure it is different than the US.
  4. QuantumFireball
    QuantumFireball Active Member
    420
    269
    Ireland
    Ralvals' car is a used import from Japan - there is no warranty.
    Prodigyplace likes this.
  5. Prodigyplace
    12,706
    11,846
    Central Virginia
    Thank you for that additional information. It was not mentioned in the initial post.
  6. jerrymildred
    jerrymildred Senior Member
    11,517
    14,164
    Tampa, FL
    So what ever happened? Did you get it fixed under warranty?
    I'm also curious how @Ralvals is coming along.
    Raytheeagle likes this.
  7. Ralvals
    Ralvals Junior Member
    Vladivostok
    I am sorry for the delay.
    I solved the problem for low voltage.
    I replacement the bad cell.
    But i have now a new trouble - high voltage :)
    Did you Initialize the HV battery after replacement fuse?
    #47 Ralvals, Aug 4, 2017
  8. jerrymildred
    11,517
    14,164
    Tampa, FL
    Oh no!
  9. Ralvals
    Vladivostok
    Do you know anything about it ?
    #49 Ralvals, Aug 5, 2017
  10. jerrymildred
    11,517
    14,164
    Tampa, FL
    I don't remember ever reading anything about that happening. As far as I know, there is still no way to grid charge a PiP, so I would guess you'd need to balance them manually, one at a time, but after all the cell phone fires, lately, I'm not likely to try that without knowing a lot more than I know now.
    I think @jeff652 once said he was thinking about something like that.
  11. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,525
    Bay Area, California
    2019 Prius Prime
    [QUOTE="jerrymildred, post: 2581606, member: 149132
    I think @jeff652 once said he was thinking about something like that.[/QUOTE]
    When I had him install the harness on our 2010 in February he said he was. But Lithium technology is trickier :(.
    Prodigyplace and jerrymildred like this.
  12. jerrymildred
    11,517
    14,164
    Tampa, FL
    There's an understatement! :)
    Prodigyplace and Raytheeagle like this.
  13. Raytheeagle
    11,267
    15,525
    2019 Prius Prime
    I try to keep it concise ;).
  14. Simtronic
    Simtronic Active Member
    290
    116
    Surrey, UK
    2017 Prius PHV
    Business Ed. Plus
    Did you manage to fix your problem? I have replaced a cell in a lithium pack before and know how hard it can be to balance the cell voltages, SOC and temperature if under-charged I have discharged a single cell while in pack until accepted by the BMS but on a much smaller system. It would be quite dangerous to attempt that if you aren't sure what you are doing.
  15. Ralvals
    Vladivostok
    Hello!
    I replaced the traction battery and my problem is gone.
    Please, give me more information.Did you discharge cell on the running car?
    I replaced 1 cell in the pack and got high voltage.
    #55 Ralvals, Nov 10, 2017
  16. Simtronic
    290
    116
    Surrey, UK
    2017 Prius PHV
    Business Ed. Plus
    Yes with a headlamp bulb to bring down the voltage on that cell but that wasn't a Prius which is complicated by 6 cells stuck in one battery meaning the only way to balance those cells is to slowly overcharge and discharge until you get the capacity back in that 7.2v battery within the pack. The Nimh batteries are also quite temperature sensitive making balancing even harder. I am glad to hear you resolved your problems
  17. QuantumFireball
    420
    269
    Ireland
    You replaced the whole traction battery? Did you find a used replacement, and was it expensive?
  18. Ralvals
    Vladivostok
    I bought the whole battery for 1500$ with shipping.I found the used battery.
    Sorry, maybe I didn't understand you, I have the prius phv and he has 56 cells with voltage 3.7v each.
    QuantumFireball likes this.
  19. Simtronic
    290
    116
    Surrey, UK
    2017 Prius PHV
    Business Ed. Plus
    I think maybe I misunderstood you, yes 56 cells nominal voltage maybe 3.7v but Toyota charge them to a maximum of 4.15v and should be much easier to balance. You can also Parallel the modules to assist. Sorry for late reply I've been very busy lately.
  20. fatfash
    fatfash Junior Member
    US
    Did you manage to resolve the problem
