Hybrid Cells Reading High in Voltage??
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Richiemoe, Feb 14, 2018.
  1. Richiemoe
    Richiemoe Junior Member
    67
    West Michigan
    This is the 3rd or 4th time that i've had a battery issue. I'm pretty sure it is the 4th time. My wife's 2006 Prius just rolled over 200k miles. She was leaving work and called me that her dash lights came on like they have in the past, but it was still driving fine, so i suggested it was fine to continue home. Instantly, i ordered a battery from ebay around 5pm. The same guy that i've bought from before ships out of Florida $36 OTD and it arrived Monday afternoon!\
    Anyway, after working 12hrs on Monday, that evening I took the hybrid battery pack out and started testing each cell. Oddly, they ALL tested above 8V; most around 8.24 & 8.36. Which is weird, because i know that when i've tested them before, most were high 7's and only a few were about 8... The lowest one on this most recent test was at 8.11. Even though my gut said it was the 5th cell in from the ECU(ECM same thing?) that read 8.11, i put the pack back together and put it back into the car and hooked it back up. Why? Because i assumed it would be as easy as the other fixes.... haha I totally forgot to scan the fricken car!!! ugh!!!
    The codes came back on again the next day, so this time i scanned it. I'm still getting used to the new version of techstream that i upgraded to (Ver 12.00.127). The previous version would scan the whole thing. This version it looks like i need to select modules to scan. So i selected the Hybrid HV option and it showed code P3000-123. Then i clicked on the snowflake and it showed/confirmed that the 5th cell is most likely the issue. "Battery Block Vol -V11 15.11". All of the other blocks are around 16.4* volts...
    So i took out the bad cell, which took a bit to undo all of the side and bottom bolts/nuts, slide the cells toward me and put in the "new" cell, which reads at 7.84V. The old one still read at 8.04V, but i'm assuming the integrity of the battery is dying? So i put it all back together and on the very LAST cell, i tighten it too hard and effing break off the stud on the first cell............ UGH!!!!! Whatever, it is late and i'm tired, and it looks like there is enough of the stud left for the metal to tough and get a good connection with (wishful thinking).... So i put the battery back in, pull out of my neighbors heated garage so he can go to sleep (Michigan is cold...) and i drove it to work this morning.
    I got almost to work before the dash lights came on again. So i scan it again in my work parking lot. This time, i took my time and scanned multiple modules. I still get "P3000-123 Battery Control System", then in another module i get "P0AFA - Hybrid Battery System Voltage Low". And under the "ABS/VSC"TRAC Live" tab, codes: C11249, C1259, C1310, C1311 & C1313. I'm pretty sure C1249, C1311, C1313 show why one of the brake lights keeps going out due to an Open Circuit. And C1259 & C1310 will go away after the bad cell is fixed. Still weird, the last version of techstream gave me a specific code for which cell pack was bad... So i look at the snowflake for P0AFA and it shows "Battery Block Vol -V01 -8.86". Yeah, negative might be a bad thing.... But that is the one that i broke off... The rest all show in the low to mid 15.** range. Except the one i replaced last night, 14.63V. I assume that is because it hasn't gotten a chance to charge up yet?
    BUT, something that just dawned on me, maybe none of the cells were bad??? After reading some other postings this morning, it dawned on me, the hybrid cell pack fan wasn't blowing 100mph like it normally does... Plus, maybe that is why the scan didn't show a specific battery pack code like before. Which i doubt, because cell pack 1 is clearly effed after i broke the stud off... Any suggestions? Maybe after i fix the cell with the broken stud, it will work again? Do i need to strain the batteries more before testing? Maybe not a cell since the fan wasn't blowing like crazy?
    My wife is due with our first child (daughter) on March 4th. I'm really trying to have this fixed and not spend a lot of money on it, before the baby is born... Please let me know if i need to include additional data, or if uploading pictures of the results will help at all. I have the scanner/laptop in the car and can run out quick to do another scan.
    52,773
    R u load testing the modules?
  3. Richiemoe
    67
    West Michigan
    What do you mean by load testing? I've tested it while fully turned on (driveable) and with the power button pushed twice without pushing down the brake.
    Usually, i just scan the car, it tells me which cell is bad, i double check it with my tester, swap out the battery with a replacement, and i'm good for another 6 months...
    52,773
    no expert, but i think you need to drive the car to put a load on. or take the modules out and load test them with a light bulb.
    you can find everything you need to know in a thread by @ryousideways .
    Raytheeagle and SFO like this.
  5. Richiemoe
    67
    West Michigan
    Thanks! i started reading up on it after your post. I drove the car, but i think it seemed to charge the batteries still. So i put the car in reverse and it seemed to use battery mode, but i don't think i did it long enough to wear down the battery charge...
    That seems simple enough with a light bulb.
    I did order another battery this morning though. The attached file shows a screenshot of the last scan i did. I think/hope/wish that after fixing the battery that i broke the stud off, it'll work again. For another 6 months, until another cell goes bad again... It is at 200k miles...
    Oddly, i keep seeing posts that say the cells closes to the ECM are group 1 and the two cells furthest away are group 14. But the very end cell that i broke shows on my techstream scan as block 1... And the one that i just replaced was number 5 in from the ECM, which as improved block 12. Prius Scan_14Feb18.jpg hmmmm...
  6. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
    On a Gen2, Block 14 is closest to the ECU/controller.
    Picture for reference:
    Raytheeagle likes this.
  7. Dxta
    Dxta Senior Member
    1,942
    769
    Lagos
    You are definitely doing something wrong here.
    First and foremost, you should ha e load tested all the modules. What you have being doing, is whack a mule approach from the beginning. I'd you don't follow the right procedure, you'd keep coming back doing the same thing.
    Replacing the bad module, won't solve the problem.
    Load test all the modules using a headlamp bulb. That would show you which of the modules are weak. I don't always trust the scan telling me its just a module. I go ahead, and for instance, instead of replacing just a single module, I instead, replaced the whole block on the faulty module. I do this, considering the effects of thermal runaway on the other nearby modules or blocks.
    The load test, should help identify other weak modules in the pack.
    Do the damr thing for the module you've ordered, and finally discharge and charge all the modules to say, 8.00V. Allow the pack to rest for some hours, then read the OCV again to see if they hold charge.
    Pictures below is for a Camry hybrid I just rebuilt last week.
    IMG-20161223-WA0001.jpg IMG_20180212_111133.jpg IMG_20180212_122253.jpg InShot_20161103_004422.jpg InShot_20161217_074202.jpg
    The 8.40V you were getting on the modules are correct and OK. You were getting that, because you immediately removed the pack from the car in its charged state.
    Believe me, if you allow the modules to rest for some days, they'd all come down to about 7.40V or so. The bad ones amongst them, would either fall quickly to maybe 7.0, or 6....volts.
    Hope this helps.
    Dxta
    CEBA Battery and SFO like this.
  8. Prodigyplace
    12,710
    11,848
    Central Virginia
    They should be able to use Prolong chargers & dischargers (conditioning system) for this, correct?
    Or does the discharger tak e the battery too low to isolate the bad modules?
    @jeff652 can tell us definitively.
    I realize that in Lagos you do not have this equipment available in the US.
    I am also assuming the OP is in the US.
  9. Dxta
    Dxta Senior Member
    1,942
    769
    Lagos
    Definitely, I don't have the prolong charger. But I do have grid and hobby chargers I use. I also use headlamp bulbs for load testings, etc. Sometimes, I discharge the pack using using the reverse and engaging the AC system at full blast. This discharges the battery to nearly 39%. I then remove the pack and check what I want to check.
    Habali and Prodigyplace like this.
  10. Sam Spade
    Sam Spade Senior Member
    2,036
    1,024
    2017 Prius c
    What kind of battery are you buying for $36 ???
    You might be your own worst enemy here.......by trying to go TOO cheap.
    I think you are right on the edge of diminishing returns with this car.......and your money likely would be better spent on a newer model with fewer miles AND without the added complexity of a hybrid.
  11. Richiemoe
    67
    West Michigan
    Thank you all for your input! I had not clue about the load testing! After the replacement battery came in the mail to fix the one that i broke the stud off of, everything seems to be working, with no dash lights on. I got lucky replacing the one that i originally thought was bad. The voltage was only slightly lower than the rest of the cells, so i assumed that was it. But that could definitely become a guessing game if i don't do the load test, i'm seeing. Thanks again!!!
    I've been ordering used batteries from the same seller on ebay for $36-$39. The ones that i just bought came out of a 2013 Prius. My wife's 2006 Prius has 201k miles. If it was still around 100k, i'd replace the whole battery pack. But we'll probably drive this car until it dies. Well, until student loans are paid off and we have the cash saved up for another car.
    Right now, i'm around every 6-9 months that another cells is going bad. If it starts happening more quickly, then i might rethink my ways... haha But a 4-6 hour job every six months isn't so bad. Valvoline High Mileage Synthetic Oil. I do need to replace the spark plugs and change the transmission fluid soon. But this car has been very cheap to maint..... I'm not going to finish that sentence..... hahaha
  12. nathaniel Stuckey
    nathaniel Stuckey New Member
    Mount morris Illinois
    I am having the same issue I have a 2006 Toyota Prius with 445000 miles solid car I took the battery pack out tested and load tested everything and I am still getting a solid 815 to 825 volts on each module but the car keeps throwing a code and pack so I went out and I purchased another pack out of a vehicle that was totaled and now not one problem so why is it that my original pack is giving me so many issues so far I replaced three modules in it but when I run my scan tool on there it jumps around and says block 5 block 13 block one just all over the place for it just jumps all over the place instead of giving me an accurate pinpoint of which block is bad anybody have an idea why are my voltage is so high like a good module I'll be willing to give my phone number if it's easier to explain thank you very much
  13. nathaniel Stuckey
    I mean I'm having the same problem will charging and discharge cells bring them back to life if they have been heavily used 445,000 on the pack.
  14. dolj
    dolj Senior Member
    8,633
    4,386
    Wellington, New Zealand
    Have you considered that they are all spent and you should just replace them all with new ones? If you don't like the idea of new, look out for newer ones, maybe no older than 5 years, from a recent wreck, maybe.
    Habali and nathaniel Stuckey like this.
  15. Dxta
    Dxta Senior Member
    1,942
    769
    Lagos
    There's nothing to rebuild on those packs again. Buy new pack. Mileage already says it all.
  16. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
    You didn't replace the "whole hv battery pack" with that used pack from the totaled vehicle, just a few of the failed/failing modules?
    Which OBD2 scanning device are you using to scan for potential DTCs, are you using Techstream?
  17. nathaniel Stuckey
    I'm using torque app pro
