Hybrid Charge Mode Question
Discussion in 'Prime Main Forum (2017-2022)' started by Wattup, Jan 25, 2017.
  1. Wattup
    Wattup Junior Member
    Hi guys, first post and first time Prius owner. My quick question is, is it worth losing some gas in order to charge the battery with the hybrid charge mode? It the amount of charge worth more than the amount of gas used to charge it? Thanks!
  2. ForestBeekeeper
    ForestBeekeeper Active Member
    780
    310
    Maine
    We stay in ECO mode. Though we have been playing with the CHG setting. It charges the battery pretty quickly.
  3. Pizza Driver
    Pizza Driver Active Member
    158
    156
    United States
    No. There are natural energy losses in the engine (maximum of 40% efficiency) and then in transferring that energy to the battery.
    The only reason to consider using the engine to charge the battery is if you cannot charge elsewhere but wish to have some EV range for use for short local trips where you want to avoid the engine going through its warm up cycle.
    Chaughten, Trollbait and bisco like this.
  4. bowang
    bowang Member
    45
    37
    Example usage 1: before entering indoor parking structure or ZEZ zero emission zone city like Tokyo.
    Usage 2: some country it's illegal to have engine on and parking for more than 5 minutes. Prime can use EV mode for AC without engine.
  5. mr88cet
    mr88cet Senior Member
    2,313
    1,335
    Austin, TX
    I'm not sure whether this is exactly what you're asking, but I did the proverbial back-of-the-envelope calculation, and at least here in Austin, operating the P.Prime on electric worked out to about 1/4 of the cost per mile of fuel at 55MPG. 1/4! I like that.
    Now, granted, The City of Austin (Texas) has some charging subsidies, but even factoring that out, it's on the order of 1/3 to 1/2, depending upon where I charge.
    bowang likes this.
  6. huskers
    huskers Senior Member
    2,551
    2,489
    Nebraska
    Wattup, welcome to the board. Lots of good info here to make you a Prius owner for life.
  7. mr88cet
    2,313
    1,335
    Austin, TX
    Oh oh oh, I understand your question (I think) now: Whether it's worthwhile to use the setting to charge the battery from the engine. I would not expect that to "pay off," so to speak.
  8. bisco
    52,905
    agree with all of the above, you'll pay a financial penalty for using it, so you would have to have a good reason such as you're heading for a big mountain climb, or just want some ev to toot around in.
  9. Trollbait
    12,833
    Pretty much it will only have a chance of being worth it, is when you won't be able to charge where you are going, and you will be doing short trips there before getting a charge.
  10. Wattup
    Initially I was thinking if this was not worth it why Toyota would even have this option. I can see why this could at times be necessary. Appreciate all the replies.
    bowang likes this.
  11. bisco
    52,905
    they got a lot of heat when volt came out with it, and took the bait.
  12. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    It is also preparing for the future. Zero Emissions zones in city centers.
    bowang likes this.
  13. Wattup
    Will charge rate be the same while the car is stationary, low rpm, as opposed to when the car is moving?, higher rpm (all other factors such as braking decelerating aside)
  14. giora
    giora Senior Member
    1,966
    730
    2013 Prius Plug-in
    Charge mode is a new feature, not a lot of empirical data...why not trying it and report your findings?
    bowang likes this.
  15. bowang
    bowang Member
    45
    37
    Quick summary for the CHG mode i tried earlier this month
    - took 32 minutes to charge battery from "empty" to 30%, i.e. 30% of 6.5kwh. This is faster than L2 charging.
    - Reported 32MPG from dashboard. Same route I usually get >50MPG using gas (hybrid mode)
    Not sure what page in manuals is it. Learn it from another hybrid driver
    ruby, Wattup and giora like this.
  16. Wattup
    Good idea. I'll give it a shot and see how it compares and post the results.
    giora likes this.
  17. giora
    giora Senior Member
    1,966
    730
    2013 Prius Plug-in
  18. giora
    giora Senior Member
    1,966
    730
    2013 Prius Plug-in
    Manual does not tell a lot on charge mode...to say the least.
  19. GA_Prime
    GA_Prime Junior Member
    Atlanta, GA
    One of the uses is to extend the range of your next tank of gas.
    I was driving through South Carolina and was going to stop for gas at Costco 100 miles away. Seeing that I had more than enough gas to get to the gas station, I switched to charge mode. When I got to the gas station, I had 10 miles of gas left. So I got an extra 25 miles of range for this relatively inexpensive tank of gas.
    Chaughten and priuscatprimeguy like this.
  20. bisco
    52,905
    this is my fear, that prius now becomes less efficient.
    Trollbait and bowang like this.
