Hybrid Interface 2013
Discussion in 'Prius PHEV Plug-In Modifications' started by NortTexSalv04Prius, Jun 9, 2013.
  1. whereswally606
    whereswally606 Junior Member
    uk
    I have a member pashko90 in for 1 to 3 boards, just need one more interested customer and i will order a batch of 5 boards. wont have the prius till august when i can afford it
  2. jc.maquet
    jc.maquet Junior Member
  3. jc.maquet
    hello
    I'm currently making new pcb design in eagle. it will be ready soon I hope.
    if anyone is interested, it will be nice to check it before make PCB.
    let me know.
    NortTexSalv04Prius likes this.
  4. jc.maquet
    it's almost ready.
    ground plane must be added
    some strange overlap error with smd. manual routing doesn't work with smd pad.
    I need to find somebody good in eagle...
  5. bwilson4web
    16,515
    Please refresh my old man memory. This is a BMS for a Gen-2 Prius?
    Can I get a high level description of what it does since the web page has gone dark?
  6. lopezjm2001
    lopezjm2001 Senior Member
    1,146
    407
    Sydney Australia
    Hi Bob,
    Only works with second generation. The BMSplus module interconnects into the CanBus wires just before the battery ECU. It captures the HV Battery SoC message on the CanBus and changes the SoC value and then transmits back on the CanBus so that the Hybrid ECU gets the modified SoC message (higher SoC value) and as a result the Hybrid ECU will ask to use more HV battery and less ICE. That pretty much sums it up.
    #46 lopezjm2001, Dec 28, 2018
  7. jc.maquet
    hello
    the bms2 clone is mounted, I'm waiting for jtag programmer to test it.
    if anyone is interested I have 4 pcb available or I can make a complete working device.
  8. NortTexSalv04Prius
    NortTexSalv04Prius Active Member
    915
    116
    Okay I may be down for two complete and populated boards ….. I do have some specific questions that must be address before any payment
  9. jc.maquet
    hello NortTexSalv04Prius
    I'm still waiting for programmer from china to test the board
    when do you need these 2 board ?
    you can send me your question by PM
    thanks
  10. NortTexSalv04Prius
    915
    116
    thanks just keep me updated
  11. jc.maquet
  12. NortTexSalv04Prius
    915
    116
    JC
    How would someone display the can data from this. I have a 7" VGA Lilliput touchscreen that I am hoping to use. However I am wholly ignorant on hardware and programming .. .. I am unsure about CANVIEW
  13. NortTexSalv04Prius
    915
    116
    Lopez and or anyone who own original interface …...Do you and can you explain how the CAN data was display ...if I recall you had possible choice of VGA or MFD display... thanks
  14. lopezjm2001
    1,146
    407
    Sydney Australia
    It was done using mmbasic programming by Geoff (Geoff's Projects - Maximite Basic). Too complex for most people. You can read about it here - (My Duinomite Mega Canview V4 equivalent Project | PriusChat). I no longer have a Prius so I have forgotten it all.
  15. NortTexSalv04Prius
    915
    116
    I had a closer look....the EAA PHEV website has some information as does Calcars......from my understanding if you have/had factory navigation with DVD player below driver seat then you had VGA capability . Gen 2 without factory navigation used a cable (modified) that connected to back of MFD and require a setup
  16. NortTexSalv04Prius
    915
    116
  17. jc.maquet
    hello
    NortTexSalv04Prius,
    hybrid assistant
    is a very simple way to display Prius canbus info.
    a good odb2 dongle and a simple smartphone are only required.
    it's free and available from play-store
    my bms2 clone is working, I can see SOC modification according to bms2 on/off button
    when enable, SOC goes to 99% when power is asked.
    I still have to test if power relay is correctly drived in P4 off mode.
    the status led remain always on.
    #57 jc.maquet, Feb 24, 2019
  18. lopezjm2001
    1,146
    407
    Sydney Australia
    You can use a Scangauge II. Or Torque Pro. Or a Canview.. You should see the HV battery all bars on your MDF light up all green when the SoC is 99%. Congratulations. Nice work.
    #58 lopezjm2001, Feb 24, 2019
  19. NortTexSalv04Prius
    915
    116
    He
    Question
    When you can or have time can you post a working screen shot..?
    When I checked hybrid assistant Link ….the screenshots where like Prius C /Aqua and Yaris
    You mean a OBD2 dongle like the ELM knockoff you see listed on Ebay?
  20. NortTexSalv04Prius
    915
    116
    I do have scanguage 2
