Hybrid Pit Stop
Discussion in 'Gen 3 Prius Main Forum' started by AzusaPrius, Sep 19, 2021.
  1. xliderider
    xliderider Senior Member
    8,140
    3,280
    Honolulu, HI
    Yep, I removed the stud and left it off when I swapped in the EGR cooler I cleaned ahead of tackling the job.
    Won't need to worry about it next time.
  2. Mendel Leisk
    42,305
    That’s happening now?
  3. AzusaPrius
    AzusaPrius Senior Member
    2,253
    942
    @Mendel Leisk
    This has been happening since my original engine.
    I was getting low 42mpg no matter how well I took care of it.
    Then once I put the Lithium HV battery in there was a gain and the mpgs went to normal oem specs of 52 mpgs.
    Now with the rebuild, it is already factory mpgs plus the extra 10 mpg gain from the Dr. Prius battery.
    http://www.RedBullet.net
    Toyota hybrid battery upgrade pack– NexPower Energy
    http://www.Pulstar.com
    http://www.PlugOutPower.com
    Use code 7373
    http://www.hybridpit.com
    use code azusa
    mikey_t likes this.
  4. AzusaPrius
    2,253
    942
    mikey_t and xliderider like this.
  5. mikey_t
    mikey_t Active Member
    371
    391
    Los Angeles
    Would you mind sharing the cost of your rebuild? And how is the car running these days?
  6. AzusaPrius
    2,253
    942
    Mine was about $5k with complete egr and IM cleaning.
    Also other random parts replaced.
    The engine is like new and I watch the temps all the time.
    I can not complain about anything as of now.
    Montgomery, Johnny Cakes and mikey_t like this.
  7. Fitcious
    Fitcious Member
    195
    88
    Los Angeles
    How much did you buy the car for initially and how much was the HV lithium battery?
  8. AzusaPrius
    2,253
    942
    The HV pack is $2k and I paid the PO $7,400
    Fitcious likes this.
  9. mikey_t
    371
    391
    Los Angeles
    Thank you. That's roughly the estimation that they gave me. It's also not that far off from the price of just a head gasket replacement at the dealership, so I think it's the option I need to go with.
  10. AzusaPrius
    2,253
    942
    That is the reason I went with them, cost not that much more than HG replacement so why not get a fresh build?
    The assurance that the engine is rebuilt and clean.
    2015 pistons & rings too cant go wrong.
    mikey_t likes this.
  11. Mendel Leisk
    42,305
    For that 5k they put in 2015 pistons/rings too?
  12. RightOnTime
    RightOnTime Senior Member
    791
    1,660
    183
    Kidnapped in OC, CA
    Yes indeed! Revised pistons and rings!
    iPhone ?
    GregC1979, Mendel Leisk and mikey_t like this.
  13. rjparker
    rjparker Tu Humilde Sirviente
    11,049
    6,924
    Texas Hill Country
    I have seen rebuilds here in Texas for $3500 with the dealer quoting $5k-$7.5k depending on reuse of block or new shortblock. Of course since the border was closed prices are beginning to rise.
  14. RightOnTime
    791
    1,660
    183
    Kidnapped in OC, CA
    Another rebuild a couple of days ago. Another Head Gasket issue
  15. Mendel Leisk
    42,305
    That throttle body pic: design fail Toyota.
  16. Montgomery
    Montgomery Senior Member
    2,254
    2,242
    Orange County, CA
    I am a believer in the OCC system. Really catches the gunk!
    RightOnTime, Mendel Leisk and mikey_t like this.
  17. tony_2018
    tony_2018 Member
    227
    68
    I did this when I cleaned it the 1st time.
    RightOnTime, mikey_t and Montgomery like this.
  18. tony_2018
    tony_2018 Member
    227
    68
    I'll go ahead and confirm this to be true. There is some torque. I had a race with a hybrid rav4 and walked it. I just dont know if that driver was in full ev mode or not but their engine has more hp though.
    mikey_t and RightOnTime like this.
  19. RightOnTime
    791
    1,660
    183
    Kidnapped in OC, CA
    Prius V going in for surgery! This was a head gasket Job but played it safe by pulling out the whole engine just in case it was bent rods. Car was towed to the Shop with 150k
    We took a pic of the Hoses that needed to be replaced. Glad the Customer gave us the thumbs up to replace!
    orenji, Mendel Leisk and mikey_t like this.
  20. jzchen
    jzchen Newbie!
    3,316
    1,022
    Arcadia, CA
    @RightOnTime How about engine mounts? I noticed some kind of mount on the bottom rear of engine when I had the subframe dropped that looked otherwise hard to replace....
    REVVL V+ 5G ?
