Hybrid Pit Stop
Discussion in 'Gen 3 Prius Main Forum' started by AzusaPrius, Sep 19, 2021.
  1. RightOnTime
    RightOnTime Senior Member
    791
    1,660
    183
    Kidnapped in OC, CA
    Chapman
    We are going to have to agree to disagree with your last comment.
    The cam bearings caps as well as the OCV filter is very important to look at when removing the valve assembly.
    As instructed from the Toyota Bible this would let you check for cam wear (Shavings) which can be present from running too dry and or other issues.
    Can you imagine not taking 2 minutes to look at this? It is just a ticking time bomb waiting to explode!
    You got to trust the good folks at Toyota that help create the step by step instructions to disassemble and assemble the valve assembly. It is very crucial to a healthy running engine.
    We are looking for long term results rather then short term results.
    Chapman it may be best to step back and move on to another Thread, just like to keep things moving in a positive direction. God bless you and your family.
    #101 RightOnTime, Dec 2, 2022
  2. RightOnTime
    791
    1,660
    183
    Kidnapped in OC, CA
    Pics for reference
    No Bueno
    TGrracie and mikey_t like this.
  3. ChapmanF
    19,041
    Something in my last comment must not have been clear at all.
    I was not remotely talking about what you guys do, as an engine rebuilding shop, when you are removing the valve assembly.
    My comment in post #94 was a reply to post #93, which was from an ordinary Prius owner asking if he should treat that filter as "another maintenance item":
    In other words, i was answering the question "should ordinary Prius owners be going and disassembling their intact engines down to the valve train, every now and then, just because they have heard there's a little filter in there that might get dirty?"
    My answer to that question is no, unless there is some other reason to be doing that disassembly, there isn't enough chance it will be useful, and there is too much chance of causing new problems inadvertently.
    After I wrote that in #94, you seemed to think I was saying that a shop like Hybrid Pit shouldn't check it while the engine is apart. I wasn't saying that, and I wrote post #100 to further clarify that I wasn't saying that, and I guess it still needs to be further clarified.
    What makes sense for a shop to do while working on an engine that's apart, and what makes sense for a typical car owner to go disassembling things just to check, are not always the same.
    TGrracie, CR94, mikey_t and 2 others like this.
  4. mikey_t
    mikey_t Active Member
    371
    391
    Los Angeles
    I wish I had asked about the possibility of getting a rundown on the shape of my engine after my rebuild swap. Just out of curiosity as I'd love to know the nerdy bits about everything out of order.
    RightOnTime and GregC1979 like this.
  5. RightOnTime
    791
    1,660
    183
    Kidnapped in OC, CA
    Let’s get back to business……
    We have just finished playing catch-up to Engine orders and now have stock inventory
    Burna J, orenji, Ohmstyles and 4 others like this.
  6. RightOnTime
    791
    1,660
    183
    Kidnapped in OC, CA
    We got a name going on for our quality Engine builds and for our world famous EGR service. We are afraid that the time has come to step up our game
    Platinum EGR service for Prius and CT200h includes:
    ◦ New Oem Toyota EGR stepper motor and assembly
    ◦ Exhaust gaskets for both EGR pipe and EGR Cooler
    ◦ Toyota intake gasket
    ◦ Toyota throttle body gasket
    ◦ All necessary hoses (5) replaced with OEM Toyota - in stock
    ◦ EGR pipe and Cooler cleaned and working up to OEM flow specs
    ◦ Free water pump inspection with option of replacement with genuine OEM Toyota
    ◦ Complimentary Vacuum and removal of leaves and debris from window wiper cowl
    ◦ Pressure tested using Snap on Tool
    ◦ Torque to spec - No shortcuts
    ◦ Oem Toyota Pink Coolant
    To set that goal post higher we are offering any follow visit before 150k with another EGR Service for $250
    Because? Passion with perfection
    ockevin, Xterra72, Burna J and 3 others like this.
  7. AzusaPrius
    AzusaPrius Senior Member
    2,258
    952
  8. Montgomery
    Montgomery Senior Member
    2,254
    2,244
    Orange County, CA
    Gang, I had this done 10k miles ago! They are thorough and quick! Highly recommend them if you live in the SoCal area.
  9. Ohmstyles
    Ohmstyles New Member
    Fairplay, co
    Been stalking these forums for some time but thought I would post finally about these guys. I ordered a remanufactured engine for hybrid and couldn't be happier. I got one of the two mentioned above. I'm out here in Colorado and blew my head gasket on my gen 3 engine. Greg over at hybrid pit stop got me a remanufactured engine out to me stat. I went with the gold package. I had Paul and Sammy over at boulder hybrids install the engine in under a day. I'm just breaking here in. I have put about 100 miles on her and she's running like a top. Thanks a ton guys and I'll keep yall updated to how she's running a few 1000 in.
  10. Mendel Leisk
    42,362
    Did the EGR and intake manifold get cleaned as well?
  11. RightOnTime
    791
    1,660
    183
    Kidnapped in OC, CA
    It’s a bare package without the EGR and intake manifold
  12. Mendel Leisk
    42,362
    Had to reread, couldn’t remember, anyway: I was wondering if Boulder Hybrids, who did the install, also cleaned the intake and EGR. To avoid a repeat.
    I should have said boulder hybrids when I posted that question. At least now it’s clarified.
    #112 Mendel Leisk, Feb 21, 2023
    RightOnTime likes this.
  13. Ohmstyles
    Fairplay, co
    They did get cleaned out properly before reinstall as well of the intake manifold and throttle body. I put new coils, plugs and remaned injectors in. So far so good. The reason I'm sure this head gasket went is the car over heated over a mountain pass here in Colorado and within 20k it blew. I had dropped all the coolant and blew the water pump. Did the 500 mile oil change and found out I got the upgraded oli filter conversion kit so needed(90915-YZZN1).
    • [​IMG]
    RightOnTime, mikey_t and Mendel Leisk like this.
  14. RightOnTime
    791
    1,660
    183
    Kidnapped in OC, CA
    Shop finally got caught up with our engine rebuilds! We offer a variety of Prius / CT200h rebuild engines including a GEN 4 and a Zero mile Toyota Block fully built to our specs
    (855) 492-4440
    11am to 4pm (SoCal)
  15. RightOnTime
    791
    1,660
    183
    Kidnapped in OC, CA
    We recently had a customer come in for a CatShield install because of previous theft.
    Insurance company decided to take it to a
    Shop for a replacement and did not inform the Owner of this Amazing work piece….
    Foxglove and Mendel Leisk like this.
  16. Matth Torrijos
    Matth Torrijos Active Member
    121
    218
    Poway
    IMG_6559.jpeg Payed a visit, always something new at this place!
  17. Montgomery
    2,254
    2,244
    Orange County, CA
    Matth Torrijos! Give me a heads up next time your in Hybridpit area! I wanna see your car in person!
  18. Matth Torrijos
    121
    218
    Poway
    PM me on IG: priimayed
    Montgomery likes this.
  19. RightOnTime
    791
    1,660
    183
    Kidnapped in OC, CA
    We are blessed to get our 1st Gen 5 Prius in….
  20. AzusaPrius
    2,258
    952
    Hey Roger, lowkey can you get an ETA on my order?
    No need to say what I ordered here tho
    So you can PM me with details if you can.
