Hybrid Pit Stop
Discussion in 'Gen 3 Prius Main Forum' started by AzusaPrius, Sep 19, 2021.
  1. Montgomery
    Montgomery Senior Member
    2,254
    2,244
    Orange County, CA
    RightOnTime likes this.
  2. RightOnTime
    RightOnTime Senior Member
    791
    1,660
    183
    Kidnapped in OC, CA
    MillerCat install on a Gen 5 Toyota Prius! We are a proud Dealer too
    mikey_t, Matth Torrijos and Ryan Will like this.
  3. AzusaPrius
    AzusaPrius Senior Member
    2,258
    952
    Nice I just got mine installed today.
    Millercat 304 stainless steel v2 with the best Millercat custom screws!!!
    You can get a discount for these in my Millercat thread. 20230421_101242.jpeg
    RightOnTime, mikey_t and Montgomery like this.
  4. mikey_t
    mikey_t Active Member
    371
    391
    Los Angeles
    How easily accessible is the Gen 5 cat?
  5. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,576
    2,605
    Taylors, SC
  6. ChapmanF
    19,041
    For that matter, does Gen 5 still have two cats like the earlier gens?
    I'm guessing that the answer is yes, and you just can't easily see the front one, in that photo.
    Am I seeing that they've done away with the heat recovery system?
  7. Georgina Rudkus
    3,576
    2,605
    Taylors, SC
    The exhaust pre-heater provides early heat for the cabin heater. Gen 2 used a thermos to store residual heat. It could be that Gen 5 uses a more expensive and complicated unit like the heat pump in EV's like on the Prime.
  8. RightOnTime
    791
    1,660
    183
    Kidnapped in OC, CA
    Last week we did another Project Lithium traction battery install on a 2005 Toyota Prius
    Matth Torrijos and mikey_t like this.
  9. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,095
    Columbia, SC
    The wire harness/voltage sensor harness is looking pretty original. Do you guys remove it, and the ecu, to inspect the ecu socket and harness plug, clean or replace the busbars? or maybe just install a new harness?
    Looks like the original harness was disconnected from the OEM modules, moved out of the way and is going to be reconnected "as-is" to the new modules....New harnesses are cheap ($65ish?) for the peace of mind they provide.
  10. RightOnTime
    791
    1,660
    183
    Kidnapped in OC, CA
    All of the above which includes using the original harness. From our last talk with our Toyota Parts Rep, you can no longer order the new harness through Toyota So we had to clean each busbar in a solution with our Ultra Sonic Cleaner - which came out Great!
  11. AzusaPrius
    2,258
    952
    black_jmyntrn and RightOnTime like this.
  12. TMR-JWAP
    6,404
    6,095
    Columbia, SC
    I haven't ordered any recently (still have 5 or 6 in the shop), so I'm not up to date on whether or not availability has changed. They're still showing good for now, though.
    The sensor harness:
    82165-47040 Genuine Toyota Wire, Frame (toyotapartsdeal.com)
    The main cable (-):
    G9242-47090 - Toyota Parts Deal
    The short cable (+)
    G9242-47100 - Toyota Parts Deal
    And this is the safety plug cables. It's kind of funny because they have a photo of a steering wheel clock spring, along with the older black and white low-quality drawing of the cable.
    G3830-47050 Genuine Toyota Plug Assy, Electric Vehicle Battery (toyotapartsdeal.com)
    #132 TMR-JWAP, Jun 2, 2023
  13. RightOnTime
    791
    1,660
    183
    Kidnapped in OC, CA
    Thanks! Going to follow up on this good info Hopefully our Parts guy can get them for future work as an option.
  14. RightOnTime
    791
    1,660
    183
    Kidnapped in OC, CA
    IMG_5085.jpg Working this week on rebuilding 5 engines for stock inventory
  15. RightOnTime
    791
    1,660
    183
    Kidnapped in OC, CA
    Prepping this Toyota Prius engine for its new home
    iPhone ?
  16. Matth Torrijos
    Matth Torrijos Active Member
    121
    218
    Poway
    GregC1979 and RightOnTime like this.
  17. AzusaPrius
    2,258
    952
  18. Montgomery
    2,254
    2,244
    Orange County, CA
    GregC1979 likes this.
  19. RightOnTime
    791
    1,660
    183
    Kidnapped in OC, CA
    If anyone happens to live close to our shop in SoCal, you are welcome to stop by if you need OEM Toyota parts to help finish your Headgaket / EGR project. Since we do so many of these we have an ample supply of bolts, gaskets, O rings, clean EGR coolers and intake manifolds.
    https://linktr.ee/hybridpit
    Montgomery, Xterra72, jzchen and 2 others like this.
  20. RightOnTime
    791
    1,660
    183
    Kidnapped in OC, CA
    Just got done with a rebuilt Gen 4 Prius waiting for its new home. We can prep the engine for Gen 3 conversion which includes the minor modifications for plug and play! Temp Harness extender included!
    iPhone ?
