Hybrid Reborn: 2023 Toyota Prius Revealed - 57 MPG, 196 HP
Discussion in 'Gen 5 Prius Main Forum' started by Danny, Nov 16, 2022.
  1. Hammersmith
    Hammersmith Senior Member
    2,315
    2,348
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    A Toyota problem. No LE models were available for the test drives.
    farmecologist likes this.
  2. 3PriusMike
    3,100
    2,419
    Silicon Valley
    Doesn't every car company only provide the higher end trims for initial reviewers to help bias them to liking the car?
    Mike
  3. Tideland Prius
    16,559
    Toyota problem. No LEs were available.
    That's usually for the independent road tests. Usually a media first drive would span the entire range. It's possible with the supply chain issue, they limit it to the top trims (or in this case, top two trims).
  4. farmecologist
    farmecologist Senior Member
    1,958
    1,799
    Southern MN
    Yes...it's all about the upsell, I suppose. (y)
    However, us "MPG enthusiasts" want to see the highest MPG base model before making any decisions...haha. I know it is pretty much just the wheel size difference, but I still want to see some like minded MPG based reviews. All I'm seeing now are reviewers "flooring it" to see what kind od 0-60 time they can get. :rolleyes: WIth that said, it *is* pretty fascinating to see folks interested in 0-60 times when talking about a Prius!
    PebblePrimer likes this.
