Hybrid Replaced: "no Map DVD. Please insert Map DVD"
Discussion in 'Gen 3 Prius Audio and Electronics' started by m_ma_belle, Dec 7, 2025.
  1. m_ma_belle
    m_ma_belle Junior Member
    2010 Prius 3 with approx. 200k miles.
    Just took it to a "hybrid specialist" shop to replace the hybrid battery which went on the fritz. Replaced with a "reconditioned" replacement w/ 3 year warranty.
    Upon pickup (after I paid, of course), I noticed the navigation screen reads "no Map DVD. Please insert Map DVD." The map system hasn't worked in quite a while, but this error message doesn't display unless I would press the "Map" button. Prior to hybrid replacement, the Radio screen would appear upon putting the vehicle into Start mode.
    So, after a very expensive battery replacement I now do not have key components of my car working: no backup camera, no bluetooth, no radio, no satellite radio that I pay a monthly subscription for.
    Things I have tried:
    - air spray in DVD slot which did help the system eject the DVD.
    - Hard reset. Remove 12V ground wire, remove orange shutoff in the trunk, remove large fuse pull, wait 15 minutes, replace everything & restart vehicle.
    - Update DVD to 18.1 purchased on eBay for $30.
    -Scanned for codes at the shop after pointing out the above were not functioning, which previously were functioning before hybrid battery replacement. No codes came up.
    What I cannot try (but shouldn't matter due to hard reset):
    - soft reset. The Trip button on steering wheel doesn't function, so I can't navigate to Trip A screen, to reset the maintenance errors or perform a soft reset.
    In my research, this seems like a security feature. Of course, the shop states "the internet says a lot of things," and "we've never encountered anything like this before."
    They say I can leave my car with them another day to troubleshoot (i.e. hold my car for the day that I depend on so they can say they checked it out, but do nothing), but that if they can't figure it out the only option is to replace the entire nav/radio unit.
    Constructive/helpful info from people with experience in this?
    I know the miles are up there, but I love this car, and having just spent close to $2k to replace the hybrid I prefer to drive the used car I know vs. another one I can afford right now that I do not know.
    #1 m_ma_belle, Dec 7, 2025
  2. John in Vermont
    John in Vermont Junior Member
    50
    22
    Rochester, Vermont
    2018 Prius c
    First of all, you need to relax. There is probably some sort of a software glitch that needs to be diagnosed before anything can be done to solve the problem. Being you don't have the ability to do the diagnosis yourself, you need to take it to a professional. If you don't trust the shop that replaced the battery, take it to someone else.
    Replacing the radio will more than likely not solve the problem, so don't start throwing parts at it without a diagnosis. Doing a reboot by disconnecting the batteries doesn't always solve problems like this, the car needs to be scanned for trouble codes.
    Also, the car is high mileage and fifteen years old you can't expect it to be totally reliable, it will need repairs more frequently.
    52,847
    try a 12 volt negative disconnect for a minute
  4. Brian1954
    Brian1954 Senior Member
    2,675
    1,071
    South Central PA, USA
    The OP already tried that.
    bisco and m_ma_belle like this.
  5. PriusII&C
    PriusII&C Active Member
    432
    147
    San Jose, California
    Is it a Prius or Prius C? I thought the first model year of Prius C in USA is 2012.
    bisco and Brian1954 like this.
  6. m_ma_belle
    I'm relaxed.
    Never tell a woman to relax.
    I didn't say I expected it to be totally reliable at 200k miles, or complain about repairs.
    Did you read my post? This problem was a direct result of the shop replacing the hybrid battery.
    Scanned for codes at the shop on the spot when I pointed out the backup camera, radio, and bluetooth were no longer working. No error codes came up. I will add that to my original post.
    I didn't say I was planning to throw parts at it. I explained the situation clearly for people who have actual experience with this and might be able to help. In fact, all I have paid for was a new nav DVD because the obvious explanation would be that the original one is scratched and couldn't scan after reboot.
  7. m_ma_belle
    you're right, it's a prius 3, typed in error.
  8. bisco
    52,847
    and the wrong forum. you can report your post and ask the mod to move it
  9. Brian1954
    2,675
    1,071
    I already did this.
  10. m_ma_belle
    Oops did I originally post in the wrong forum?
    Whoever reported/moved it - thank you!!
  11. indel
    indel Member
    283
    89
    Northwest Indiana
    Did you try bringing the car back to the shop that replaced the hybrid battery?
  12. Mendel Leisk
    42,343
    How long have you had it? I don't relish being the harbinger but: 3rd gens (2010~2015) are very prone to blow head gasket around those miles.
  13. bisco
    52,847
    now we're in audio and electronics :cool:
    m_ma_belle likes this.
  14. m_ma_belle
    I did this yesterday when I finally had a day that I could be without my car for the day, however I asked in this forum because they stated after working on thousands of Priuses they have never seen this issue.
    I'm posting an update now.
  15. m_ma_belle
    Update 12/11:
    (TL,DR: This morning I drove 2 miles to walk my dog, and when I got back in the car and started to back up all the functions were working again. I'm unable to edit the original post with this info, so here it is.)
    - I visited the dealership service center who said the battery was likely not calibrated, programmed, or possibly a wire was missed, and said I should suggest the shop pay for them to diagnose it for $200.
    - I brought vehicle back into the original shop. They stated they called Toyota service line, who said that both the DVD that came with the vehicle (I was 2nd owner, most likely the original DVD) and the updated version of that DVD that I just purchased, neither were the correct "part number" DVD for my VIN number.. DVD with the right "part number" had been discontinued by Toyota but I found it available on ebay for $66 at the lowest price.
    The shop stated they checked all the wires and work that went into the hybrid battery, and they did not find any issues. They asked me to purchase the correct "part number" DVD to see if that would bypass the screen, and that the Toyota service line stated if the correct part number DVD doesn't do the trick, the whole screen will have to be replaced.
    I ordered that DVD.
    - This morning I drove 2 miles to walk my dog, and when I got back in the car and started to back up all the functions were working again.
    - It has been suggested by a friend who had similar issues with a Honda that it is some kind of a feature where the car has to be driven a certain number of miles after the battery is replaced before full functionality?
    Case closed. Hopefully not just for now, but forever.
    Thanks to everyone for your support and information. As for me, I will be driving around as much as possible with satellite radio turned way up for the foreseeable future.
    #15 m_ma_belle, Dec 11, 2025
  16. indel
    indel Member
    283
    89
    Northwest Indiana
    Usually, disconnecting the 12V battery may result in short term memory loss for the car. Then the car has to relearn all the parameters and some things like radio presets need to be set again by the user. Perhaps there is something similar that also happens when the high voltage battery is disconnected. If no DTCs were set and you are now back to normal, then perhaps relearning has been completed. If not, you will find out soon enough.
  17. m_ma_belle
    Could be. Why doesn't toyota service line, or a shop that has worked on "1000s of priuses" know this? (rhetorical question)
  18. indel
    indel Member
    283
    89
    Northwest Indiana
    What Toyota service line did you call?
  19. bisco
    52,847
    congrats, all the best!
  20. m_ma_belle
    I did not. The shop called yesterday. THey did not specifiy which line, just that there is a Toyota service hotline they called.
    I did however bring it into the dealership & asked a service rep there, who also did not mention anything about this (but was likely not a service technician).
