"Hybrid Sales Stall"
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by massparanoia, Apr 3, 2012.
  1. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    There is no defense. The article is trash, but is published because it follows the WSJ meme.
    As for the NYT, find me a hack job of similar ignorance. Every day.
  2. billnchristy
    billnchristy Active Member
    924
    123
    GA
    2016 Chevy Volt
    toyota says....93.7cu ft interior volume.
    civic....94.6 cu ft.
    I stand corrected sir.
    It is a chunky compact.
    (though Camry is only 102 so its not cavernously larger either)
    Though with cargo (do they consider that interior space?) Prius is barely smaller:
    115.3 Prius
    118.1 Camry
    If they do include trunk then the Prius is in fact a mid sized and a quite efficient one being only 3 cu ft smaller internally than a much larger car.
    BTW did the math, Camry is externally 42.8 cu ft larger than Prius.
  3. Skoorbmax
    Skoorbmax Senior Member
    2,641
    265
    Western NY
    I agree it's a small midsize--for passengers. I have another mid-size sedan and it's much larger for all passengers than the Prius, but its cargo capacity is not necessarily as functional. It has a large trunk, but isn't a hatch back, and the trunk shape of the Prius buys it a lot of interior space. But, it's still larger than a corolla!
  4. billnchristy
    924
    123
    GA
    2016 Chevy Volt
    To show how efficiently the Prius uses space, my Fiesta is only 16cu ft smaller than the Prius (3" shorter l, 1" narrower, .7" shorter height) and has a total capacity of 100.5 cu ft.
    85.1 human space, 15.4 abductee...err...trunk space.
    That 8 cu ft in the passenger space means you can fit human people in the back seat.
    Meaning almost every inch of extra space in the Prius is internal.
  5. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    To all the WSJ loving, love to compare Corolla to Prius people out there, try putting a 58" tall cat tower (I mean 58" tall cat and tower:) in your Corolla ...
    Kitty is going to be awfully mad you can't bring both home :mad:
    I did the math between 2012 Matrix 1.8 auto and '12 Prius Two yes it's $4,315 cost diff, but no SKS, USB, PBS or bluetooth in Matrix.
    If you drive only 6k mi / year and at 10 years, the traction battery poops, well, at $4 avg, gas, will have only made up $3.6k in gas savings (6 cpm diff).
    But if drive 12k mi/yr, will make up cost diff and have almost $3k for battery replacement. Not including extra brake expense for matrix.
    But geez, would you rather drive a matrix around or Prius?
  6. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    We are just getting to the point where lots of 2004 Prius' are running out of the 8 yr hybrid warranty.
    Yes, they sold about 50k of 01 - 03 Prius, but Toyota sold over 50k Prius for 2004 model year alone.
    So, we'll see what happens with hybrid batteries not just in terms of miles, but also age. One the biggest issues with the naysayers is 'how much will the battery cost?'
  7. austingreen
    austingreen Senior Member
    13,714
    4,232
    Austin, TX, USA
    First this comparison in smart money really came as a reprint of analysis from edmunds. These are the same people that put out that a leaf goes 0-60 in 7 seconds, because the guy measuring it did not know how to use his stop watch. Unfoturnately they get a lot of stuff about cars wrong, and other people quote them. The WSJ has excellent journalism and financial analysis. Its editorial page and smart money sections are not part of journalism, they are opinion, and this bad report was quoting some shotty analysis from edmunds.
    Why does it always have to be about the cat:confused: But your analysis is closer to true. Remember these things started with gen I prius and the echo, cars that were much more similar than the prius gen III and corolla.
    Seems like a poor choice if you are only going 6K miles a year. but most that buy the prius drive more:D
    yup.
  8. DeadPhish
    DeadPhish Senior Member
    2,010
    353
    Outer Banks of NC.. Retired to play golf and poker
    Ive always considered the Prius, Jetta and now the Cruze to be `tweeners`.
  9. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,002
    Fort Lee, NJ
    Yes, they do. EPA considers passenger volume and cargo volume as interior volume.
  10. DeadPhish
    2,010
    353
    The battery replacement issue has been proven to be a non-issue now after 14 yrs of experience. Especially since the debut of the Gen 2 there is no reason not to expect the HV battery to last 200K to 300K miles and at least 8-10 yrs.
    But IF it was necessary to replace mine at 250,000 miles or so then I`d only expsct to spend ~$2K or less. I've estimated that Ive saved at least $8K since Day 1 in Nov 2005.
  11. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    Ok, but 20 to 30k or more miles per year is a Lot of driving.
  12. massparanoia
    massparanoia Active Member
    697
    467
    Virginia
    Here are a few past and present examples of NBC's creativity. I'm sure I could find more than a few NYT examples if I looked around.
    NBC issues apology on Zimmerman tape screw-up - Erik Wemple - The Washington Post
    NBC offers on-air apology for GM story 02/10/1993 | Archives | Chron.com - Houston Chronicle
  13. DeadPhish
    2,010
    353
    I hear ya. I've averaged 30000 to 45000 every year since 1990. Boink, it IS a lot of driving. The last 6+ yrs have been in my '05 Prius.
  14. spwolf
    spwolf Senior Member
    3,156
    440
    Eastern Europe
    my friend, why are you spending your valuable time on the article that is actually using bad information (on purpose?) as its main hypothesis?
    With almost 20% of Toyota/Lexus vehicles being sold as full hybrids in March 2012, market for hybrids has never been bigger in the USA.
  15. rebenson
    rebenson Member
    364
    43
    Suburb of Chicago
    I love the "comparably equipped" comparison of Prius and Corolla as well... Have had this discussion many a time...
    I have a 2009 Corolla and a 2010 Prius and did the comparison and listed the differences... I was amazed at the differences myself.
  16. billnchristy
    924
    123
    GA
    2016 Chevy Volt
    You also have to look at what a battery for a gen1 cost new and what they cost now and consider that the Gen II and III will have similar reductions (or greater).
    By the time we need batteries for our GenIIIs the car will have a gas guzzler tax (hopefully).
