Hybrid System Failing?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by rcast1986, Jan 13, 2014.
  1. rcast1986
    rcast1986 Junior Member
    Provo, UT/San Antonio, TX
    So I've had my '05 Prius since 2010. Since that time, I've averaged approximately 44-47 mpg pretty consistently. I've made several cross-country trips with heavy loads full of personal belongings and have still averaged at least 42 mpg. Recently, over the last month, I've noticed a pretty rapid decline in mileage, averaging around 36 mpg. What I've noticed is that the hybrid battery will remain almost fully charged most of the time, not really making use of it to power the vehicle. I've taken the car to the dealership for some recalls, mentioning the issue. Basically, my concerns were pushed aside because the dash wasn't showing any errors. They supposedly checked for codes, but found nothing.
    Well, I'm not in the middle of another cross-country trip (from San Antonio to L.A.), and things have only gotten worse. My car has about half the weight it did on my last 42mpg trip, and before leaving I had an oil change, changed the air filter (it needed it), and had my tires rotated. The spark plugs were changed less than 5k miles ago. I can assure you it is not an engine issue--and I am now getting 31 mpg.
    This is ridiculous. Furthermore, my concerns about the system seen to be somewhat vindicated: the battery has not ONCE, over the last 300 miles, dipped below or risen above the top line of the "blue zone", if you will. It has just stayed there, and when on a hill climb, the readout on the console shows that it will power the car for very brief, infrequent bursts of less than a second before either letting the ICE charge it, or even just do nothing. Basically, the system appears to be favoring this particular area of the battery.
    So what do you think, Prius Nation? Is it the hardware? Battery? Entire hybrid system? Is this a sign of its failure? Or is it a simple matter of software? If there is an issue, why aren't there any warning lights or indicators?
    I'm currently sitting at 92k on the clock, so I can imagine why the dealership isn't eager to help me now. They'd probably just rather the system fail in 8k miles and let me come pay it out of pocket (which I can't do, obviously). So any tips on getting them to cooporate? I'm in the middle of Texas right now at a gas station, so hopefully y'all will have some words of wisdom for me at my next stop!
    Thanks in advance for any help.
  2. Patrick Wong
    18,210
    6,517
    You are right. If there are no warning lights on, then no diagnostic trouble codes are logged. Therefore, from the dealer service department's point of view, nothing is wrong with your car. There really is nothing you can do or say to get around that.
    You haven't mentioned tire inflation pressure. I suggest you check all four tires and inflate to 44/42 psi front/rear.
    Also, if you are still carrying heavy loads in the car, that clearly is not going to help mpg so you need to take a long drive without any excess weight and see what mpg is logged.
    Good luck.
  3. AzWxGuy
    AzWxGuy Weather Guy
    1,078
    556
    Tucson, AZ
    2021 Prius
    Anybody else thinking, drum up the chorus now, that little 12 volt auxiliary battery in the right-rear corner of the trunk? If or when has it been replaced? Maybe 8 years on the factory original? I should have that permalink to the diagnostic procedure memorized by now. Do a search for 12V battery and see if those recommendations don't improve things.
  4. dorunron
    dorunron Senior Member
    3,318
    1,105
    Houston, TX
    It might be any one of several things at this point. I would suggest the OP fill out the questionnaire concerning low mileage and then maybe we might be able to help.
    As Patrick pointed out, no codes, and no lights means the Prius is functioning normally, or at least within specified parameters.
    Here is the questionnaire. Please copy and paste it into your reply and fill in the answers. Then we might be able to assist better.
    - What fuel economy are you getting and how are you determining fuel economy? (trip computer or manual calculations)
    - What fuel economy are you expecting and why?
    - What are the approximate outside air temps?
    - How long are your trips?
    - How much of it is city vs. highway? Roughly what's the average speed in overall and and of each segment? Is there a lot of stop and go driving?
    - What region/state are you in? (if you haven't set your location in your profile)
    - What's the terrain like of your drives? (e.g. flat, gentle hills, steep hills, etc.)
    - Is your oil overfilled? (i.e. above the full mark on the dipstick)
    How old is your 12v battery? What is the voltage reading of your 12v battery after sitting over night? (Method Here) Weird stuff happening? MPGs dropping? Test The Battery | PriusChat
    Have you had your alignment checked? Any pulling or abnormal tire wear?
    - Are you using the factory tires and wheels? If not, please indicate tire make, model and size (e.g. Goodyear Assurance Fuel Max 185/65R15).
    - What are your tire pressures?
    - Make, model, year, engine and transmission of previous car? (e.g. 08 Honda Civic Si 2.0L 4 cylinder, manual transmission) What did you actually get on the same trips/commute? (Please give us actual numbers, not EPA ratings.)
    - How are you trying to drive (e.g. trying to stay in electric only?) and how hard are you braking?
    - Are you "warming up" the ICE (internal combustion engine) by letting it idle after powering on?
    - Are you driving using D or B mode?
    - HVAC settings? Are you using the heater, AC, auto mode, etc.? If using auto, what temp is it set to?
    - If reporting a mileage drop, did anything significant change on your car (e.g. accident, hit a curb or big pothole throwing off alignment, oil change/other maintenance/repairs, changed tires or wheels, etc.) or your commute?
    cwerdna likes this.
  5. uart
    uart Senior Member
    4,220
    1,212
    Australia
    Here's a few things worth checking out.
    1. Check the simple things, your 12V battery health, tire pressures and that your oil isn't overfilled.
    See: Weird stuff happening? MPGs dropping? Test The Battery | PriusChat
    2. Probably a long shot, but some people have had success against various anomalies with a "brain reset". Disconnecting the battery positive for half an hour and then reconnecting.
    3. Check the inverter coolant for circulation. You should be able to see it steadily gurgling away if you look down through the filler hole of the reservoir while it's in ready more.
    See my post (#10) here: maintenance and repair in Anchorage AK | PriusChat
    4. Check the rear battery fan to make sure it's not clogged with dust.
    See my post (#31) here: Fur and dirt causing major battery problems | Page 2 | PriusChat
  6. rcast1986
    UPDATE
    Here is the data from my trip, segmented by stops:
    1st Leg
    31.3 mpg, 277 miles
    2nd Leg
    33.7 mpg, 224 miles
    3rd Leg
    40.1 mpg, 343 miles
    4th Leg
    38.5 mpg, 262 miles
    One interesting thing I noticed was that those large jumps in mileage correlated with parts of the trip that had a lot of traffic compared to that first section. That first leg with the 31 mpg had almost no traffic, and very few moments where I needed to apply the brakes. The others had several instances of braking, more similar to "normal" highway conditions. Speed limit (which I mostly adhered to) ranged from 75 to 80 mph in general, and elevation remained more or less steady, as did the weather.
    38 and 40 mpg is certainly much better than 31, but they're far removed from what I've had on past trips.
    The troublesome part is that, this trip--and especially that first leg out of Texas--is one I have made many times, with loads much heavier (around 2/3's heavier) than what I had this time, and in much hotter weather where I blasted the A/C, and still managed to get 6-15 mpg better than I did this week.
    Ah, yes. I had the tires inflated to 5 PSI over the factory suggestions in the door jam (for some reason the numbers elude me right now).
  7. rcast1986
    I'm starting to wonder if the 12V might be the culprit. I failed to mention in my OP that, when they called to tell me the car was ready, they informed that (a) the cables to the 12V were loose and (b) that it was failing. I thought this was odd since I had just purchased it 18 months prior to replace the old, definitely-failing 12V, and when I went to pick up the vehicle, the service manager couldn't find any record of them suggesting the 12V was dying. So I assumed I had misheard them, and sorta moved on from there.
    I'll check out these suggestions and report back. Thanks for these!
  8. dorunron
    3,318
    1,105
    Houston, TX
    Consider this. In the last month or so the temps here in Texas have dropped considerably. Also the winter gas is now in use.
    Furthermore, Texas recently raised the speed limits and you are driving considerably faster as per your statement above.
    Based on the information given so far, I don't think you have any problems. Sure your traction battery is beginning to show age. But does that mean the system is failing? No, it simply means that your car is not as strong as was in the past. There are many factors that contribute to this.
    75 and 80 MPH with an average load on a Prius could very well contribute to the MPG you are reporting. Maybe a few miles more, but with the cold temps we have been having what you are getting is acceptable.
    Try slowing down, pump the tires up to 42 F, 40 R and block the grill. Remember the Prius has a load limit of 800 lbs. That includes the driver and any passengers.
    Just because the limit is 75 doesn't mean you have to drive that fast. I am still driving 62 to 65 in the 75 zones. I stay in the right hand lane with the other's who are doing the same and let the speed demons pass on the left. I am getting a lot better MPG that way rather than driving 75 to 80. I tried that and saw the MPG drop like a rock.
  9. nh7o
    nh7o Off grid since 1980
    1,686
    340
    Hawaii
    A shorted cell in the 12V battery can cause your issues. If the battery is not able to reach full charge, then the little converter portion of the inverter will work over time to try and charge it. This causes overheating in the inverter and excessive reliance on the ICE.
    What happens when you come to a stop? ICE shuts off promptly? When you are cruising in a hilly area, does the car go in and out of EV mode frequently? My guess is that your ICE is running continuously.
    If you were to run Priidash or Torque and look at the various temperatures in the system, I'm sure the problem would be apparent.
  10. rcast1986
    I spent the first 2 years of owning the car in Utah, with temperatures during winter frequently hitting single digits, and just about every day spent at or near freezing. I consistently maintained upwards of 42 miles per gallon, as recently as 20,000 miles ago. I realize load contributes greatly to mileage, but there's no way the near-perfect 65 degree weather I just drove through out of Texas lowered my results by almost 15 MPG.
    Like I mentioned above, I've made that exact trip multiple times before, in hot (90 degree) weather, A/C blasting, with a load 66% heavier, and with the same 80 MPH speed limit (those have been in effect off of I-10 W for years now; though it might have been considered a "test period" before becoming official a year ago). The variables have only changed in favor of mileage, with the exception being that the car is now, of course, older.
    I have to contend with the statement that the car is simply "older" now, and therefore I can expect a sudden drop in mileage of more than 10 MPG when it has under 100k on the clock. If I'm supposed to just accept this, then what's the point of owning a hybrid, ya know? That just seems silly to me.
  11. fuzzy1
    10,671
    Don't accept it. My last two non-hybrids displayed improved MPG with age (to 235k and 175k miles), though that probably had more to do with the adjustment of the nut behind the wheel than to anything else.
    dorunron likes this.
  12. dorunron
    3,318
    1,105
    Houston, TX
    My point exactly - adjustment of the nut behind the wheel. Thank you for saying that!
  13. dorunron
    3,318
    1,105
    Houston, TX
    I am going to ask the op one more time to please fill out the questionnaire posted above. It would be helpful in more ways than one.
    In another part of the forum it is stated that it is a requirement of users with less than 50 post's when complaining about fuel economy.
    The following is copied directly from the source page where the questionnaire above came from.
    In the interests of being able to more efficiently answer common requests for fuel economy help (e.g. "help, I'm getting only 35 mpg", "I'm very disappointed w/the mileage of my Prius", etc.), please copy and paste the questions below then do your best to answer most of the questions below in your post.
    This is required of users w/less than 50 posts. Many Priuschat members are eager to help give suggestions, tell you that your mileage is normal/abnormal, etc, but often, we don't have enough information and are left guessing, wasting time posting guesses or the same questions/responses, etc.
    Read more: http://priuschat.com/threads/fuel-economy-complaints-queries-please-copy-paste-answer-these-questions-esp-if-youre-new.77075/#ixzz2qdS07ORS
    Follow us: @PriusChat on Twitter | PriusChat on Facebook
  14. rcast1986
    I think I answered most of these in the posts above, but I'll go ahead and fill this bad boy out and see if that helps us.
    Getting between 31 and 36 mpg.
    Expecting 42-46 mpg, because up until the sudden drop two weeks ago, this is what I was consistently getting.
    65-75 during the day, 50-60 at night.
    They vary greatly. From short jaunts to a cross-country road trip, the decrease has been witnessed across all of these, albeit not the same drop.
    Half and half? I was in Texas getting around 35 mpg on pretty open freeway drives, some small hills, around 20 minutes a drive, on average.
    Now I'm in California, so this sees some city driving with a lot of stop-and-go, and equal parts highway, also with some stop-and-go (I avoid rush hour as much as possible)
    TX/CA
    Again, this varies. Texas, and the drive here to California, was pretty damn flat. Now that I'm here, there are, of course, some hilly areas.
    No. I had it changed before the road trip.
    I need to have this checked. I was getting 42 mpg at its worst, and 45 at best, with the OEM battery as it was deteriorating and failing. I replaced it 18 months ago with a battery from the dealership, and noticed a small bump (about 2 mpg) afterwards.
    I do need an alignment. The car pulls to the left pretty hard after having my tires rotated prior to the road trip.
    No. Good
    3-5 psi above factory recommendations.
    2002 Subaru WRX, with the 2.0L turbo. 5-speed manual. Would average around 22-24 on those road trips, 19 city.
    I'll admit I've driven it without much concern for mpg in the past. But since it first dropped to 36 mpg, I've been driving much more conservatively in an attempt to minimize the damage to my tank/wallet.
    I usually sit in the car 30-60 seconds before taking off.
    D. Is driving in B really a thing?
    I rarely use auto: when I'm warm/cold, I like to use it on the last or second lowest power setting until I'm comfortable.
    One last thing I should mention: I freelance for work, so I'm frequently in cities without my car. It's been at my mom's house in Texas, and I came home (and would thus use it regularly) for a week in September, and from halfway through November until currently (when I drove it out here to California). Between the time I was gone, my mom would drive it twice a week (commute to/from the gym and work), and there was also a two week-long period where she drove it every day while her Camry was in the shop. She didn't report anything crazy, and the average mpg when I returned in November was 44 mpg. It was immediately clear to me that the hybrid drive battery was responding differently than normal (as detailed in posts above). The tank was low, so I filled it up later that night when I got back, and my suspicions seemed to be confirmed in the form of the lower mileage I've been speaking about.
    Read more: http://priuschat.com/threads/hybrid-system-failing.136479/#ixzz2qzTMq6Sx
  15. rcast1986
    This nut might be especially nutty, but he's consistently so. And he could definitely, always use an adjustment.
  16. dorunron
    3,318
    1,105
    Houston, TX
    It would help to know what the tires are that are on your Prius now. IE: Size and brand.
    Also it would help if you were to run the test on the MFD and report all three values. The test run's best if you do it after the Prius has set overnight.
    Based on all the info you have provided so far, I think your alignment is part of the problem.
    On the subject of the tires. It is given that the tires have been replaced at one point or another. It might also help when giving the data on the tires (size and brand) if you were to add when these tires were mounted and also if they were new at the time of purchase.
    The Prius is a economical vehicle, but it also will vary in that aspect to a lot of variables. As I stated earlier, I think you have more than one problem that is contributing to your loss. But nailing it down is going to be the trick.
    Thank you for taking the time to fill out the questionnaire.
  17. rcast1986
    Two things I keep struggling with here are (a) how all of these adverse variables somehow came together to simultaneously form a strong negative impact on my mileage at once and (b) how we aren't considering the odd behavior of the hybrid system as given on the display. The system seems to be heavily favoring keeping the battery charged within the top 4 "levels" of the battery, to the point that it will sacrifice great drops in mileage for the sake of keeping it there.
    On previous trips, especially on uphill stretches, the car would deplete the battery to power the electric motor, not at all afraid of letting it dip into the lower "pink" levels of charge in order to maintain as high of an MPG as possible. On an empty stretch of road on the trip here to LA, I took some video of what has now become typical behavior of the hybrid system--not just in 60 seconds or however long it is, but throughout the entirety of the trip. Basically, the lower half (or just over the lower half) is not available for powering the electric motor. It will only dip into this lower half if I am parked, stationary, for a very long period of time. It will no longer fall past this mark whilst driving.
    I believe there were two times, in the 3+ years I've owned the car, that I've witnessed the battery being fully charged, all the way to the very top. Since the drop in mileage and the odd behavior of the hybrid system, this is a daily occurrence. Again, this would be fantastic news if my mileage wasn't currently being obliterated, and I think it is another piece of evidence that suggests something is suddenly amiss with the car.
    I understand there are things that can be done to maximize mileage. I get that there are many, many variables to consider in what is a very fluid, almost abstract concept of MPGs. But for it to happen all at once, corresponding to an odd change in behavior for the way it does and does not charge the battery/power the electric motor, is a sign of something else at play. With a mere 6,000 miles left on the odometer until the battery is no longer covered under warranty, I'm worried that I will lose my car if this isn't addressed soon.
    Video:
    (Watch as the battery will only run the electric motor for the briefest of spurts here and there, and would even prefer to stop altogether than help as I cruise at about 70 miles an hour on a slight incline.)
  18. dorunron
    3,318
    1,105
    Houston, TX
    Watched the video. To me, nothing looks amiss for a typical incline @ 70 MPH.
    I note it was night time. I saw it was 57 outside but have no idea what the climate control was set on.
    I realize you have touched on this in your reply to the questionnaire, but that data does effect MPG.
    It would be nice if you were to post the information requested above concerning the brand, model and size of all four tires and the exact pressures on the front and back when measured while the tires are cold.
    You may be discounting the alignment of your Prius also. It doesn't take much to cause the Prius to suffer in the MPG world and alignments are critical if you want good MPG.
    Also concerning the tires. They do make a BIG difference in how the Prius performs both in handling and MPG. That is why the data is asked for.
    It is possible that the modules in your traction battery are not holding as much charge as they used to when they were new. But until the car actually codes and the red triangle or CEL light comes on, there is no mechanic in the world that is going to tell you there is something wrong with your car. They can speculate, but without a DTC code present the car is operating "normally".
    This has been mentioned before also. The 12 volt battery could be weak. The test is readily available onboard and the technique is above. Still haven't heard what the results are. It only takes a few seconds to run this test first thing in the morning before you set off. Please take the time to run the test and post all three values. The technique is plainly spelled out below.
    DO-IT-YOURSELF TEST PROCEDURE (thanks to jdenenberg):
    - Without brake pedal, press the Power button once and release to enter ACC mode
    - Press and hold the MFD Info button, then turn the headlights on and off three times to enter Maintenance mode; release Info button
    - Press “Menu” (on screen)
    - Press “Display Check”
    - Press “Vehicle Signal Check” - the battery voltage is shown and should be about 12.4 to 12.8 Volts (normal for an unloaded battery)
    - Again without brake pedal, press Power button and release to put a current load on the battery - the voltage should stay above 12.0V (if less than 12.0V the battery is not well, or there is a fault or unusual load somewhere)
    - Press brake pedal and press Power button once to enter "Ready" mode - the battery is now charging at about 14V (if less than 13.6V or more than 14.4 there may be a problem with the charging circuit)
    - Turn car OFF to leave Maintenance mode
    So far with all the data you have provided, it is my opinion that your car needs an alignment and could be running non LRR type tires.
  19. Sarge
    Sarge Senior Member
    1,325
    785
    Milton, Ontario, Canada
    2023 Prius Prime
    XSE Premium
    Sounds like some good advice above.
    Just thought I would add in some comments, as someone who has had the HV battery fail on my 2006 Prius at about 171K miles (well beyond warranty, unfortunately...).
    It happened in May 2013, and the first symptom was that the battery charging and discharging became very erratic. I.e. the battery charge would go from one extreme to the other (full green to 1 bar pink and back), in a matter of 1-2 minutes, all while rolling at consistent speed on flat ground (!). After driving the car 7 years, I definitely recognized the change, but curiously the car was also getting amazing fuel economy (better than usual) at the same time, at least according to the MFD.
    It was about 2 weeks after this behaviour started that the dash suddenly lit up like a Christmas tree, indicating "Problem" across the top of the MFD.
    Fortunately, the Prius is engineered not to strand you, and you will still be mobile, though likely with reduced power. The battery fan will also blow continuously as well. Sometimes the car would drive 'normally', while other times the engine would race and you would have virtually no power, essentially feeling like you are trying to accelerate in 2nd gear from a stop with a manual transmission. I would have to pull over and 'reboot' the car to get out of this mode. Had to do this more frequently with each passing day, until I parked the car and got around with my wife's Kia until I found a solution.
    Anyway, to make a long story short, I solicited three different dealers who only offered a full HV battery replacement ($3K+) as a solution, all claiming Toyota did not provide part numbers for replacing individual cells. I did find an independent guy through re-involt.com here in Toronto, Ontario, who was able to rebuild my battery (4 cells of 28 needed replacement) for less than half the cost, also guaranteeing his work for 1 year, and so far so good, 17K miles later. I would be more than happy to relay his info for anyone in the area. :cool:
    My mechanic did warn me that it is ok to drive a short time in this condition, but that it should be addressed ASAP, as the failing battery cell could overheat and explode, which WOULD cripple the car and kill expensive ECU computers. That's not good.
    In any case, just thought I would share some of my experience here so you will recognize it if your '05 takes a turn for the worse, as the age is getting up there...:unsure:
    Good luck!
  20. fktw
    fktw New Member
    Hi Kevin, unfortunately, I think my battery is dying...currently at the dealers for diagnostics but symptoms seem to point to a dead battery. Could you please send me your contact? Thanks much!
