Hybrid System Failure in 08
Discussion in 'Gen 2 Prius Technical Discussion' started by lmurph07, Jul 8, 2008.
  1. DeadPhish
    DeadPhish Senior Member
    2,010
    353
    Outer Banks of NC.. Retired to play golf and poker
    81,000 miles. I always drive it down til the last bar blinks and then fill it at the first station I come across, if I'm paying attention ( prior post ).
    At that point I almost always put 9.7 to 10.3 gal in it. If I'm not paying attention and drive another 50+ miles...then all hell breaks loose and the nice lady inside gets on my case. At that point after a Triangle of Death Event I end up putting about 11.3-11.5 gal in it.
  2. Winston
    Winston Member
    614
    SF Bay Area, California
    Once again, I find all of you "fill 'er up at two pips, or else" people silly. OTOH, I am suspicious of the OP's statement that they drove 5-7 miles on the blinking pip, before running out of fuel. The Prius should definately go farther than that on a blinking pip.
  3. xsmatt81
    xsmatt81 non-AARP Member
    522
    Vegas
    tthe summer heat is killing my mpg right now.
    anyway just try to keep it full at one pip or so.
    i hope they increase tank capacity in the coming years..to say 13 gal
  4. richard schumacher
    7,686
    1,068
    United States
    Try doing it 10 or 20 times and let us know what happens.
  5. kevinwhite
    kevinwhite Active Member
    333
    200
    Los Gatos Ca
    The OP said 5-7 miles after the "Add Fuel" message. That usually occurs a long while after the pip starts blinking. And means that fuel is really, really low.
    kevin
  6. Genoz World
    Genoz World ZEN-style living
    797
    22
    La Canada
    I DONT GET IT - why can't we fill up, or add fuel when it goes down to 2-3 pips????????????
    WHY?????????????????????
    why all this drama?
  7. warrior
    warrior New Member
    141
    Paso Robles, CA USA
    Refuel: I agee on the last two lines that it is time to gas up!!
  8. Patrick Wong
    18,214
    6,531
    Hi Gene,
    25% of 274 poll respondents admitted to running out of gas:
    http://priuschat.com/forums/prius-main-forum/33751-have-you-run-out-gas-your-prius.html
    21% of 112 respondents wait until the last pip is flashing before they seek to refuel:
    http://priuschat.com/forums/prius-main-forum/45034-when-do-you-refill.html
    I am wondering whether there is a strong correlation between the respondents who ran out of gas, and those who wait until the flashing pip to refuel... :confused:
  9. morpheusx
    morpheusx Professor Chaos
    1,555
    81
    Akron, OH
    I am sure there is a strong co-relation. I now just find it best to fill up once a week on the weekend at my convenience regardless of how many pips are there.
  10. dogfriend
    7,512
    1,191
    Carmichael, CA
    I have never seen the flashing pip. I have never run out of fuel. I think there is a strong correlation between the two events. :yo:
  11. wmveal
    wmveal New Member
    Kansas City
    Sorry U ran out of gas better watch the gas gauge
  12. FredCof
    FredCof New Member
    Houston, TX
    Re: Fuel System Failure in 08
    Just got new '08 Prius, had similar 'out of fuel' problem. My gauge "low fuel level warning light" began to blink, but the manual said "Remaining Fuel Approximately 3.0 Gal", so went on. Made only about 8-9 miles, got nasty red triangle and gas engine shutdown (it is however nice that you can drive a few blocks on electric!).
    Complained to dealer. Their message seemed to be "that's not unusual - just always refuel when down to 'two pips' on the gas gauge".
    Now, from reading this forum I understand that it's "common" for gauge to not drop AT ALL until drive maybe 150 miles (I have that problem), and that it's "normal" that there is a gallon or so of inaccessible fuel in the tank when it runs empty (I had that problem). Sounds like a bad design, but I can live with those.
    And I suppose I can live with never trusting the gauge below "two pips" - but it seems to me the warning light should mean "refuel soon", not "you're dead"!
    Anybody have experience trying to get dealer to correct the problem? Or is it really an uncorrectable design flaw?
  13. ZC1
    ZC1 Junior Prius Owner
    711
    Metro Detroit
    I read the original post to my wife, who says:
    "What does he expect, to run the car without gas?"
    "On what other conventional car would he run it to fumes and expect it to merrily continue on?"
    My wife also agrees it's not funny or proper to apply a thread title such as "Hybrid System Failure" for a problem he created and which could possibly perpetuate a rumor.
    My thoughts are the thread title needs changing to "Disgruntled, untrusting, and disillusioned man forces car to run out of gas. Story at Ten."
    ZC1
  14. PriusSport
    PriusSport senior member
    1,498
    88
    SE PA
    Once you post a thread, you can't modify the title. That's a common problem in chatgroups. Threads often have misleading titles--especially in the political section.
    My suggestion to administrators: make the title modifiable.
  15. pashadc
    pashadc Pasha DC
    Washington, DC
    Yikes - good thing I didn't post my same issue with the "running out of gas". From the responses I'd feel really stupid - lighten up people! Why do we have this forum unless it is to educate and not punish people for asking questions. The same thing happened to me 2 weeks ago on the interstate at midnight. The Add Fuel warning came on and the last pip started flashing and before I could get to the next exit all of the dash lights came on then the car lost a bit of power. Luckily I went onto the shoulder and got it to the gas station at the next exit.
    My question is that with ALL other non-hybrid cars that I've had that have had a low fuel light, when the light first comes on you have some time to safely get to a gas station. With the Prius and all the major technology that is has, I'd think it would give you a bit of time to get safely to a gas station. Why have the Add Fuel" warning if it won't let you get to the gas station.
  16. richard schumacher
    7,686
    1,068
    United States
    Uncorrectable design flaw. The only thing any dealer can honestly do about it is what yours did.
    On what page of the manual does it say there are 3 gallons left when the last pip starts to flash?
  17. bwilson4web
    16,553
    Wierd, I ran out of gas last week and drove on to the next parking lot and over to a shady spot. I parked the car and pulled out my spare gallon container and was on my way to my favorite gas station. I filled up the car and the spare and when I got home, put it back in the car port.
    I ran out of gas to get rid of the last of the ethanol bought on the way back from Hybridfest. In Huntsville, we have straight gas so I prefer to use 'the real deal' and not fiddle with that funny stuff.
  18. steveholtam
    steveholtam Junior Member
    44
    Sacramento, CA
    The average Prius owner that does not visit this site would clearly trust the low fuel beep and flashing pip as a realistic indicator that the time to get fuel is very soon.
    That is the way every other car on the market works, even other Toyotas. Priuschat members need to not forget that most people actually think there car is just a car, and not a passion or hobby like us.
