Hybrid system failure
Discussion in 'Prius c Technical Discussion' started by fermuscolo, Dec 9, 2017.
  1. fermuscolo
    fermuscolo Member
    53
    38
    Really appreciated
    Raytheeagle likes this.
  2. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,094
    Columbia, SC
    That is exactly what I have. And no bug poop.
    #62 TMR-JWAP, Dec 22, 2017
  3. TMR-JWAP
    6,404
    6,094
    Columbia, SC
    It's on the way. USPS priority mail small flat rate box. The package can be tracked at USPS.com using tracking number 9505 5000 0231 7357 0000 79. It said a three day delivery, but also mentioned delivery times could be affected by the availability of delivery vehicles.
  4. fermuscolo
    fermuscolo Member
    53
    38
    Wow man!!! Thanks a lot! you are something!!!!!
    Have a happy holiday!!!
    Raytheeagle and Prodigyplace like this.
  5. WilDavis
    WilDavis Senior Member
    2,493
    2,155
    49
    What codes were being flagged?
    fermuscolo likes this.
  6. Dxta
    Dxta Senior Member
    1,942
    769
    Lagos
    Can this app be configured to read other Toyota hybrid cars?
  7. Dxta
    Dxta Senior Member
    1,942
    769
    Lagos
    This would have led some dealerships to ask you to replace an entire pack, just because of the intermittent voltage problem on the MFD.
    That would have solved the problem, but it would have ended up costing you thousands of dollars in new batteries.
    Thank God, they did the right thing, by referring the car to a Prius pro.
  8. ericbecky
    ericbecky Hybrid Battery Hero
    4,451
    3,359
    Madison, Wisconsin
    Can be used with all kinds if makes and models. It is not Toyota specific.
    fermuscolo, Dxta and Raytheeagle like this.
  9. Dxta
    Dxta Senior Member
    1,942
    769
    Lagos
    Thanks a lot
  10. fermuscolo
    fermuscolo Member
    53
    38
    The code was p0a80.
  11. ericbecky
    4,451
    3,359
    Madison, Wisconsin
    That's a helpful but still kinda generic Hybrid Battery failure code. I'd want to see more data like block voltages. Or delta soc
    Prodigyplace likes this.
  12. fermuscolo
    fermuscolo Member
    53
    38
    Looks if this have the info
    ztanos likes this.
  13. fermuscolo
    fermuscolo Member
    53
    38
    Excel zipped torque log
    #73 fermuscolo, Dec 25, 2017
  14. fermuscolo
    fermuscolo Member
    53
    38
    Removed
    #74 fermuscolo, Dec 25, 2017
  15. fermuscolo
    fermuscolo Member
    53
    38
    Removed
    #75 fermuscolo, Dec 25, 2017
  16. bisco
    52,762
  17. fermuscolo
    fermuscolo Member
    53
    38
    Well. The car shows again the Hybrid failure screen so its time to install the computer
    TMR-JWAP send me. I dont know if I can do it myself but Im doing to look for instructions
  18. fermuscolo
    fermuscolo Member
    53
    38
    Hi. Someone knows where the battery ecu is located. Do I have to take the battery out to change it? Thanks
  19. fermuscolo
    fermuscolo Member
    53
    38
    Feliz año nuevo!! Happy new year!!! Im drunk. I dont care about the fuc. King hybrid system!!
  20. Matt H
    Matt H Active Member
    164
    105
    Okinawa Japan
    2012 Aqua
    On the Aqua/C, no need to remove the battery to get to it. Nothing special needs to be done. Plug and play.
    That said, P0a80 is set when the battery blocks show a difference of 1.2v. Easy to see with a scan tool. Reset the code, and drive the car. If the code sets, you need to look at the "Battery Block Minimum Voltage" and "Battery Block Maximum Voltage" PID's. If there's more than a 1.2V difference, it's most likely something with the battery...
    You can test this with a simple test: On a warm engine with ICE stopped, put the car in reverse, and step on the brake and accelerator at the same time. This will discharge the battery without starting the ICE (it will start in "drive" so use reverse). When the battery SOC gets low enough, the ICE will start, to charge the battery, step off the gas, and just hold the brake. When the ICE stops, step on the accelerator again.
    If you have the proper tool, you can graph the two PID's above, and see the min/max difference. You can also do this by driving using just the battery at full battery-only power bars, and have the engine start/stop, but it's a lot easier to do in reverse.
    If the min/max block voltage is going to exceed 1.2v, it will happen when the ICE stops, and the car goes back to full battery discharge (full throttle in reverse with brakes).
    Lots of other variables to look at to in order to get an idea of battery condition, but if it's bad, this will tell you for sure.
    hope this helps.
