Hybrid system malfunction, p lock, no start
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Sabolscience, Mar 29, 2023.
  1. Sabolscience
    Sabolscience New Member
    Binghamton ny
    Ok. Spent a week or so an hour here and there trying to figure out what's going on. Started when I pulled out of drive. No engine start, check hybrid system notification. Turned around and parked in driveway and put it in park. Shut off and tried to restart. Plock message and check hybrid. Tried all reset methods, confirmed good battery, got to the point where all fuses had power except the 6 I circled. Whatever and wherever the switch or signal to allow power to these fuses is what I'm looking for I believe. Any advice?
    49,490
    you might have to read the trouble codes
  3. PriusCamper
    PriusCamper Senior Member
    11,104
    4,518
    Pacific Northwest, USA
    Here's buyer's guide for an inexpensive device that plugs into your car and connects to your phone via bluetooth: Hybrid battery diagnostic and repair tool for Toyota and Lexus
    Once you have that you can use Dr. Prius app or Car Scanner app or another option to read and clear error codes.
    Come back to this post with those codes and we'll walk you through your repair options.
    Pri3C likes this.
  4. Sabolscience
    Binghamton ny
    Hey everyone. The starting issue was the battery. It tested fine however when a load was put on it apparently dropped a cell and would not allow the engine to engage. With that fixed the issue still remains where the 5 fuses (top most one circled does work) do not have power. Traction control light is on, airbag light on, bo power to stereo, no trunk open power, no dome lights. What the heck controls the power to those 5 fuses!! There has to be an inline something to say wake up...here's the power!
  5. Sabolscience
    Binghamton ny
    Oh and no codes show up on Dr. Prius or torque pro.
