Hybrid System or Traction Battery Failure - Japanese Import
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Shirjeel Agha, Aug 3, 2014.
  1. Shirjeel Agha
    Shirjeel Agha Junior Member
    31
    Lahore, Punjab, Pakistan
    I will definitely keep you and others posted.
    It has three buttons in English starting from left to right:
    PWR, ECO & EV/ HV
    Please elaborate on EV-BOOST. If it means re-charging of EV Battery while driving then affirmative. I have driven around 1200 km over the weekend (in HV) and seldom seen displayed EV range below 1.5 km.
  2. -Rozi-
    -Rozi- Member
    134
    59
    Slovenia, E.U.
    2014 Prius Plug-in
    You're totaly "right" on that! I've been to UK once and it took some time to adopt to driving on the left side. However, after a few days I enjoyed it a lot. Taking a roundabout was a whole lot easier for my eyesight!
    Congratulations on solving this problem and sharing it here! Enjoy your PiP. Good to know that charging a totally depleted high-voltage traction battery using a wall charger does take place without any visual feedback.
    Based on your expertise waking Prius from hybernation needs:
    • Some fuel
    • 12V battery charged or supported externally to power up on-board computers, lights, and accessories.
    • Tractional battery has to have minimal charge to start HSD (i.e. to get "READY"). When the tractional battery is charged enough, HSD starts in EV mode. When charge is low, the ICE is started using MG1 powered by the remaining charge in tractional battery, right? That would explain why HSD wouldn't get READY in your case as tractional battery was too depleted to start ICE.
    Am I getting this right? Now I am confused, how you managed to drive the car for the first few miles in the first place?!
    Shirjeel Agha likes this.
  3. Astolat
    Astolat Member
    229
    73
    Guildford UK
    OK, that's the US buttons; the EU model has EV CITY instead of PWR. But that's intended for driving in regulated low emission zones, which I would guess Pakistan hasn't got round to yet.
    If you've solved your charging problems and had some experience now, the next question is at what speed the car fires up the internal combustion engine (ICE) even though you are in EV mode with range left? I can explain EV Boost after that!
  4. Shirjeel Agha
    31
    I will get back to you on this question later. I am still waiting for my charging cable to arrive which did not ship with the car for some reason. Presently driving in HV mode only.
  5. Shirjeel Agha
    31
    Thanks
    I am not technically savvy to comment but as I understand you are on the mark.
    How I managed to drive 1-2 miles also confuses me. If the traction battery was too low on charge it should have given me the same problem (which I experienced later) when I jump started it. After jump starting, logically the vehicle should have automatically shifted to HV mode with ICE coming on to make up the low charge state but I guess it did not. I remember seeing the EV mode indication on before the vehicle sounded alarm and stopped. May be it was a malfunction since neither EV or HV partitions of the battery had enough juice.
  6. -Rozi-
    -Rozi- Member
    134
    59
    Slovenia, E.U.
    2014 Prius Plug-in
    If anxious, you can charge traction battery without the charging cable using regen braking:
    1. Do some serious downhill driving in HV. Enough to build a mile or two of EV range.
    2. When the displays start showing EV miles left, you will be able to change to EV mode manually (press EV/HV button once).
    3. After a couple of seconds change back to HV (press the EV/HV button again). Changing from EV to HV manually seems to tell the computer to leave the approximate amount of current state-of-charge for later EV-only driving. Driving in manually engaged HV will not deplete the charge much further beyond the SOC at the time of engaging HV.
    4. Repeat the procedure until you build up EV range desired.
    Take note, that this procedure might affect your MPG, as it is probably less efficient to charge traction batery by regen, instead of using a charging cable.
  7. -Rozi-
    -Rozi- Member
    134
    59
    Slovenia, E.U.
    2014 Prius Plug-in
    Probably the SOC measurement is cached in computer memory. Before your computer measured actual SOC it was too late.
    Besides: Please, drop the concept of EV and HV partitions of the traction battery. There is one battery only. With continuous SOC.
    Instead, imagine the picture of the battery when SOC is represented with bars as zoomed in view of the last few % of battery.
  8. CharlesH
    2,797
    1,163
    Roseville, CA
    There is no separate EV and HV partition of the traction battery; it's all one big battery. The control software produces the illusion of two batteries, depending on whether it is in HV or EV mode. You can be in HV mode with significant charge by pressing the EV/HV button, but when the state of charge gets low enough (about 23%), HV mode is forced. But it's all software.
    The Prius Plug-in prototype did have a separate HV and EV battery, and sometimes people come across old web pages discussing this and get confused. But the production model got rid of this.
    #48 CharlesH, Aug 14, 2014
  9. Shirjeel Agha
    31
    Thanks I did that once during my recent visit to a hilly area close to our capital. In any case, my cable is scheduled to arrive in 2-3 days via DHL so not really much anxious.
  10. -Rozi-
    -Rozi- Member
    134
    59
    Slovenia, E.U.
    2014 Prius Plug-in
    Then, you're 2-3 days away of experiencing that undescribable wonderful feeling only plug-in owners know when we plug in our cars. ;)
  11. Shirjeel Agha
    31
    Got it. Thanks
  12. Shirjeel Agha
    31
    Today I received my charging cable from UK (488 + 67). DHL is surely fast since it took only 3 days against my expectation of 4-5.
    The cable is 10 Amp max. I plugged-in the cable and it charged on the default 8 Amp setting. Took around 90 mins (at 220 V) to charge the battery for 21.3 km (13.2 miles) of EV range and thereafter the car stopped charging. Took the car out for a drive and it really felt wonderful but when I started driving the displayed range came down to 18.5 km. I speeded up the car up to 106 km/h (66 mph) and the ICE did not come on. Couldn't try more but when I do I will let you know. Got full 18.5 km of EV range while I drove both light and heavy footed in between.
    GrumpyCabbie and Tracksyde like this.
  13. Astolat
    Astolat Member
    229
    73
    Guildford UK
    Did you turn the fan on, with or without the a/c? If so, that is the reason the EV estimate came down, it just knocks off 10%. Good you got the mileage out of it though.
    That sounds like the EU model is the only one with the reduced EV max speed, and I'm sure it is to keep the emissions at below 50g/km.
  14. Shirjeel Agha
    31
    Yes, I did turn on the AC since it is still hot here (around 37 Celsius). After your post, I kept observing whenever I drove in EV mode. The displayed range drops when the AC is switched on.
  15. bisco
    51,972
    it's actually when you switch the fan on. you can observe it, then turn the fan off and watch it revert back.
  16. Astolat
    Astolat Member
    229
    73
    Guildford UK
    Preferably while parked... I do worry how much of my time is NOT spent looking at the road!
  17. bisco
    51,972
    agreed! yesterday, a bicycle was coming toward me on the other side of the road. an impatient driver decided to pass him on my side of the road just as i was approaching. i do believe if i hadn't been observing the situation and not swerved to the right, it would have been a head on. we're always a moment away from tragedy whilst driving.
    retired4999 likes this.
  18. GregP507
    GregP507 Senior Member
    3,002
    481
    I'm sure someone has developed a set of protocols for storing a car with a hybrid battery for long periods of time. It should be plugged in, at least periodically when in storage. Even in ideal conditions, a battery will eventually discharge itself, even without external current draw, due to internal factors. In less than ideal conditions, it can happen even faster. Based on what I know about rechargeable batteries, my biggest concern about not driving a hybrid for a period of time, would be allowing the battery to become too deeply-discharged to be recharged.
