"Hybrid System Warning" Light
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by yingyang, Sep 16, 2013.
  1. yingyang
    yingyang Junior Member
    Disneyland
    Went to the market, and my 2010 Prius II with 56K miles wont start. Display works with the "Hybrid System Warning" message, but nothing else works. Called AAA, and he said 12V battery is not problem. Got towed to dealer now, and waiting for status now. Scary that this failed & stranded me with no warning.
  2. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    Once the dealer diagnoses the problem, post the DTC's (diagnostic trouble codes) listed on the service report on here. If not listed on the report, ask the service advisor for them.
    If the dealer gives you a costly estimate to repair you may want to let the experts on here help you analyze the codes and give you their recommendation.
    52,891
    hopefully, the triple a guy knows little about 12 volt batteries. all the best!(y)
  4. yingyang
    Disneyland
    Dealer called and says inverter needs to be replaced, and is covered under warranty :) .
    It had multiple codes, and dealer had to call Toyota directly to toubleshoot.
    Says this is a rare case that the inverter failed. Parts come in tomorrow, and offered a loaner car.
    ou812 likes this.
  5. jdcollins5
    5,131
    1,346
    Wilmington, NC
    Good news for you ! Glad to hear Toyota is able to take care of your problem.
    Once you pick up the car and get the service report please post the DTC's, and any sub-codes, listed on the report so the rest of us can see what this unusual failure looks like. It will help the community if we see the same combination of DTC's in the future.
    If none are on the report, since it is covered by warranty, ask the service advisor if he can give you the DTC's.
  6. yingyang
    Disneyland
    Here are the DTC's that were given:
    • DTC P3004-800
    • DTC P3004-801
    • DTC P0AE6-225
    Fix: Replaced Inverter Assembly (Inverter and coolant)
  7. bisco
    52,891
    it's always a good day in disneyland.:)
  8. jdcollins5
    5,131
    1,346
    Wilmington, NC
    Thanks for posting.
    P3004-800 = Power Cable Malfunction (Includes Inverter/Converter)
    P3004-801 = Power Cable Malfunction (Includes Inverter/Converter)
    P0AE6-225 = Hybrid Battery Precharge Contactor Control Circuit High
  9. Umar Ali
    Umar Ali Member
    274
    91
    Dallas, TX
    Good thing it is covered under warrenty and dealer offered loaner car because i know a fellow member here in one of the threads complaining about the dealer needs to keep car in shop for several days to trouble shoot engine knocking but does not agree to loaner car.
  10. The Critic
    The Critic Resident Critic
    3,193
    2,333
    CA
    ROTD - Gen 3 Prius P3004 | Facebook
    According to the Luscious Garage post, they're finding that some P3004 codes are caused by a relay issue. It's interesting that the Inverter can also be the problem.
    sholz and jdcollins5 like this.
  11. orivas53
    orivas53 Junior Member
    cranston ri
    Does any one know what the relay is that can cause the p3004 also.
  12. bisco
    52,891
    according to the link from luscious garage (above) it could be one of the two main hv relays.
