Hybrid Traction Battery not recharging
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by RAG, May 13, 2023.
  1. ChapmanF
    19,055
    Any chance the tow driver might have got the cables backwards one little teensy time?
    Take a look at the fusible link.
  2. RAG
    RAG Junior Member
    PA
    My neighbor who is a AAA guy is also a seasoned car repair person, and I watched him connect the front battery connection but did not see him connect the 12V battery….although I did see the 12.3 reading from the 12V battery ….I’ll try to connect battery charger again.
    #22 RAG, Dec 19, 2023
  3. pasadena_commut
    pasadena_commut Senior Member
    3,071
    956
    Southern California
    12.3V should have been more than enough to start the car, assuming the voltage doesn't collapse when a load is applied.
    You might start by looking for a blown fuse.
  4. RAG
    RAG Junior Member
    PA
    Thanks! I was just going to report my news. It seems like my key fob was and is the problem. I keep the key fob in my purse and it never occurred to me to put it in the key slot (before calling AAA) and neither did the AAA attendant.
    I have replaced the key fob battery but even so I no longer have the keyless entry feature and the car will only start with the key fob in the key slot. Doors will only lock by pressing the key fob. Could this be a fuse problem also? I haven’t checked my manual yet.
  5. pasadena_commut
    3,071
    956
    Southern California
    dolj and Brian1954 like this.
