hybrid vs. Hummer NOx emissions PDF
Discussion in 'The File Library' started by cwerdna, Jun 26, 2007.
  1. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
  2. tripp
    tripp Which it's a 'ybrid, ain't it?
    4,717
    79
    Denver, CO
    Ha! I'd like to see 45 people carpooling in a Hummer. That's an H2 I assume. Wow, a Hummer produces 45 times more NOx than a Prius. Madness...
  3. Bill Merchant
    Bill Merchant absit invidia
    4,096
    81
    Nuthin' dummer than a _________.
  4. TonyPSchaefer
    14,816
    2,497
    66
    Far-North Chicagoland
    BUMMER
    DUMMER
  5. SureValla
    SureValla Member
    590
    Shelton, CT
    <div class='quotetop'>QUOTE(tripp @ Jun 26 2007, 04:40 PM) [snapback]468494[/snapback]</div>
    well said madness indeed
    just what were the engineers that designed that thinking i cant even imagine
  6. tripp
    4,717
    79
    Denver, CO
    <div class='quotetop'>QUOTE(SureValla @ Jul 18 2007, 07:36 PM) [snapback]481333[/snapback]</div>
    ROI, baby. ROI.
  7. FL_Prius_Driver
    FL_Prius_Driver Senior Member
    4,319
    1,527
    Tampa Bay
    I
    <div class='quotetop'>QUOTE(SureValla @ Jul 18 2007, 09:36 PM) [snapback]481333[/snapback]</div>
    I know what they were thinking. "If I don't engineer what the bosses mandated, I will get fired."
  8. zenMachine
    zenMachine Just another Onionhead
    3,355
    300
    Dumb and Hummer?
  9. MaxLegroom
    MaxLegroom Junior Member
    Newport News, VA
    The dumber part of Hummer has to deal with the fact that initially, AM General was selling but a few hundred civilian Hummers a year, GM saw this and decided they could make a 100k a year business out of that. One comment I read somewhere (Car and Driver perhaps) stated that they were glad that GM didn't take a similar look at Avanti.
    As a former Army mechanic, I have little respect for those who buy Hummer H1s. They may be formidable off-road vehicles, but used on highways they tended to break down a lot as they were not meant for such speeds. That means I replaced a bunch of engines.
  10. Godiva
    Godiva AmeriKan Citizen
    10,339
    What do they care. Isn't the Hummer exempt from every regulation there is? Including taxes?
  11. rfruth
    rfruth Member
    394
    Houston, Tx
  12. HummerOwner
    HummerOwner New Member
    Wisconsin
    I own a Hummer and Prius. Now what?
  13. F8L
    19,011
    4,080
    50
    Grass Valley, CA.
    I'd say you're just as confused as a christian biochemist.... You can't see reality even when it stares you in the face.
  14. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    944
    118
    Los Angeles Foothills
    Are they not the folks that brought us Brandy, and those other fine spirits!!
    73 de Pat KK6PD
  15. qbee42
    qbee42 My other car is a boat
    18,058
    3,073
    Northern Michigan
    Do you carry your Prius in davits behind the Hummer? It would make a good tender for getting around parking lots. :D
    Tom
  16. F8L
    19,011
    4,080
    50
    Grass Valley, CA.
    Of course they are. It takes a lot of alcohol to partition your mind in such a way. :D
  17. miscrms
    miscrms Plug Envious Member
    2,076
    523
    Phoenix, AZ
    You'd have to get 56 people into an '06 VW TDI Wagon, or 88 into an '85 Mercedes 300d even if it is running WVO :eek:
    Rob
  18. HummerOwner
    Wisconsin
    Actually, they both have a purpose.
  19. TimBikes
    TimBikes New Member
    2,492
    245
    WA
    True - presumably you do off-roading in the Hummer...
    My only problem with the Hummer is when people use them as their daily vehicle. They suck up a lot of gas and their large size endangers other vehicles. This can be said of many large vehicles though, particularly the super-jacked up trucks that are so deadly to smaller car drivers. Anyway, the Hummer is by no means the only vehicle like this - probably just more easily noticed.
  20. tripp
    4,717
    79
    Denver, CO
    Tim, I wonder if you could bring suit against someone if they killed somebody with their jacked-up truck. Seems like reckless endangerment or involuntary manslaughter straight away as there's absolutely no reason for those lift kits. They just make the vehicle more dangerous to the operator and others on the road.
