hybrid vs used compact car
Discussion in 'Prius c Main Forum' started by happymiwa, Apr 8, 2012.
  1. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    If people didn't buy new cars; there
    would be no used cars. Also car companies
    can not make "Used" cars. The need
    customes to buy there new cars to
    finance research and developement of
    even better cars.
    Look at the Prius when it first came out, look in
    a little over 10 years how it advanced.....
  2. Mr Incredible
    Mr Incredible Chance favors the prepared mind.
    955
    506
    Neb
    My advice is to not incur debt. If I could I would go back and kick my young buttinski for doing just that. Bite the bullet and buy a used car, learn to do your own maintenance, drive your cheap car for a while, and save your money.
    I just sold my 1989 CRX for more than I paid for it 4 years ago. Now I'm in a position to buy this new Prius C. And I can park it next to all my other paid off hot rods,trucks, and motorcycles.
    Do right by yourself...be smart. Pay your dues and enjoy it without worry when the time is right. Oh, and if you have four grand for a car,don't forget tax and tags. And whatever else thecar may need to start out with.
  3. Tideland Prius
    16,681
    Financially, I would lean towards used but it really depends on your situation and first of all, you need to know what your budget is. That is important. Factor in insurance, fuel and maintenance cost for both new and used cars. Play with the "build your car" section and see if it's worth dropping all of the $4k as downpayment or part of it.
    With a used car, I would get something newer (or as new as possible, say around 2005 or newer, give or take a year). The reason is mostly for safety. There have been big strides made over the last decade in active and passive safety (electronic aids like traction control and stability control have made their way down to smaller cars and more airbags are being installed). Our 2002 Camry XLE had 6 airbags but only ABS w/ EBD. Traction control, stability control and Brake Assist were limited to the XLE V6 at that time but soon made its way down by 2005 (midlife update) as an example.
    The thing about a hybrid is that you pay upfront for the benefit of low ownership cost (short term pain, long term gain). Most people can't see past 1 year, financially so they try to justify that you won't save anything or it will take a ridiculously long time to get any money back (if that was the case, we'd all be riding scooters to work). They're probably the same people that scare you into thinking the battery needs replacing every 2 years (it doesn't. The warranty is for 8 years/100,000 miles and plenty of Prius cabs have done over 350,000 miles without issue with the hybrid powertrain).
  4. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    I say buy used for now. No offense to Toyota, but the c model did just come out and there may be a couple tweaks needed or coming in a couple years. ... For example, the 3rd gen Prius, 2010 was refreshed for model year 2012 and gained a new intake manifold and rear engine mount, freshened front grill and other things.
    I think it's good to get a new edition car in about its 3rd model year when some of the kinks worked out. But, some people like the first cut of a brand new thing and that's ok too. Toyota's kinks are usually pretty minor.
  5. t_in_the_front
    t_in_the_front Junior Member
    Bay Area
    I don't envy you. Read ttac.com for used car auction news by Steven Lang. Prices are double what the car is worth due to low supply. Cash for clunkers, anyone? Pria cost too much new or used for a recent grad. You didn't say how much driving you have to do or if you are in a job search. Moving close to your job may eliminate the need to drive. Then you can pay yourself first.
  6. happymiwa
    happymiwa New Member
    26
    chicago
    I
    thanks for all the advice!!
    a lot more to think around...
    here's some more details:
    the insurance is giving me 4k for my total'd car and is also going to pay for the title/tax fees.
    I am currently employed, my commute to work isn't super long... but I do drive all over the city.
    after reading all the advice, I am leaning toward a used car... tho in my inital used car search, a lot of the newer models (2004+) are well above the 10k mark-- which makes me wonder if I should just spring for a new car?
    I managed to boil down a prius c to about 18k then subtract the taxes and fees... is it still worth it?
    thanks everyone! :)
  7. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    If you are asking for help with arithmetic, you have to provide numbers.
    Annual mileage:
    New car OTD cost:
    Used car OTD cost:
    Insurance cost delta:
  8. B. Roberts
    B. Roberts Hypah Milah! Ayuh.
    691
    212
    used to be "Glacial" Maine and now FL
    Used, buy used. Until you are more settled and have a good income, buy used. You have $4,000 so if you found a gently used Gen II Prius, you could still get 50 MPG and probably only have to take a $4-5K loan. Prius have no problem going 200,000+ miles with little in the way of maintenance issues. You can check them out across the whole USA on cargurus.com
    Plenty of Corollas (super reliable), Matrix and Vibes (Vibe= Matrix, all Corolla based) out there for fairly inexpensive admission. If you buy one of those with a manual transmission, you can get upper 30s to near 40 MPG. Price of those could be close to that $4K that you have.
    So, you could buy a reliable used Prius for less than half the price of a new c or a Corolla for about a third the price of a c, depending on the year. Doing that will allow more of your money to go into the bank, until you have enought to buy a c or something like it in short time. Just don 't go into deep debt, ever. Too many people get into financial trouble that way.
    Good luck!
  9. The Critic
    The Critic Resident Critic
    3,193
    2,333
    CA
    Honestly, if you do not drive much, the gas savings between a Prius and most 25-30 mpg vehicles does not amount to much money anyway.
    You may as well find an inexpensive, relatively fuel efficient used car and not get too caught up with finding the most efficient vehicle.
    There are lots of relatively fuel-efficient, fun and reliable vehicles for under 10k.
  10. Chino510
    Chino510 Junior Member
    Oakland, Ca
    I don't think I will ever finance a used car again. Even the most reliable brands (Honda, Toyota) are not what they used to be. My 2006 civic Si with 46k is getting a new transmission right now from the dealer good thing I bought it as a certified used vehicle and the warranty is covering it. My opinion buy a used car with your $4000 or an affordable new car. I wouldn't go in between... but that's just me.
  11. LizKauai
    LizKauai First PriusC3 owner on Kauai!
    70
    Kauai
    Well, when it comes to a car, I depend on it. Don't wanna spend time in the repair shop. Been there done that when I was younger.
    I'm a cash and carry person except with my home mortgage and my car - which I purchased with the proceeds of my 2006 Prius (after 105K miles) and a home equity loan for the balance.
    That means the interest on the car loan is deductible and the monthly payments are very low and if I can pay it off sooner... the better.
    There's always a way to work out what one needs. The best part- 61 mpg and no buyer's remorse.
  12. SageBrush
    11,627
    2,533
    Southwest Colorado
    i changed your quote a bit.
    How much HELOC interest can I deduct?
    To put it simply: If your HELOC was used to improve your home, you may deduct interest on lines up to $1 million ($500,000 married filing separately). If your HELOC used for other purposes, you may deduct interest on lines up to $100,000 ($50,000 married filing separately).
  13. JLee81
    JLee81 Junior Member
    56
    Maryland
    When I was 21 (2002) I purchased a 2003 Toyota Matrix. After having several used cars I decided it was best for me to buy a new car. My reasoning behind it was that I got sick of having to repair my used vehicles constantly and wanted to buy something that I could just drive. Not having to worry about breaking down or wondering what would give out next was well worth the five years of car payments. Used cars are always a gamble since you don't know how well it was taken care of or how it was driven.
    I planned on keeping the Matrix until it fell apart but unfortunately it met an untimely death when I got hit head on, 5 payments before it was paid off. If it wasn't for that I would still be driving it today. Fortunately most people never have to deal with a total loss and ending up back at square one.
    Depreciation is something that you cannot avoid unless you plan on walking or taking public transportation for the rest of your life. A car may not be an "investment" when it comes to money but if you buy a new car and take good care of it you are making a great "investment" for reliable transportation for the future.
    I bought my C with the intent on keeping so I really don't care how much it is "worth" when it's paid off. You will more than get your money's worth if you buy a car and maintain it well and keep it until it is no longer reliable. I am spending less than half of what I was on gas so even though my payment is $273 and my insurance is $106 a month I am only paying about $190 more per month than I was before (My insurance on my previous car was $66). Even after its paid off I should easily get another 10-15 years or more out of it so that initial investment would be well worth it.
    If you don't have a car or at least a fairly reliable one I would do as others have suggested and buy a used car until you can afford the car payment. If you drive a lot of miles and the potential savings would offset a significant portion of the payment I would at least consider buying a new Prius but only if you plan on keeping the car for the long haul.
  14. ataylorracing
    ataylorracing ataylorracing
    171
    29
    Fishers, IN
    If you can drive a stick I STRONGLY suggest a used Neon 5 speed. The 98s were rated at 41 but only got that after mods. My 95 was rated at 38 but gets 46. The way to obtain this kind of gas mileage is:
    Slightly larger TB from one with an automatic
    CAI
    bigger cat
    rear muffler replaced with the cheapest generic one you can get for a Mustang or Camaro V8
    manual steering rack
    On my 98 I got 41 best with all of the above mods except steering rack.
    My 96 Geo Metro 3 banger was rated at 49 but got 60.1 by removing 140 lbs, to include lighter rims, aero mods by the way of headlight covers and a grill block.
    Both cars will likely need work. On the Geo you must look at the sub frame rusting out around the axles. The Neons are prone to headgasket problems and water pump troubles. Once repaired with quality parts you can drill a 1/8th inch whole in the outside edge of the thermostat so that coolant can seep past the closed part and not cause a thermal shock between the alloy head and iron block. My 95 had the headgasket and water pump replaced by the owner before it hit 80,000 miles and the car is now nearing 180,000 mile. BUT....the Prius will help pay for itself with its gas savings. The wife did not WANT a Geo or Neon...the new or used Focus would take longer in gas savings to pay for themselves, so the Prius was the choice. I REALLY wanted to buy American, but none had the mpgs to pay for themselves. Nearly all of the wifes driving is in town.
  15. j_benj
    j_benj Prius C Fan
    125
    Jersey
    side note, don't forget that Toyota gives you a free two year Toyota Care contract with a Prius C. that means ZERO maintenance costs for 24 months including free roadside assistance. a used car has no such guarantee, especially I'd you're buying one from a private party.
    like my grandfather used to say, "buying a used car is buying someone else's headache". you might get lucky, but it's always risky.
