Hydrogen station explodes
Discussion in 'Fuel Cell Vehicles' started by fotomoto, Jun 11, 2019.
  1. bisco
    52,776
    noonm likes this.
  2. Trollbait
    12,806
    I think it is just aesthetic paneling to cyclone fencing to hide the equipment.
  3. hill
    9,014
    #23 hill, Jun 12, 2019
  4. Trollbait
    12,806
    Or not. The explosion was at a production plant. We use hydrogen for other things besides expensive Camries.
  5. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    That's what I'm thinking; just a (weak) cosmetic barrier. Maybe it's just temporary till a more permanent (explosion proof HAH!) and better aesthetic design could be built. (?)
  6. Trollbait
    12,806
    Temporary as in, "this things are expensive, and netting little profits, so let's put up the cheapest thing to hide the ugly grey equipment," then yes.
  7. fotomoto
    5,639
    3,815
    So. Texas
    LOL.
    I'm thinking, "Norway has like real winters; shouldn't all this expensive stuff be INSIDE a building?" I guess that would really blow the construction budget. (pun intended)
  8. Trollbait
    12,806
    There are some aerial photos.
    Looks like it is pre-fab, with the delicate stuff build into shipping containers.
    I'm guessing local codes would require venting of some kind. The safety factor of hydrogen floating away doesn't apply in an enclosed space.
    Robert Holt likes this.
  9. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
    We used a lot of H2 inside lab buildings no probs but much ventilation and big spaces, tall ceilings, and probably some way to detect flow rate spikes...not sure.
    California probably has a number of H2 plants but sounds like only one was selected to fuel the few FCV vehicles they have. Sounds like the truck loading rack had a problem. Again it is a little hard to comprehend as H2 has been loaded onto trucks probably 100-years now, buit I do not know if they are trying some new methods or whatever.
    #29 wjtracy, Jun 12, 2019
  10. wjtracy
    11,374
    3,609
    Northern VA (NoVA)
    Here is the Norway H2 company Nel ASA...apparently suppliers of renewable source H2.
    I am not aware of Nel ASA like say for example Lurgi who I think probably has a robust H2 filling station offering.
    Nel ASA - Wikipedia
  11. noonm
    noonm Senior Member
    575
    595
    2018 Prius Prime
    Right?
    But then again its no more irrational that people who say electric cars are too dangerous after a Tesla fire while happily driving a vehicle full of a highly flammable and explosive liquid fuel.
    Trollbait and bisco like this.
  12. Trollbait
    12,806
    A commenter to the Jalopnik article on this posted these.
    How Not To Do It: Hydrogen Gas Mixtures | In the Pipeline
    That was once a micro lab. Hydrogen is used to scavenge oxygen in anaerobic chambers. Well, some ended up with oxygen in a place it shouldn't be, and four people were injured, with at least one sent to the hospital.
    This seems to a be a case of poor training, and hydrogen cars and public stations should have a higher degree of idiot proofing, but hydrogen is flammable and explosive over a wide range of concentrations in air, and doesn't take much to ignite.
    These are lessons in why you should never defeat pressure relief systems.
    How Not to Do It: Liquid Nitrogen Tanks | In the Pipeline
    How Not to Do It: Liquid Oxygen Cylinders | In the Pipeline
    The top one was at an estimated 1200psi.
  13. wjtracy
    11,374
    3,609
    Northern VA (NoVA)
    Yes there are potential hazards that have to be properly addressed
  14. Trollbait
    12,806
    wjtracy likes this.
  15. wjtracy
    11,374
    3,609
    Northern VA (NoVA)
    Good, at least we are getting some information now.
    I also wonder why the H2 was allowed to acculmate (not vented properly?) and why they did not find this leak in pressure testing. It also sounds like some kind of unique design not used by USA, others. I have to guess the more reputable H2 filling station design vendors might be able to critique the Norway design.
    Now if Air Products would kindly tell what happened in Ca., that would help too.
  16. Leadfoot J. McCoalroller
    8,269
    7,774
    Pennsylvania
    2018 Prius c
    One detail I caught somewhere about the European explosion was that the pressure wave was enough to set off the airbags in some cars passing by at the time of the event. I hadn't ever thought about that before. A little scary all by itself.
  17. wjtracy
    11,374
    3,609
    Northern VA (NoVA)
    Anytime you have a explosive mixture of air and any flammable gas or vapor (including gasoline vapor inside your pistons) -- if ignited -- you get an extremely powerful explosion technically known as a "detonation". Detonation implies shock waves etc. So this is why air/vapor mixtures can be so hazardous. And ignition source can just be static electricity. Explosion-proof equipment is equipment which does not accidentally iginite gas mixes, and is another question for Norway.
    To demonstate this, you could fill one balloon with methane and another balloon with methane/air mixture. Then ignite those ballons, and you will see the methane/air explosion is much more rapid and powerful.
    Even dust like grain elevator dust in air can detonate.
    #37 wjtracy, Jun 30, 2019
  18. Trollbait
    12,806
    Hydrogen can get explosive at a low concentration in the air, so venting alone may not be enough to prevent an accident. Safety measures aren't guarantees. Still have plenty of fires and explosions with gasoline and natural gas.
    Parts can fail after passing testing. Then hydrogen can act like a halogen and degrade materials.
    I heard the cars were Teslas.
  19. wjtracy
    11,374
    3,609
    Northern VA (NoVA)
    Yes there are potential hazards that have to be properly addressed...if you are using correct materials of construction/maintenance for H2, there should not be problem with unexpected degradation of materials.
  20. drash
    drash Senior Member
    2,598
    1,338
    Upstate NY
    XLE AWD-e
    Because it’s hydrogen everybody is getting all riled up. Between 2014 and 2016, FEMA estimated 171,500 vehicular (>83% were passenger vehicles) fires occured (https://www.usfa.fema.gov/downloads/pdf/statistics/v19i2.pdf) that caused 345 deaths and $1.1B in damages. About 5,000 gas station fires happen per year according to National Fire Protection Association.
    Unsupervised!
