hydrolock
Discussion in 'Gen 2 Prius Technical Discussion' started by chronon, Mar 11, 2013.
  1. Britprius
    Britprius Senior Member
    5,194
    1,922
    Herefordshire England
    The bent con rod will be very obvious, but check the bottom edge of the bore where the rod has likely hit it small chipping is ok since the rings do not get down that far, but a crack is really a scrap engine>
    John (Britprius)
    chronon likes this.
  2. 3prongpaul
    3prongpaul Hybrid Shop Owner, worked on 100's of Prius's
    956
    735
    Boulder Hybids, Boulder, CO
    In the long run I still think it's easier/cheaper to just change out the entire engine. I know one Prius owner who changed a rod with engine in the car then found other problems...so he had to change out the entire engine anyway. He regretted not swapping the engine in the first place so think through your options carefully.
    chronon likes this.
  3. Britprius
    5,194
    1,922
    Paul I'm inclined to agree with you, but just pointing out the options. A look at the bottom of the engine would only take 1/2 hr.
    John (Britprius)
    chronon likes this.
  4. jdenenberg
    jdenenberg EE Professor
    3,960
    1,956
    Trumbull, CT
    2020 Prius
    LE AWD-e
    If you are in central FL, Take the Prius to Mellor's as they have been good to other Prius owners.
    mellor's automotive
    JeffD
    chronon likes this.
  5. chronon
    chronon Active Member
    601
    106
    here and there aint be in frozen wasteland no mo..
    thanks for the tip JD , Melbourne is about 1.5 hrs away though ...
    west melbourne, fl 32904
  6. chronon
    601
    106
    this seems to be the 'next best thing' to taking an x-ray of the engine ....
  7. chronon
    601
    106
    i recall that my dad, a metalurgist, had this black light and this fosforescent dye/powder (dye penatrent) that could be applied to an engine block or metal chunk to test /see any hairline cracks that may exist... perhaps that is something else I can look at after a visual inpsection of the bottom crank area ...
  8. chronon
    601
    106
    in looking up about the oil pan i found this procedure saying REMOVE THE ENGINE before removing the oil pan -- which wont be 30 min !!!!
    HowToRepairGuide: (remove engine prior) HowToRepairGuide.com: How to Replace Oil Pan on Toyota Prius?
    Autozone : (remove engine prior) | Repair Guides | Engine Mechanical Components | Oil Pan | AutoZone.com
    Also, looking at the pictures here : Replaced Oil Pan Gasket | PriusChat It doesnt actually look like complete exposure for visuals of the crank/connecting rods with this 04 pan removed ...
  9. chronon
    601
    106
    as an aside : what happens running 1 gallon of biodeisel into the prius ..
    excellent views of under the engine and pistons (this is a gen 1 (2001)
  10. chronon
    601
    106
    so a OBDII reader or ELM323 isn't going to do it ?
  11. jdenenberg
    3,960
    1,956
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Torque Pro (Android) or Pridash (MS Windows) can with a GOOD ELM323 Bluetooth OBDII dongle.
    JeffD
    chronon likes this.
  12. chronon
    601
    106
    i only have the elm323 USB connection (no Blutooth) -- would scanmaster do it ?
  13. jdenenberg
    3,960
    1,956
    Trumbull, CT
    2020 Prius
    LE AWD-e
    ScanMaster is a generic OBDII Android app. Download the free version of Torque and see if it functions for generic codes. If it does, pay $4.95 for Torque Pro to get access to Prius specific codes.
    JeffD
    [email protected] and chronon like this.
  14. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    just as an odd note.... the intake manifold has to be spotless in order for the car to work. in the event (unrelated in a way) that your oil is overfilled, the tiny amounts get into the intake through the emissions recovery lines and then the loss of pressure registered on those lines causes the car to not even try running the engine. back to my odd point... make sure those lines are clean and make sure the intake is clean. blow the lines out with air (disconnect and clean then reconnect)
    even if the water didn't hit the cylinders, the water being in the intake caused the emission recovery system to flip out because it loss pressure due to air no longer moving.
    or it's something worse. (my apologies if i didn't read any updates, i'm about to run out and do errands and saw this post so i wanted to mention that odd bit)
    chronon likes this.
  15. chronon
    601
    106
    well i dont have android or smart fone 4 that matter so .. I dont think it applies .. either a win , Mac or linux laptop ...
  16. chronon
    601
    106
    Yeah, finike. In fact the water did go to the oil resoirvor ... as I noticed an 'above full' on the dipstick (that would be me for allowing a gravity siphon to occurr !) -- I have drained all the oil , I am in the process of removing the pan, the pan gasket is really on there with what looks like permaflex silicone .. and 11x 10mm bolts .. (which i need to look the torque up for future re-assembly)- I think i need to use the metal spatula - prob. better than screwdrivers....
  17. jdenenberg
    3,960
    1,956
    Trumbull, CT
    2020 Prius
    LE AWD-e
    chronon likes this.
  18. chronon
    601
    106
  19. Lavalamp
    Lavalamp Junior Member
    34
    Tallahassee, FL
    Google the name of the dll and download it to the folder where the setup.exe is. If you're lucky, that'll work. Otherwise you might have to put the dll file elsewhere. And worst case you'll need soemething more than a dll.
    chronon likes this.
  20. chronon
    601
    106
    AND --- .. there are TWO oil pans .. the #1 is the lower one , which doesnt require engine removal but also dosent expose much of the bottom of the engine .. AND it requires a special tool Image Search Results for SST 09032-00100 for removal of pan1 .. well we'll see how far I get with the metal spatula .... ;(
