Hymotion PHEV, LED off, Not Charging, Not Assisting
Discussion in 'Prius PHEV Plug-In Modifications' started by mchase, Jun 18, 2018.
  1. mchase
    mchase Junior Member
    Santa Rosa
    I recently bought a 2009 Prius with low miles and a Hymotion PHEV Battery. The Hymotion LED does not light or flicker when I turn the switch on. I do not see the tail lights turn on when I plug the car in. I do not see a display flicker of the battery charging indicator when driving. So obviously the Hymotion system is not working (mpg is not out as high as I would expect with a working system) or charging. The fuse on the battery unit appears to be pressed in the on position.
    I would like to try trouble shooting the system. Where is a good place to start?
    Any suggestion?
    Thank you,
    mchase
