Hymotion without battery?
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Patrick Dubuc, Jan 16, 2017.
Tags:
  1. Patrick Dubuc
    Patrick Dubuc Junior Member
    quebec
    Hi everyone,
    I just bought a Hymotion L5 and I will install the harness at my home. I plan to drive to a friend garage after I have installed the harness, is it possible? Is all connections of the harness (CAN, etc) cut for the harness will prevent the car to work normally. Summary, for those who got a dead battery, what happent if you unplug the Hymotion L5, to get less weight, is the car can drive?
    Thanks
    Patrick
  2. ericbecky
    ericbecky Hybrid Battery Hero
    4,449
    3,354
    Madison, Wisconsin
    The system should come with a bypass plug.
    If not, you'll need to build one.
  3. Patrick Dubuc
    quebec
    Ok, thanks for this quick reply. Is there a schematic plan for it. (I think I can figure it out, but it will be faster)
    Patrick
  4. Patrick Dubuc
    quebec
    As I see, I only have to connect V1 pin 9 to 12 and pin 10 to 11. But what about the cutted p11 pin 6 (start button interlock), is there something to do with it?
    Patrick
  5. ericbecky
    4,449
    3,354
    Madison, Wisconsin
    Well you can likely drive without the system in place.
    So you are building your own wire harness for it?
  6. Patrick Dubuc
    quebec
    No I will get a used harness remove from a used car. I recently bought a used refurbished pack with 4.55 kW from empty. What do you think of the health of the battery? The pack was supposed to be balanced one years ago. I will maybe rebalance it before install it in the car (with the pdf share here on priuschat).
    I still don't know what to do with the V1 pin 13 or P11 pin 6.
    Patrick
  7. ericbecky
    4,449
    3,354
    Madison, Wisconsin
    If you get the harness from the car it will come with the bypass plug.
    So the car did not have a pack? And you bought a pack from... where?
  8. Patrick Dubuc
    quebec
    Exactly, my prius 2008 doesn't have a pack, I'm gonna convert it to plugin with a used battery hymotion pack and a used harness. Here in quebec, it's cold and I got a engine heater plus a buddy car heater. I will also add a 12V charger for aux battery.
    Here is where I got it
    ebay "Hymotion-Plug-In-Hybrid-Kit" #261762230374
    There are somes availables.
  9. Patrick Dubuc
    quebec
    I have found the answer... in the Hymotion service manual. There is a photo of the bypass plug (added here). So I have to connect V1 pin 13 with V1 pin 8. The Start button interlock should be grounded.
  10. ericbecky
    4,449
    3,354
    Madison, Wisconsin
    You are one of the brave few to purchase an orphaned product. But it sounds like you gave the right frame of mind about it.
    You'll enjoy the system while it works.
    Start saving now for any future repairs. That way you'll be ready and not caught off guard.
    Enjoy.
  11. Patrick Dubuc
    quebec
    Since few weeks, the pack work well! Very happy about it, my milage goes from 6.5l/100km to 4.5l/100km. Now weather going worst, february ... -15 celcius... very cold...
  12. Robertojax
    Robertojax New Member
    Did this work? I'm hoping to find instructions on removing Hymotion battery but when I disconnected the
    connection to battery the car was dead and would not get ready.
  13. ericbecky
    4,449
    3,354
    Madison, Wisconsin
    If you left the wiring in place did you install the bypass plug?
  14. Robertojax
    No. I really did not know that the extra plug attached was a bypass. My daughter has the car back in Atlanta as of today. I will try that and hope I can find a garage that will take the battery out.
  15. Patrick Dubuc
    quebec
    Yes it's work. You can bypass interlock in the plug. Don't forget the CAN too, as pictured. If you want permanent remove, I suggest you to verify, habitually, all the harness can be removed and you can reconnect original wires.
  16. Robertojax
    Can you email me or post the instructions so I can rig this bypass so I can remove the system and be able to run the car without it?
  17. ericbecky
    4,449
    3,354
    Madison, Wisconsin
    There should be a bypass plug attached.
    Call me if you need help locating it.
    It is usually zip tied near the harness connectors on the driver side.
    Uplug existing harness. Plug in the bypass connector.
  18. Patrick Dubuc
    quebec
    As ericbecky said, you can find bypass plug in your truck, near the hymotion plug. It's the easiest way to remove the kit and you will be able to use your car normally.
    If you plan to remove the harness, it's not easy, you should read instruction carefully and replug all original wire, but it's as been placed by human... so human can removed it too...
    Here is the link for intructions:
    https://priuschat.com/attachments/hymotion-installation-manual-pdf.65763/
    I know someone in Florida that can remove it if you want, write me if you need info.
    Patrick
  19. TLM2618
    TLM2618 New Member
    Seattle
    Four Touring
    I have a 2009 with the HymotionL5 Plug in. It failed a couple years ago. I plugged in the bypass plug. Now I would like to remove the battery. If using the bypass plug, can the battery be removed and just leave the harness? Is there must be another plug on the battery end?
    Terry
