Hypermiling
Discussion in 'Prime Fuel Economy & EV Range' started by HPrimeAdvanced, May 19, 2017.
  1. Prius from Dad
    Prius from Dad Senior Member
    724
    1,116
    Toms River, NJ USA
    So true!
    HPrimeAdvanced likes this.
  2. Prius from Dad
    724
    1,116
    Toms River, NJ USA
    Hello Gimli. Those numbers probably will not be achieved again. I did HV in the afternoon commute at 100° and 98° but the humidity was low and did not use A/C.:eek: When we get the NJ summer humidity, I will be using the A/C at 80° or below. I'll use the eco A/C and see how that affects the mpg's. I've been tracking every commute since Feb 1 and found a definite correlation between temp and mpg's and EV range.
    The EV mile chart is the AM commute (35.9 miles) and the HV is the PM commute 34.8 miles).
  3. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    Good. I drive the speed limit. The more that annoys people who are breaking the law, the better.
  4. fuzzy1
    10,652
    Maybe dry traction.
    But for wet traction, higher pressure reduces susceptibility to hydroplaning. The hydroplaning onset speed rises as the square root of tire pressure. For those of us with (it seems like) 180 rainy days per year, this is quite important. If one prepares for wet conditions, then there are no traction surprises on dry roads.
    #24 fuzzy1, May 19, 2017
  5. stevepea
    stevepea Senior Member
    535
    581
    I totally agree. Hypermiling is great, and when I'm driving, I'm always trying to get the best mileage I can on one level or another. But I would never, for instance, go 55 in the fast lane when others are going 80 there. There's an appropriate place to be for whatever speed you're going (just like you shouldn't pass to the right, I feel you shouldn't drag to the left). If I'm happy going 65 while others are going 85, I'm happy staying away from the left lanes.
    As far as aircon, for the past 25 years (even before hybrids and hypermiling), I would never use the A/C while on the freeway or while moving. The only time I'll put it on is if I'm stopped at a light on a really hot day (ie, not moving, so no breeze/wind coming in). Unless it's raining (or Godzilla is attacking downtown) I generally prefer to drive with at least the back windows open instead of the A/C on, so that helps with the mileage as well. But I WILL put the A/C on if there's no breeze coming in (ie, stopped) on a really hot day. Then when I get moving, it goes off.
    HPrimeAdvanced and alexcue like this.
  6. Lee Jay
    5,850
    4,036
    Generally at highway speeds opening the windows has a larger drag penalty than using air conditioning.
  7. heiwa
    heiwa Active Member
    223
    216
    Central Valley, CA
    I use P&G while driving LEAF. It does extend the range and improve miles/kWh figures. However, as Mr. Wilson mentioned, P&G is not needed with Prime in hybrid mode. I first came to realize this when my wife who is not a hypermiler getting better eco scores and MPG figures than I in 100-150 mile travel range! I feel like Prime makes any driver an excellent hypermiler if you stick to slow start, consistent speed and slow stop as Lee Jay suggested in other thread.
    I do not have a proof like Mr. Wilson, but it might extend the EV range if you do P&G while driving Prime within AER. Get up to speed and gliding with no power/regen on flat/descending. However, your eco score may suffer because Prime seems to give you low eco score unless you start applying break/regen much sooner than I am used to in hypermiling.
    #27 heiwa, May 20, 2017
    dalcon95 and Prius from Dad like this.
  8. Since2002
    Since2002 Senior Lurker
    936
    1,098
    Duluth, GA
    I have always heard, long before hybrids even existed, that placard pressures were designed to provide a soft ride, but that going a few pounds over the published pressures provided better mpg although with a slightly harsher ride. Your comment is the first I have ever heard that the placard represents the highest safe pressure. Not disputing, just saying I have never heard that before. I only remember hearing that it's not safe to inflate to the maximum listed on the sidewalls, although apparently some people do. I agree though that just because someone drives at a certain pressure for twenty years with no problem is not proof that it's safe.
    Data Daedalus likes this.
  9. Shaun_Collins
    Shaun_Collins Junior Member
    48
    Tulsa / Broken Arrow / Catoosa Area
    It is because its illegal here pulsing, driving slow and coasting!
    LG-H918 ?
  10. fuzzy1
    10,652
    This difference would be even stronger on modern Prii with the higher efficiency AC systems, i.e. those installed on 2010 and later model years.
  11. fuzzy1
    10,652
    If you haven't heard it before, then you simply haven't been spent too much time reading these types of discussions. Pretty much all possible combinations of good & bad have been expressed in the arguments I've seen.
    Correctly separating truth from mythology from legal CYA from self-serving marketing can be quite difficult for those of us outside the industry. Maybe even impossible.
  12. bwilson4web
    16,479
    To quote @john1701a,
    Just drive the car.
  13. Since2002
    936
    1,098
    Duluth, GA
    We shouldn't have to rely on marketing or anecdotal experiences to get safety information. It seems like there should be some independent studies to determine the safest tire pressures, although it may not be practical to test every vehicle, at least to find out what the general trend is. Probably there have been studies, that's why I don't dispute it I intend to look into it, I am willing to sacrifice a few mpg for safety if there is data to support it.
    #33 Since2002, May 20, 2017
  14. bwilson4web
    16,479
    I look through racing articles since these folks are running at the performance edge. There is a lot of useful track tire knowledge that applies to what we do.
    fuzzy1 and Since2002 like this.
  15. Prime8
    Prime8 Member
    Oregon
    2020 Prius Prime
    I draft semi's with DRCC set to 1 bar. The car does a version of pulse and glide by itself. It will periodically run for an EV range mile while in HV mode. It appears to yield about 80mpg over flat terrain. This behavior does not appear to occur at faster highway speeds. Semi's tend to run at about 62/63 mph. I think the slower speed makes a bigger difference than the airflow behind the semi. The semi makes the slower speed safer since faster traffic will ignore you.
  16. HPrimeAdvanced
    HPrimeAdvanced Senior Member
    2,304
    3,519
    Anaheim, CA
    Totally smart way to go! That speed should get you some good MPG numbers. Sounds like the semis in your area are a little saner that out here in Socal; we do have some who drive legally at the 55mph truck speed, but I've seen a lot of 70-75 mph semis driving like real nutjobs on our crowded freeways. No wonder we have so many wrecks out here, with sudden stops and go!
  17. TonyPSchaefer
    14,816
    2,501
    66
    Far-North Chicagoland
    Here's a series of articles from What Drives Us. I don't have my Prime yet so none of these address that aspect. They are intentionally generic on the belief that you can hypermile anything: conventional, hybrid, or EV. Also, these are not for experts who can nit-pick the details; the goal was to be accessible to those who have never tried and are looking for introductory information. There's always potential for more articles and if you have any ideas please let me know.
    Tony Schaefer on Hypermiling » What Drives Us
  18. sorka
    sorka Active Member
    1,031
    199
    Merced, CA
    2019 Prius
    Low gas prices doesn't reduce the carbon footprint. In fact, it increases it so as prices drop, we should increase our fuel economy even more.
    Racing Shepherd likes this.
