Featured Hyundai IONIQ - Prius competitor?
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by GasperG, Dec 8, 2015.
  1. Felt
    Felt Senior Member
    1,624
    604
    Mountain West
    I like the head lights better than the G4's.
    PS (after another look)
    I will even go so far to say that I like the grille and headlights better than the G4.
    52,878
    ouch. the mistake by the lake, with apologies to cleveland.
    all the talk about beautiful hundai styling and this is what they come up with? it better perform, or they'll be crawling back down the rabbit hole with honda.
  3. frodoz737
    frodoz737 Top Wrench
    4,810
    2,562
    33
    Sorry, but they are both ugly to me.
  4. GasperG
    GasperG Senior Member
    1,169
    601
    Slovenia
    2018 Prius
    Even worse, some rumors suggest it's 6 speed DCT (Double clutch transmission). That 8AT was just announced together with 1.6 GDI, coincidence, PR doesn't mention any hybrid application with 8AT.
    arescec likes this.
  5. arescec
    arescec Active Member
    238
    105
    Croatia
  6. bisco
    52,878
    i'll give hundai credit, they made the shadowy silhouette look gorgeous. really got peoples hopes up.
  7. arescec
    238
    105
    Croatia
    You got the real spy photos one post above you :p
  8. bisco
    52,878
    i know, that's what makes it so disappointing.
  9. Felt
    Felt Senior Member
    1,624
    604
    Mountain West
    From an exterior visual (photograph) viewpoint, I generally like the Hyundai, mainly, because I liked the look of the G3.
    The G4 may be a technological achievement, and it may be the best thing "since sliced bread," but I still find the "exterior visual (pholograph)" clumsy and unattractive. But then I am too old to understand or appreciate the "youthful" appearance that Toyota executives are reported to have wanted.
  10. hill
    9,041
    I thought the under sized engine that the first gen volt had was supposed to be one of its shortcomings - ie; the primary reason its CS mpg was so paltry. After all, their 2nd gen has a bigger ice, yet it yields a higher EPA mpg in CS mode.
    #110 hill, Dec 21, 2015
  11. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    GM presented the concept Volt as having an engine to address "range anxiety". It was only for those rare instances when you needed to travel farther than what the battery-capacity offered.
    The plan was to deliver a system which used a small 3-cylinder engine that did nothing but generate electricity.
    Instead, they used an off-the-shelf 4-cylinder engine, which could provide thrust directly to the wheels. It was far bigger and far more powerful... much more expensive than anticipated too.
    That disenchanted purists... especially when BMW delivered what GM didn't. The i3 has a tiny (650cc) engine used exclusively for electricity generating.
    Volt gen-2 retained the same larger engine. MPG did improve, but not much and it still operates the same way.
  12. Trollbait
    12,832
    It appears the Ioniq might be an actual sedan.
    They wanted a smaller turbo originally; Perhaps 1L in displacement. Then the recession hit, and they went with an existing engine. At its core, the gen1 Volt ICE is the 1.4L used in the Cruze and Sonic without the turbo. Fuel efficiency may have been better even then, but the resulting engine noise was deemed unacceptable. Audi ran into the same issue with its early A1 Etron PHV. It was a pure serial hybrid with a rotorary engine even smaller than in the i3 REX. It was supposed to just run at one, efficient speed. Drivers and passengers found the unchanging engine note disconcerting though, and the car was programmed to use 3 different rpms to follow the car's speed.
    The gen2 Volt ICE got bigger by 0.1L, but it is also a more technologically advanced ICE, with direct injection and wider valve control. GM does have a 1l turbo available now, but feedback of gen1 owners says they want an even quieter ICE, which would have been harder to achieve with a 3 cylinder turbo than the naturally aspirated 4 cylinder.
  13. Jeff N
    Jeff N The answer is 0042
    2,382
    1,304
    California, USA
    2011 Chevy Volt
    At that time, GM had an existing 48 kW (64 HP) 1.0L 3 cylinder engine (at 5300 rpm) although the concept in 2007 was to use a turbocharged variant of it that would provide 53 kW (71 HP) at lower rpms. Ultimately, they chose a 4 cylinder non-turbo that generated 63 kW (84 HP). I'm not sure if that qualifies as "far bigger" and "far more powerful". Was the non-turbo 4 cylinder "much more expensive" than the 3 cylinder turbo-ized? I don't know.
    The BMW i3 uses a 2 cylinder engine that generates 25 kW (33 HP).
  14. bisco
    52,878
    what is hundai going with?
  15. bwilson4web
    16,549
    Many years ago, when I had hair, some folks started posting rave reviews about the new, 'clean diesels'. In the spirit of Christmas, I wish @GasperG and @Netcub the same success and fame.
    Time again for the biannual, Prius-killer, Beta.
  16. hill
    9,041
    Yep - better luck with gen III insight too
  17. Maxwell61
    Maxwell61 Active Member
    393
    242
    Italy
    2024 Prius Prime
    XSE Premium
    #117 Maxwell61, Dec 21, 2015
  18. bisco
    52,878
    this is the ionique?
  19. Maxwell61
    393
    242
    Italy
    2024 Prius Prime
    XSE Premium
    #119 Maxwell61, Dec 21, 2015
  20. Sergiospl
    Sergiospl Senior Member
    3,938
    1,351
    28
    ION + IQ
