Featured Hyundai IONIQ - Prius competitor?
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by GasperG, Dec 8, 2015.
  1. bwilson4web
    16,521
    Using 5-5.5 krpm on the Ioniq as a stopping point, it looks like:
    • 1st gear - Ioniq
    • 2nd gear - Prius catches up, no engine pause
    • 3d gear - Prius continues to advance
    • 4th gear and above - the Ioniq has too high of a ratio and the Prius continues to accelerate
    This was my first look so I welcome other analysis.
    Data Daedalus likes this.
  2. telmo744
    telmo744 HSD fanatic
    2,181
    769
    Portugal
    Well, we should have GPS speed to compare, display ones may be a bit offset...
  3. Sevreth
    Sevreth New Member
    23
    Maryland
    2016 Prius v wagon
    It also could be different in the automatic mode because the computer selects the best point to shift rather than the driver.
    Either way an interesting video. I would love to see them race a predefined circuit to see how each performs time wise. I feel the ioniq would do a better job since the gears can be selected to maximize power coming out of turns.
  4. Maroon
    Maroon Member
    159
    88
    Tupelo, MS
    It is more powerful, but gearing, weight, tires, etc. also play a part in a timed run.
  5. Felt
    Felt Senior Member
    1,624
    604
    Mountain West
    All good and interesting points .... if you are solely interested in performance.
    I'm still unable to get past the looks of the Prius, so performance in not that important. In truth, I'm beyond the Ioniq as well.
    My comment was solely an opinion after looking at an SEL in a showroom.
  6. bhtooefr
    bhtooefr Senior Member
    1,396
    1,489
    Newark, OH, USA
    But the Prius can get the engine RPM up pretty quickly itself, so I wouldn't be so sure that that's necessary...
  7. hill
    9,022
    With Toyota's more powerful MG setup - it actually surprised me that Ioniq got the hole-shot.
  8. bwilson4web
    16,521
    Ok, I went back and looked at this YouTube on a frame-by-frame basis:
    • Used "," to back up one frame and "." to step forward a frame
    • Used Ioniq engine rpm, local rpm minimum and maximums as measuring points
    So this is what the graphs look like:
    The problem appears the Ioniq was a little lethargic in the last gear shift. Note that the Ioniq starts with the engine at 1,000 rpm whereas the Prius engine may be off. A better start might be to hold the cars with the brake, floor the accelerator so both engines are spinning, and release the brake to launch. Alternatively, re-run the launch with the Ioniq engine in 'auto-OFF.' Finally, run the 2017 Level 2 ECO versus the 2017 Ioniq Blue . . . grasshopper vs grasshopper.
    #1848 bwilson4web, May 4, 2017
  9. hill
    9,022
    0 to 60 mph appears to be just under 10.2 seconds ... kind of underwhelming considering that even our old '04 Prius managed a 9.8 second time by Road & Track iirc. Our Leaf is in the same mediocre acceleration category. It's like watching 3-toed sloths race .... gotta be patient.
    Data Daedalus and Sevreth like this.
  10. davidtm
    davidtm Member
    180
    TJ'ville
    But it's most important to get to the gas station LAST!
    SM-T530NU ?
  11. mikefocke
    4,073
    1,858
    Sanford, NC
    A slow car isn't necessarily a bad thing. It imposes needed discipline by requiring allowing lots of room. Said as one who witnessed the chopper medivac of someone who didn't and got t-boned last Sunday. Cut out of a burning car. Died on Monday.
    I went from a Porsche to a Prius v which is a pretty radical change. After 4+ years, the pause and reconsider has hopefully become second nature. I haven't been in a situation where I needed more acceleration than the v's mediocre amount.
  12. bwilson4web
    16,521
    Upon further reflection, it made sense to do a second-by-second sampling:
    Prius top speed, 188 kph, which allowed the Ioniq to catch up. The Ioniq 4th gear is too tall which slowed it up. Even the Inoiq 3d gear looks tall and/or the Ioniq engine is running out of torque.
    The initial chart sampled at the local minimum/maximum Ioniq rpm with linear interpretation between the points:
    Nothing wrong other than this was too coarse sampling.
    Data Daedalus and Fred_H like this.
  13. Trollbait
    12,817
    Fourth through sixth gears on the Ioniq are overdrives. That last shift is likely into 6th, and when not being pushed, the car will likely shift into it at 45mph or so. The car could skip 2nd and even 3rd when under hard acceleration from a stop, or just have shifted quickly enough to not to be noticed. I know it isn't like to like, but the Sonic can move in to 4th as early as 20mph.
    Considering the transmission software is likely programed for keeping fuel economy up, the Ioniq should do better using manual mode to keep it out of 6th or even 5th.
  14. bhtooefr
    1,396
    1,489
    Newark, OH, USA
    I don't think so, actually - note that it seems to land at right about 4000 RPM after every shift, indicating well-spaced ratios (at least for consistent shiftpoints, if not optimum acceleration - in an optimum acceleration configuration, the shifts get closer as you get higher up the box).
    Ioniq Hybrid gear ratios, for at least the European model:
    That dual final drive thing is actually pretty common on DCTs and 6-speed manuals, helps make things more compact.
    In any case, it's about 2 meters per revolution of the tires with the Ioniq's stock tire size (well, I've got 1.9933 m, but 2 m is probably close enough).
    0.956 * 3.045 = 2.911
    4500 rpm engine / 2.911 = 1546 rpm wheels
    1546 * 2 * 60 / 1000 = 185.5 km/h
    Basically, it was in 5th, I think it just ran into its speed limiter.
    Edit: However, it looks like the system wasn't even allowing it to get to the 5700 RPM horsepower peak...
    #1854 bhtooefr, May 4, 2017
    Jeff N and Fred_H like this.
  15. bwilson4web
    16,521
    Thanks!
    Understand I was trying to read the Ioniq rpm from the dial as captured by YouTube. I could not see the fine divisions so I would give +/-100 rpm on any of the readings. Feel free to spot check (see below).
    ps. The seconds start at 5 but I shift them relative to 0:
    seconds Prius_kph Ioniq_kph Ioniq_rpm
    1 0 0 0 1000
    2 1 12 13 1800
    3 2 29 28 4000
    4 3 42 44 3600
    5 4 55 56 4000
    6 5 66 64 5000
    7 6 74 74 3800
    8 7 83 79 3800
    9 8 89 86 4000
    10 9 96 92 4300
    11 10 101 99 4800
    12 11 108 105 4900
    13 12 114 110 5100
    14 13 119 115 5200
    15 14 124 118 3800
    16 15 128 122 3900
    17 16 132 126 4000
    18 17 136 130 4000
    19 18 140 133 4100
    20 19 144 137 4300
    21 20 146 140 4500
    22 21 150 144 4600
    23 22 153 146 4700
    24 23 155 149 4800
    25 24 158 152 4900
    26 25 161 154 5000
    27 26 164 157 5000
    28 27 166 159 5100
    29 28 168 161 5100
    30 29 170 163 5200
    31 30 172 165 5300
    32 31 174 166 5400
    33 32 176 168 5400
    34 33 177 169 5500
    35 34 179 171 5500
    36 35 181 173 5500
    37 36 182 174 4500
    38 37 183 176 4200
    39 38 184 177 4200
    40 39 185 179 4300
    41 40 186 180 4300
    42 41 187 181 4300
    43 42 188 182 4400
    44 43 188 183 4400
    45 44 188 184 4400
    46 45 188 185 4400
    47 46 188 186 4500
    48 47 188 186 4500
    49 48 188 187 4500
    50 49 188 187 4500
    51 50 188 188 4500
    52 51 188 188 4500
    53 52 188 189 4500
    54 53 188 190 4500
    55 54 188 190 4500
    Sevreth likes this.
  16. inferno
    inferno Senior Member
    1,072
    405
    We're missing an important factor here. Where's the mpg/kpl?
  17. hill
    9,022
    ~ 117mph?
  18. bwilson4web
    16,521
    Please review the YouTube video and report what you find.
    telmo744 likes this.
  19. Felt
    Felt Senior Member
    1,624
    604
    Mountain West
    Great discussion!
    I presume the discussion is all based on the side by side images of the speedometer?
    If my understanding is correct, there is no way to improve the Prius performance with manual manipulation .....
    whereas, the Ioniq DCT can be manually shifted,(as Trollbait says) (forget fuel efficiency) holding each gear until the point of peak performance.
    I don't suppose we will know for sure until someone drives the Ioniq in performance mode.
    Also, remember the article about the Ioniq setting a land speed record (I think the speed limiter was removed)
    I well recall in 1955 when the new Chevy V8 was widely acclaimed because it would 0-60 mph in 10 second flat!
  20. bisco
    52,807
    oh sure, pulse and glide works great. or do you mean a manual setting?
