I’m in Love, With Our New 12V Battery!
Discussion in 'Prius v Accessories and Modifications' started by jzchen, Oct 12, 2018.
  1. audiodave
    audiodave Active Member
    800
    272
    US
    Funny how we had rain last night. Wasn't predicted early in the day.
    jzchen likes this.
  2. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    Probably making me wait until I figure out how to read engine RPM so I can do the 3000 RPM test. Soccer game is about to start. I keep praying to the lightning and thunder gods to no avail....
    audiodave likes this.
  3. audiodave
    800
    272
    US
  4. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    Alright, so I dug through what I compiled from Toyota TIS about checking the charging system. Since it is a DC/DC converter the steps are a little different:
    Turning on vehicle to Ready, one is supposed to connect an ammeter to the positive cable and watch as current flow into the battery decreases to 10 A or less.
    Then turn the power switch on to Ready again, headlight ON, blower motor on and rear defogger ON:
    Current flowing from battery should be 0 A or less
    Aux battery voltage (at the terminals) should be 13 V to 15 V
    Woohoo. I think we have a compatibility match! Time to install.
    #24 jzchen, Oct 13, 2018
  5. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    Okay, so I connected a charger to the jump points under the hood while I swapped the new battery in, quickly disconnected the charger, and found that the new battery is too tall! I have contacted the seller. Hold down will not hold with original bolt and nut. And the plastic panel on top does not sit flush, roughly 1 cm - 2 cm above where it should sit. They should get back to me Monday hopefully as they are closed weekends.
    To be continued....
  6. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    So I had the opportunity to get the original battery on my scales. One is a post office letter scale which just said “E”, too heavy. The bathroom scale says 28.8 lbs.
  7. bisco
    51,844
    no way to customize the hold down? does lithium even need to be locked in place?
  8. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    I can, not too hard, but the plastic cover above it also doesn’t sit properly, about 1 cm up I’m estimating, and I don’t really want to hack that to fit, at least not yet. As it is the other stuff that sits on top of that cover might not fit well too. I’m going to get a longer bolt and that should hold it down for now. It’s so light I don’t want it bouncing around while driven. I’ll see what options the seller gives me before I do more than bolting it down with a longer bolt and bunch of washers...
  9. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    I just thought of something, the bracket holding the battery down has the battery temperature monitor attached, and it doesn’t sit well on the top, more than likely hindering the temp monitoring function. Gonna have to note that to the seller when they get back to me. It should sit more flush with the top surface so heat can transfer more properly. (But I also feel the actual battery cell inside sits low so as not to contact the top of the casing as well, so that the temperature control may have to depend solely on the built in internal circuitry).
    As it is the bracket partially covers the emergency/voltage meter button and voltage display.....
  10. Al Bundy
    Al Bundy Member
    140
    69
    florida
    the link says $362.00...................................for a battery......................................about the same size as a $25 lawn tractor battery..........or a $75 gel cell wheel chair battery.......what am I missing? is there a free lifetime replacement warranty? solid gold posts worth $150 each?
  11. Usle
    Usle Active Member
    317
    140
    Me
    2018 Prius Prime
    Ok, free shipping, but to return...you pay shipping, it might be cost effective to take a slow boat to China and bring the battery.
  12. mikefocke
    3,988
    1,801
    Sanford, NC
    In another world, we used small light batteries to reduce weight that was relatively high up in the car. Only for long trips, only for racing, only in warm weather. Now granted there are differences in the way a Toyota uses its battery to start but I'd still be concerned that there might be some downside.
    Air_Boss likes this.
  13. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    Well, I took a closer look and the bottom of the original is square while the bottom of the Li one flares out so you can clamp a hold down bracket on the bottom, so it is not sitting flat on the bottom. Almost fits with mounting bracket mod...
  14. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    Supposedly Li batteries can be cycled 2000 times, similar to cell phone batteries. So the plus side is the longevity and the weight. They have been prone to catch fire, the concern, and whether the onboard electronics/control logic are reliable I will have to follow up. It is in the car, sitting close to just right. The plastic cover barely will stay in it’s place as it wants to pop up from one of the three tab hold downs.
  15. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    Besides the high cost down side. Braille batteries can cost $1000 to $2000 +.
  16. frodoz737
    frodoz737 Top Wrench
    4,694
    2,496
    33
    If I may jzchen...why this experiment?
  17. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    To me this is more an investment/calculated risk. I paid more for a supposedly more durable/reliable product, with built in logic/safeguards, and backup power, for a fraction of the cost of a Braille battery, which doesn’t include such enhancements.
    I would consider a Braille Lithium battery more of a risk because of it’s extremely significant premium.
  18. frodoz737
    4,694
    2,496
    33
    Respects, but for double the cost and the extra work, it seems wiser to just buy another AGM @ $180-$200 retail.
    sadie72 likes this.
  19. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    I did take some risk, that it doesn’t last long enough to make it monetarily worth it, true. Only time will tell. I’ll pop in this thread once in a while to update on any (other) issues I come across. (Right now there is a slight fitment issue).
  20. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    Almost 2 1/2 months, roughly. So far so good. I guess I’ll post again around 6 months, or 1 yr...
    nssdiver and bisco like this.
