I am 331000 miles new.
Discussion in 'Newbie Forum' started by HellOnAStick, Mar 7, 2018.
  1. 3prongpaul
    3prongpaul Hybrid Shop Owner, worked on 100's of Prius's
    956
    730
    Boulder Hybids, Boulder, CO
    HellOnAstick, instead of throwing parts, time, and money at the car you need to have it properly diagnosed by someone who knows Prius and has Techstream. When you have weird problem on a Prius, Techstream (and knowing how to use it) is the most helpful tool.
    Many times I've had DIYers try to fix their car using the internet, spending tons of money then give up. They tow the car to me and I find something simple that if they had come to me in the fist place they would have saved hundreds of dollars.
  2. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
    What kind of OBD2 scanner are you using?
    Data Daedalus and Raytheeagle like this.
  3. 3prongpaul
    956
    730
    $7EA and $7EB are not codes. They are generic module/ECU references. You need a better tool to properly scan a Prius.
    Cheapo consumer grade scanners will give you standard engine errors (misfire, bad cat, running lean etc), but most won't tell you anything about the transaxle or hybrid drive side of things which you need to properly diagnose a Prius.
  4. HellOnAStick
    HellOnAStick Junior Member
    30
    South Lake Tahoe
  5. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
  6. 3prongpaul
    956
    730
    That scanner is not going to provide all the information to properly diagnose a Prius. Get Techstream or pay someone to diagnose the car.
    Data Daedalus, RCO and Raytheeagle like this.
  7. HellOnAStick
    30
    South Lake Tahoe
    Already did that. It was O2 sensor codes. Replaced O2 sensor and fuel/air sensor. Then.....
    SO....I guess Techstream is my next stop.
  8. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
    Am curious what those two oxygen air/fuel sensor codes were?
    Data Daedalus likes this.
  9. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
    Were these two parts replaced with OEM or aftermarket parts?
    HellOnAStick and Data Daedalus like this.
  10. HellOnAStick
    30
    South Lake Tahoe
    Replaced with Denso (OEM) parts.
