I am losing it please help
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Steve Fox, Aug 5, 2015.
  1. Steve Fox
    Steve Fox New Member
    pa
    I have 2 priuses and the 2008 has been getting bad. To start things off my daughter ran it out of gas and i believe ruined the hv battery. so i replaced it an still cant get it running. i have tried everthing that i have read here. please help
  2. JC91006
    16,871
    8,619
    You have to put at least 5 gallons of fuel in the car to get it started. What made you change the hybrid battery? Did you buy new?
    The orange service plug on the battery has to be installed properly. Tilt upwards and then press downward to lock it in place. Or your car won't start.
  3. Steve Fox
    pa
    i have a full tank and have reinstalled plug 3 times and pushed down afterwards.Still no luck i switched 12v batteries with the other prius and that ddnt help
  4. JC91006
    16,871
    8,619
    Where did you get this new hv battery? Are you sure it's good? are you sure the 12v battery is good? Does everything light up on the dash but you just don't get the car to go READY?
    #4 JC91006, Aug 5, 2015
  5. Steve Fox
    pa
    the 12v battery works in he other prius. and the hv battery came from green tech. appears to be good it is reading 5 bars on the monitor where the othe read 1
  6. JC91006
    16,871
    8,619
    Well the greentec battery could be a bad battery.
    If there was nothing wrong with the car when it ran out of gas.....chances are, the hv battery on the car wouldn't go bad from that event....especially on a 2008
    At this point, you would need to retrieve the codes on the car, see what could be wrong.
  7. Steve Fox
    pa
    will do thnks for the help
  8. JC91006
    16,871
    8,619
    well sounds like you might have gotten rid of a perfectly good battery, 1 battery bar does not mean the battery is bad.
    Why didn't you bring it to a dealer first?
  9. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    Moved out of the Prius v forums as you own a gen II.
  10. dpeverhart
    dpeverhart Member
    126
    23
    I
    Try this: Put your foot on the brake and press the start button and hold it down for about 5 seconds. I noticed after changing the battery the first time starting the car you have to hold the start button down a little longer.
