I am resetting TPSM but light remains on (all 4 tires are 50psi)
Discussion in 'Gen 2 Prius Main Forum' started by MilkyWay, Aug 15, 2016.
  1. Mendel Leisk
    41,402
    No tape, thank you. I bask in the baleful light of the TPMS sensor every winter, with my snows tires (no sensors). :p
    Ah, I can kinda see that. Maybe. No, I would just sell it as-is, tell the guy the story, IF he notes it, and be about as flexible on the price as the cost to remedy. Again, IF pressed.
    I just can't get too excited about TPMS sensors, lol.
    #21 Mendel Leisk, Mar 2, 2019
    tranfamily35 likes this.
  2. Hamptgx
    Hamptgx Member
    66
    27
    Northern Illinois
    Maybe im not reading these posts correctly but the tpm switch on steering column is for setting the pressure you want the low tire pressure to come on at so if you press and hold to get the three flashes while your tires are at the desired pressure then your warning light will come on as soon as pressure dips.
  3. fuzzy1
    10,433
    ... but the light also stays one when it can't get readings from one or more sensors at all, whether it be a bad sensor, dead sensor battery, radio reception or interference problem, or a wheel without sensor at all.
    Some tires call this out as the max cold pressure, before any road or day heating occurs. The later heating is included in their built-in safety margin, which should also include margin for common elevation changes (High elevation -> lower ambient air pressure -> higher internal gauge (not absolute) pressure).
  4. dolj
    dolj Senior Member
    8,438
    4,288
    Wellington, New Zealand
    Yes, but you pump your tires up to the correct pressure then use the switch to calibrate. This sets the warning light pressure to a few PSI below.the current pressure.
  5. Salamander_King
    Salamander_King Senior Member
    11,016
    8,948
    New England
    $240 (excluding tire cost) for 4 TPMS is a lot cheaper than ~$800 I spent on 4 TPMS on my old HCH. But if I knew what I know now about TPMS, I suggest option 4: Buy cheap external TPMS at Amazon around ~$40, and know exactly each tire presser is all the time while you are driving.
    That said, I can see why you wanted to take care of TPMS light issue before selling your car.
  6. Mendel Leisk
    41,402
    Maybe just hearsay, but I've heard a 25% drop below set pressure is needed. Normally. In other words, if set pressure is 40 they'll alert at 30. That said, I've had mine go off AT the set pressure. A one time bug I think.
  7. Skibob
    Skibob Senior Member
    2,912
    1,502
    Northern California
    The sensors measure both tire pressure and temperature. And yes when the battery’s run out you get the light on no matter if you try to reset it.
  8. dolj
    dolj Senior Member
    8,438
    4,288
    I think you're right, it sounds like hearsay. It wouldn't make sense to use a percentage. It would be a hard 3-5 PSI at most.
  9. Mendel Leisk
    41,402
    More hearsay?
    We could put this to bed, by just testing. Set all four tires to the same pressure, do the TPMS reset, then with the car fully on, start dropping pressure in one tire, say a couple of pounds at a time, wait a minute or two, repeat. See how much pressure drop is needed to to set off the light.
    #29 Mendel Leisk, Mar 3, 2019
    fuzzy1 likes this.
  10. dolj
    dolj Senior Member
    8,438
    4,288
    No, just a WAG based on what seems reasonable.
    Yes you could. I couldn't, I don't have TPMS, thank goodness, but would happily do so, if I did.
  11. fuzzy1
    10,433
    I don't see why a fixed hard number makes any more sense than a percentage. Microprocessors have enough math processing capacity to handle either.
  12. Skibob
    2,912
    1,502
    Northern California
    Plus don’t forget, the sensors measure tire temperature as well as pressure.
  13. wjtracy
    wjtracy Senior Member
    11,367
    3,608
    Northern VA (NoVA)
    I never got around to fiddling with the reset to see if I could adjust the alarm setting upwards...I think there is a default value around 26 or 26.5 psia as the base case minimum.
    If its percent basis then maybe it is % x (P+14.7) but then 25% sounds too high
  14. RobH
    RobH Senior Member
    2,385
    991
    70
    Sunnyvale, California
    Techstream can read the actual tire pressure that will trigger the warning light.
