I blew the fuse for the lighter socket for the second time
Discussion in 'Gen 5 Prius Technical Discussion' started by Paul Gregory, Aug 24, 2025.
  1. Paul Gregory
    Paul Gregory Senior Member
    2,339
    614
    Alberta
    2024 Prius Prime
    XSE
    I'm totally to blame. I run too many accessories at the same time. This time it was the vibrating seat cushion that broke the camel's back. I decided to use a 20 amp breaker in place of the 15 amp fuse. Since I don't bend that way, I took it to a local repair shop, where they installed it for free. The mechanic advised against it, but I said I was doing it anyway. I have no problem at all driving 20 amps through that circuit.
    I run several chargers, a cellphone booster, a dashcam, a radar detector, and the back massager. Now, if it blows again, I'll know when to disconnect some of them, but I won't have to replace a fuse.
  2. Paul Gregory
    2,339
    614
    Alberta
    2024 Prius Prime
    XSE
    I learned about the limits of the lighter socket in my Gen 3 from a close call. That one is protected by a 10 amp fuse, and I may have upgraded the fuse; I don't recall.
    But when I plugged in my truckers oven (heated lunchbox) I smelled hot plastic, so I unplugged it right away. No apparent harm to it anyhow. I installed a socket directly off the battery, with a long extension cable instead. I'm sure it was fused at 20 amps. No problem with that setup at all.
    #2 Paul Gregory, Aug 24, 2025
  3. frodoz737
    frodoz737 Top Wrench
    4,797
    2,560
    33
    You posted this knowing anyone with even the most basic electrical knowledge and wisdom would advise against. :rolleyes:
    Brian1954 likes this.
  4. Paul Gregory
    2,339
    614
    Alberta
    2024 Prius Prime
    XSE
    Of course I knew. But I feel confident in my choice.
    I knew someone would be eager to criticize my decision.
    #4 Paul Gregory, Aug 24, 2025
    PrimeDan likes this.
  5. bisco
    52,807
    ah, that's why. i was wondering
  6. Brian1954
    Brian1954 Senior Member
    2,669
    1,068
    South Central PA, USA
    Do you do the same thing at your house? When a 15 amp breaker trips a couple of times, do you go and replace the 15 amp circuit breaker with a 20 or 30 amp breaker?
