I blew up the inverter????
Discussion in 'Gen 2 Prius Technical Discussion' started by GinnyErns, Jun 5, 2008.
  1. patsparks
    10,664
    569
    Adelaide South Australia
    Put it on ebay and be quick before all the crazy panic merchants calm down. You will get top dollar for it.
  2. Godiva
    Godiva AmeriKan Citizen
    10,339
    You are a customer and it is not your job to diagnose your car. The lack of expertise of the service manager is demanding that you do exactly that.
    Given the history of the new owner, you are wasting your time; you're not going to get anything out of him. Don't bother with an e-mail. Wait until another dealer correctly diagnoses and fixes your car. Then you can CC the original dealership owner on the letter you write to Toyota headquarters, Consumer Reports, the local TV troubleshooter, Better Business Bureau, etc.
    You need to:
    1. Get your car out of there and to a REPUTABLE dealer. Don't let them do any more work. Just have it towed as is. You can always sue them for the cost of the towing later on.
    2. Contact Corporate over the original dealer's screwing you over regarding failure to honor warranty and inablity to diagnose problem and provide detailed description of failure and cost of repair. If the new dealership you take it to can back up anything in writing, you have leverage.
    3. Contact the media. The last thing Toyota or the Dealership needs is it splashed all over the news that the Prius will require the owner to pay $5,000 to replace the inverter if they get a bad battery and end up having to jump it AND that Toyota will NOT honor their warranty.
  3. Godiva
    10,339
    That's what I was thinking. Do they hybrid tech contests and he placed second? If not....he can call himself anything he wants, the proof is in the pudding. And he's got mush.
    By know someone at the dealership should be getting a clue that Ginny isn't your average mark due to the questions she's asking. Since they're still clueless....even more incentive to get the car out of their hands and to a dealership that really knows what they're doing.
  4. Patrick Wong
    18,210
    6,517
    Hi Galaxee,
    I agree that a failed inverter coolant pump is a low probability event, since DTC P0A93 "Inverter Cooling System Performance" did not appear, and since an overheating problem would usually manifest itself after the car has been driven a sufficient distance for the inverter to overheat. Ginny did not complain that her car had any warning lights appear prior to having a dead 12V auxiliary battery.
    Hi Ginny,
    Your post #140 provided the fusible link part number of 82620-47050. If you enter that part number into the following link, you can obtain pricing and part description:
    DiscountToyotaParts
  5. andyprius
    andyprius Senior Member
    2,212
    188
    Sacramento, California.
    Ginny, Please listen to this incredibly good advice, and act upon it! Incidentally you are not senile, as your post indicate. I think your dealership is senile.
  6. richard schumacher
    7,683
    1,066
    United States
    How many pips were lighted on the gas gauge?
    GinnyErns, which dealer is this? We all want to stay the hell away from that one.
  7. andyprius
    2,212
    188
    She listed it on this thread
  8. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    My favorite scenario, one that others have already mentioned:
    Your Prius is dead. You have it towed to this dealership. The lot cleaning/urinal cleaning boy is told to jumpstart it. He hooks up jumper cables to the dead Prius, then touches the other ends together to get a big fat spark, "proving" he has a good connection. That was how his grade 3 dropout daddy taught him, by gum it has to be the right way
    So he hooks up the other end to a running vehicle, and gee whiz, the Prius won't start. They push it into the shop, hook up techstream, and lo and behold: fried inverter. Nope, not *our* fault, *you* did it
    This has turned into a giant cluster f*** for Ginny. I fear she will get nowhere and will have essentially a brand new dead car on her hands. If Ginny is smart - nudge nudge wink wink - she will really broadcast what has happened, and Toyota will regret not covering this incident
    Or at the very least Toyota will be forced to put giant yellow warning stickers near the jump start point and on the battery itself: WARNING. IMPROPER JUMP START WILL DESTROY A $4,000 PART AND SUBJECT YOU TO HUMILIATION AND HIGHWAY ROBBERY. ARE YOU SURE YOU HAVE THE POLARITY CORRECT?
    In the meantime, if my Prius ever breaks down in Idaho, I'm having it towed out of state!
  9. qbee42
    qbee42 My other car is a boat
    18,058
    3,081
    Northern Michigan
    How many potatoes would we need to connect in series and parallel to jump start a dead Prius? This is a homework problem for those of you with nothing to do and lots of time to do it in. What type of electrodes shall we use? :rolleyes:
    Tom
  10. aminorjourney
    aminorjourney Mum to two prius!
    335
    27
    Bristol, UK
    Can I just ask a simple question? Forgive me if it's been asked before.
    You said the car was towed. How did they tow it? Where the front wheels off the ground and non-rotating?
    If the car was towed with the front wheels on the ground, rotating, then that's a possible cause for the inverter failure....isn't it?
  11. andyprius
    2,212
    188
    Hmm, That's very interesting. Pat, Galaxee....is that true?
  12. Patrick Wong
    18,210
    6,517
    Hi Andy,
    In order for the 2G to be towed with the front wheels rotating, the gear selector would have to be in N which implies that the car is IG-ON. I don't think that the tow would cause damage to the inverter, but it might cause transaxle damage since the engine is not powering the transaxle oil pump.
  13. aminorjourney
    335
    27
    Bristol, UK
    But isn't MG1 (or is it 2) directly connected to the transmission permanently? If it was towed with the car in neutral it would still be connected...
  14. Patrick Wong
    18,210
    6,517
    MG2 is directly connected to the axleshafts via a differential. Hence MG2 would be spinning as the car is towed. The MG2 electrical output is connected to the inverter. However since the car would be in N, I understand that the inverter circuitry will isolate the MG2 output.
    In any event, this is probably moot since the 12V battery was dead, hence it would not have been possible to keep the car in N for an extended tow.
  15. aminorjourney
    335
    27
    Bristol, UK
    Ah, okay then.
    I did wonder ;)
  16. galaxee
    galaxee mostly benevolent
    9,810
    471
    MD
    as has been said, you couldn't tow it in N because you couldn't get it out of P.
  17. Codyroo
    Codyroo Senior Member
    1,826
    515
    Pleasanton, Ca
    Any updates on this?
  18. GinnyErns
    GinnyErns No warranty for me
    55
    Idaho, USA
    OK Gang....here is the latest.....first, the car was towed on a flat bed....as stated, a dead car can not be put in neutral......this car really gets me, because if it stops dead you have to have it towed in. They said my battery was defective, and replaced that under warranty, but say I have to pay for the tow. Doesn't a new car come with free towing/roadside service and is that for the 3 yrs/36k miles. Second if a part is defective and caused the car to die, why wouldn't the tow be included in the warranty. That's what the service guy told me at the dealership when he said have it towed in. But they want me to pay for the towing which is $401.
    Now I asked the service department for an update on what they really did when they replaced the battery and fuse link. They said it was the fuse link assembly and the 100A fuse located in engtine compartment fuse block. They did not give me any of the new DTCs...........they said they came back as hard faults, but would not give me the codes.
    Did someone say if I jumped it wrong it would have triped the 120a fuse at the battery terminals? That one was not determined damaged. So now I am really confused as to why I am at fault.
    I am going to write to the owner now. I am not sure if he realizes what has been going on with my case. If anyone else would like to give him a word of advice, about treating me justly and fairl, I would appreciate it. His name is DH Moss..........and service dept. tells me that is his name really is DH.
    Email is [email protected]
    Thank You all for your support,
    Ginny
  19. hiremichaelreid
    hiremichaelreid New Member
    451
    Ottawa/Aylmer, Canada
    I
    Yes. Charging you for towing is preposterous.
    So the car is fixed now and under warranty ? If so, great work ! Last step is to get them to pay for towing. Just seems silly, like they want to "win" something here.
  20. GinnyErns
    55
    Idaho, USA
    Patrick, what codes am I looking for. The service gal says she sent me all the codes before and do I want them again. I have to write back and say yes, that is what I asked for on June 25th. I am trying to get them now, as we know they were impossible to get until they replaced the battery and fuse. The only 5 digit code I saw on all their sheets was C1320 that said HV System Malfuntion (but is that the inverter.) on the next line it said Detailed Freeze DTC and only had a value of 87........but don't see a 5 digit code.
