I blew up the inverter????
Discussion in 'Gen 2 Prius Technical Discussion' started by GinnyErns, Jun 5, 2008.
  1. GinnyErns
    GinnyErns No warranty for me
    55
    Idaho, USA
    Oh Michael, I wish I could say the car was fixed. The only thing they have paid for is the battery nothing else.....still want me to pay $4367.77.....and I am still not going to. But am tackeling each perposterous item one at a time.
  2. dhancock
    dhancock 2 Prius Family
    357
    40
    Hamburg, NY (Buffalo area)
    Ginny, Have you tried contacting any news organization? It seems that these days, with gas prices so high, that there would be a keen interest in the Prius - both the plus and the minus of it. I'm sure that some news organization would really be interested in your story.
  3. GinnyErns
    55
    Idaho, USA
    Tried the Boise paper and TV back in May and no response. Will try again as you are right people are very interested in the Prius and should be alerted to how to care for the hybrids and what dealers to stay away from as they don't seem to want to stand behind the warranty. And why not stand behind the warranty. Toyota Corp. pays for the repair and you would think customer satisfaction would be worth any amount they may be out doing warranty work. Thanks for the reminder.
  4. kohnen
    kohnen Grumpy, Cranky Senior Member
    317
    58
    Fullerton CA
    :grouphug:
    OK. We're all huddled trying to figure out what to do.
    Do you still have the jumper cables? Can you get them?
    If so, can you check them VERY CAREFULLY to make sure that the red clamp goes to a red clamp and the black clamp goes to a black clamp?
    I'm asking because I recall a notice at my local AutoZone recalling a bunch of relatively cheap jumper cables because the clamps were put on the cables to wire red to black.
    If this is the case, Toyota is right, and you get to sue the jumper cable manufacturer / importer / distributer / retailer.
    Hope things ultimately go well.
  5. Patrick Wong
    18,210
    6,513
    Hi Ginny,
    On June 13, you provided a list of DTC that had been retrieved by the tech prior to any repairs being performed to your car (see your post #140).
    Now that the 12V battery was replaced and all fuses are (hopefully) in good condition, we want the tech to clear all old codes, retrieve whatever DTC(s) are produced now and list them for you, to substantiate why the inverter needs to be replaced. Hopefully the DTC list will be shorter, compared to the list provided on June 13. In particular, we are interested to see whether DTC P0A08 and P0A09 still show up.
    By the way, I do not find DTC C1320 in my repair manual.
  6. Bob64
    1,540
    93
    Virginia
    On page 11-32 of the bentley repair manual I think it might have it on the row that says:
    DTC: C1310/51
    INF Code: 156
    Definition: Malfunction in HV system
    Trouble Area: Hybrid control system (Enhanced VSC, TRAC system)
    Perhaps C1310/51 means C1310-C1351?
  7. Patrick Wong
    18,210
    6,513
    Hi Bob,
    Not sure what the "/51" means. However I do not think that it signifies a wide range of 42 possible numbers from 1310 to 1351. For example, C1336/39 "Zero point calibration of deceleration sensor undone" exists, and is within the range from C1310 to C1351.
  8. ibmindless
    ibmindless Member
    206
    Doesn't a Boise TV station or newspaper have a TROUBLESHOOTER? Many media organizations have someone who will fight for the consumer.
  9. Patrick Wong
    18,210
    6,513
    Hi Mark,
    Since TV stations and newspapers usually depend heavily upon auto dealer advertising, while Toyota is an extremely large and relatively successful auto manufacturer, I would not expect the Boise media to intercede in an ambiguous situation like this.
  10. kohnen
    317
    58
    Fullerton CA
    More information on the bad booster cables:
    - Accidents and Injuries
    If you used one of these, you get to go after Autozone for the repair costs.
    (Curiously, my previous post was _TOTALLY_ ignored!)
  11. GinnyErns
    55
    Idaho, USA
    Sorry Kohnen, I did not mean to ignore your post. My cables are connected propertly. They are very good ones and I have used several times before. So will not be going to Autozone.
  12. abq sfr
    abq sfr New Member
    690
    Albuquerque, NM
    I think I read about that in Consumer Reports, and thought WOW that could really cause some trouble! And I thought, the only place they could screw something up that bad is China! A whole run of jumper cables with black to red? Do they use a different standard in China? Or just hire the mentally deficient in their jumper cable factories?? You would have thought somebody in the factory would have noticed long before it became a major issue, like maybe when the number produced was only 139,000? ;-)
  13. GinnyErns
    55
    Idaho, USA
    UPDATE: The plot thickens. Appears one of the TV stations in Boise do want to do a story on the hybrids and costly reapirs. They wrote to me tonight. Will find out more and keep you all informed.
  14. brick
    brick Active Member
    1,083
    79
    Upstate NY
    Sooooo...they want you to go on TV and talk about how terrible hybrid cars are because you're getting screwed by your dealer on something that (probably) falls under the warranty. Be extremely careful how you handle this. If you want this to help your agenda, it has to be about the people mistreating you. Not some BS about how expensive and unreliable hybrid cars are in general. It's a shame but the media are not particularly trustworthy.
  15. galaxee
    galaxee mostly benevolent
    9,810
    471
    MD
    prepare before the interview- you want to speak in sound bites. make sure they tell your story straight, that will be most effective.
    good luck! hope it pans out ok for you.
  16. Godiva
    Godiva AmeriKan Citizen
    10,339
    you can anticipate what they'll ask you. write answers out in advance. practice.
  17. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    Your dealer and Toyota Corp had a chance to apply Goodwill to your case, and refused to do so. Quite frankly, I could care less if it turns out to be a hatchet job on hybrids in general, or the Prius in particular.
    It wouldn't be a huge leap to put short/reverse polarity protection at the underhood jump point. My 700 amp Canadian Tire jump start box has reverse polarity protection built in, and I have tried it - on purpose - on the 1984 Ford work truck at my hobby farm
    Hook up the cables correctly, the green LED turns on. Reverse the cables, it stays dead.
    It would be helpful to ask in advance what the station expects, and if they truly want to cover your plight with the dealer and Toyota Corp. As others have mentioned, don't get emotional, do "sound bites" that the undereducated, brainless masses expect
  18. ibmindless
    ibmindless Member
    206
    I thought about that after I posted. You are quite correct - newspapers & TV stations depend on the advertising revenue. I remember when a local newspaper decided to do an expose' on shady car dealer practices. The network of dealers not threatened, but actually withdrew their advertising. MAJOR loss to the paper. After a month or so, things went back to normal. Oh yeah, the paper never finished their 5-part story.
  19. GinnyErns
    55
    Idaho, USA
    All I want is my car repaired under warranty like it should be. Even the tow. Don't we get a 3 yr/36000 mile roadside service with our car?.
    Why do they keep saying I have topay for towing? They admit the battery is defective yet still keep trying to say I have to pay the $401 towing. The mechanic that led me through the 2nd jump said to have it towed in as it was covered under warranty. So because the battery is defective the tow should be paid for too. I live 85 miles from the dealership and the car died. They did not know the problem and said I had to have it towed in so they could check it out. They found a defective battery. Seems to me no matter what the problem found with the car our roadside service that comes with the new car should cover the tow. I do not have any of my books as they are all at the dealership with my car.
    Can someone refresh me on the roadside service. Doesn't that come with the new car and for how long do we get it?
  20. Godiva
    10,339
    I think they did away with the tow. I don't believe towing is part of roadside service anymore. In fact, I don't believe roadside service is covered either.
    But....you are absolutely correct. Whatever is wrong with your car (and I don't believe your dealer knows what's wrong) *should* be covered under warranty. They are trying to weasel out of the warranty by blaming you.
    If you have to pay for the towing, that's one thing. But they should be paying for everything else. And if you have to rent a car while this is going on....I say take them to court and sue them for the cost of the rental car.
