I blew up the inverter????
Discussion in 'Gen 2 Prius Technical Discussion' started by GinnyErns, Jun 5, 2008.
  1. bestmapman
    bestmapman 04, 07 ,08, 09, 10, 16, 21 Prime
    1,289
    242
    Kentucky near Cincinnati, OH
    Who is the dealer. I am sure a lot of us would like to stay away from that one.
  2. hobbit
    hobbit Senior Member
    4,089
    469
    Bahstahn
    Wow, this thread went totally out of control before I found it
    and caught up... While I sort of like the idea of a reverse
    protection diode, even a .4 volt drop might be enough to fool
    a charger into doing the wrong thing or terminating early or just
    not pushing enough charge into a dead prius battery from another
    source. Example: I used my car to charge a friend's car [not
    jump, i.e. crank his starter, we knew better]. Even with mine
    in READY at 14V [no, not 14.8] I could only get a couple of amps
    to flow from mine to his. I had to leave things that way for a
    couple of hours to finally push enough charge into his battery to
    get his car started, and that was direct without any intervening
    diode. To really *charge* another 12V you really need a source
    north of 15 volts to get any appreciable current across.
    Now, take a look at
    http://techno-fandom.org/~hobbit/cars/ginv/615dcdc.jpg
    and follow along. Near the upper right, which corresponds to
    the left rear corner of the inverter when it's mounted in the
    car, you see black and orange wires coming up through a rubber
    gland in the case. Just below and to the left of that are two
    things with curved metal straps bolted down across them. The
    rightmost one of those is the output filter for the 12V, and
    the left one is the DC/DC transformer that gets driven by some
    of the power transistors along the left edge of the circuit
    board. In between the two is the diode module. It's a typical
    center-tapped transformer/rectifier circuit. Below the inductor/
    diode assemblies, on the circuit board, are some small orange
    capacitors that are the final noise filtering for the 12V output.
    The DC/DC output comes out the large grey connector to the
    right of that final section, that sticks farthest to the right
    outside the inverter case right there. You can find this with
    a little groping around behind the inverter [taking the cowl
    off obviously makes it much easier but it's visible/reachable
    just under the big orange hose feeding MG2]; it goes to a thick
    wire which heads back toward the big harness at the firewall.
    If you were to backpower that circuit, i.e. reverse jump with
    all that connected, you would send high currents through the
    final filter, diodes [forward biased, oops!], and transformer.
    They are already high current parts and might be able to sustain
    that peak load until something else blew, you saw a fat spark and
    yanked it, or whatever. But it might not. The most likely result
    is the diodes would short and then the whole thing would present
    a permanent, fairly direct short to ground once 12 volts were
    externally applied even in the *correct* polarity.
    Now, note that the picture also shows an area of small, low-
    power components that visibly blew up. I'm not sure if that
    was from a reverse jump -- galaxee/DH might know since it came
    from them in the first place. Since most of the control
    electronics and low-power stuff in the inverter are powered
    *off* when the car's off, it doesn't really seem likely since
    there's a conduction barrier across the DC/DC main transformer
    that would prevent backpowering any of the rest of the board.
    But who knows, there may be another path and it wouldn't take
    much wrong-way current to fry the small parts.
    One test to do is pull that grey connector behind the inverter
    and isolate the DC/DC from the rest of the 12V system. Give
    the car a known good 12V source, and one might be able to
    temporarily jumper the 100A main fusible link [which it indeed
    is, and that's the correct spelling] with a thin piece of wire
    so that will also act as a fuse if there's still a problem,
    and see if anything will power on. Then, use a test light or
    other protected source to apply +12 to the inverter's DC/DC
    output -- maybe even an ohmmeter would work, to at least
    determine if the DC/DC output is shorted or not. It *is*
    possible to break the system down into individual sections
    and isolate the problem. Now, most of the circuit diagrams
    from the EWD don't actually show where the jump terminal is
    connected and frankly I'm not exactly sure where it sits and
    I'd go out and look were it not for the dark and mosquitoes
    right now. I *think* it terminates the wire that comes up
    from the 12V in the back, and the DC/DC is downstream of the
    main link from there.
    Generally, the 30A encapsulated, soldered-in fuse inside the
    inverter [visible near the center of the board] wouldn't blow
    in this case because that protects the 200V coming in from the
    hybrid battery, not the 12V.
    All of these sub-modules inside the inverter can be replaced.
    Not from Toyota, because they want to sell you a whole new
    inverter and their Prius tech training doesn't really go into
    what's inside it anyways, but from an independent like Steve
    or Lusciousgarage or Art's who actually knows what they're
    doing when romping around in this area. I can't help locate
    one in your immediate area, but if you can manage to find a
    shop that is known to be good with the higher-end electronics
    and find a tech who works there who's really jonesing to dig
    into hybrid technology, please give them this opportunity.
    I hope it works out okay, and I hope the final and very
    specific diagnosis/fix will be posted. Possibly in a new
    thread since nobody's likely to wade all the way through this
    one to find the answer when they go looking two years hence.
    _H*
  3. Patrick Wong
    18,210
    6,526
    Hi Hobbit,
    Thanks for joining the discussion, since you've previously dissected the inverter.
    • What disassembly was required to take the photo?
    • Isn't another layer of the inverter installed above this layer?
    • If yes, how hard would it be to remove and reinstall the top layer?
    • Are the diodes custom or are they off-the-shelf?
    You've introduced another interesting issue with your point that other components besides the diodes appear to have failed. It looks like the most cost-effective solution is to purchase a salvage inverter.
  4. galaxee
    galaxee mostly benevolent
    9,810
    471
    MD
    hobbit, come to think of it i'm pretty sure that one was blown in a reverse jump. we didn't even think about the stuff that looked that screwed. there are very few ways to get your hands on a non-warranty bad inverter, and i can only think of one. toyota takes back all the warranty parts.
  5. patsparks
    10,664
    569
    Adelaide South Australia
    You know if I was a person who couldn't fix the inverter, which is how I describe myself to strangers, I'd go the route I went with the MFD and hunt out a electronics tech to have a go at fixing it. I'd gather as much information as I could find and invite an electronics tech over to have a look then extract the guts of the inverter to try to repair it. Either that or seek out a change-over unit if they exist. To me it's hard to believe that a fuse in the inverter which has blown can't at least be bypassed with another fuse either in the casing or external. Isn't the idea of a fuse to protect the other components? No point in having a fuse if that fuse failing writes off the whole inverter.
    It's my understanding (perhaps mistaken) that most of the component cost is in making them compact so if a single component has failed inside the case is there a reason it cant be bypassed and a similar but perhaps larger component mounted externally?
    Sorry if I'm speaking sh** I just thought maybe I was thinking outside the box and would say what I was thinking. Feel free to say I'm wrong.
  6. Seamus
    Seamus Grumpy old man
    45
    Orchard Park, NY
    I think if I was Ginny I would want all replaced parts returned to me.
  7. hobbit
    4,089
    469
    Bahstahn
    For the rest of the inverter teardown pages, knock the picture
    filename off the above URL. It shows the whole sequence of
    opening it up. Remember that we're talking about the UNDERSIDE
    of the unit here.
    The diodes say on them: TS906 C2 53 with no particular company
    logo on them. Nothing really substantial Googles up for that
    although there's a hint that it might be an equivalent custom part
    number for a 35 amp automotive diode. That vague reference comes
    from one of the offshore data-sheet pirates, so don't take that
    as anything like certain. They're ganged up 3 and 3 on each
    transformer leg for a 100 amp capable output and quite well
    heat-sunk, so that might make sense.
    The clearly smoked parts in the picture are near the control
    input connector for the DC/DC converter, so it's possible the
    reverse jump did manage to back-bias parts right near there.
    I haven't looked to see if there's an always-on power connection
    between the 12V output and that area of the circuitry.
    For those that missed the relevant exchange a couple of years ago,
    I should once again publicly thank galaxee and her DH for making
    this unit available to me and the Prius community. I'm still not
    done studying this thing, in fact! It's been a great demo for
    both indy techs and the public alike, as well as a good teaching
    tool for how Toyota implemented their motor control.
    _H*
  8. Patrick Wong
    18,210
    6,526
    Hi Hobbit,
    I had forgotten to ask you about the above excerpt from your prior post. Is the 30A fuse just for the high voltage side of the DC/DC converter? If so, since the DC/DC output is fused at 100A (at 14V, hence 1,400W output), I am surprised that the input fuse would not be much smaller, say 10A at 200V (for 2,000W input).
  9. Scruge
    Scruge New Member
    97
    TX
    And we know Toyota certainly doesn't want to spend a couple extra bucks to prevent a $4800+ repair.. ;)
    Unfortunately, other causes can be the result of dealer, road side assistance, repair dept. etc. If they are going to set a trap then it better be able to ID the varmint.
    In my opinion its a crap design.
    Its like not putting a fuel filter on the fuel system.. and expecting the customer to buy only gourmet bottled fuel.:(
  10. andyprius
    andyprius Senior Member
    2,212
    188
    Sacramento, California.
    All great posts, to get these posts to Toyota Headquarters may get them moving. PATRICK: If the jumper cables are reversed, then current flow direction is reversed, right? so the current flows from ground thru the Electronics, thru the fusible link to the positive post and back thru the donor car. With NORMAL current direction flow shouldn't the fusible link protect the inverter and any other electronics downstream. Perhaps the fusible link is way overrated. I believe that tepid battery is rated at about 32 Amps, so why is a 100 or 120 Amp protecting an inverter that would blow at a much smaller current draw???? The total sum of this and the thread started by Ginny is that the dealership was presumptive, arrogant, rude and just plain ignorant in the treatment of this customer. The whole situation is totally without reason and Toyota should be made aware. I think you and ICARUS are correct, it's highly possible that the inverter is still good and only the fuses and battery need to be replaced. So in Ginny's case it's worthwhile to have a new battery installed and fuses checked. Since her dealer has not actually done the work...................THEY ARE GUESSING.
  11. Codyroo
    Codyroo Senior Member
    1,826
    515
    Pleasanton, Ca
    Pat, you crack me up......
  12. andyprius
    2,212
    188
    Absolutely! We want the whole world to know the name of that Dealer!
  13. GinnyErns
    GinnyErns No warranty for me
    55
    Idaho, USA
    Tom Scott Motors In Nampa, Idaho
  14. exbauer
    exbauer Active Member
    1,188
    102
    Washington
    i didn't read all the post. but, i would contact another toyota dealer that is close to you. you don't have to take your car where you bought it. just any toyota dealer.
  15. hobbit
    4,089
    469
    Bahstahn
    Okay, I went and checked the topology of all the 12V main power
    because I was curious. I had most of it clarified with scribbles
    on my paper schematics and terminal-location sheets already,
    but a little bit was missing.
    Basically, the chain is like this:
    battery -- 120A -- frame wire -- post -- 100A -- DC/DC
    where the 120A fuse is in the block on top of the battery in
    the back, and the 100A is in the grey/clear-cover block in the
    underhood relay block. The metal area under the post [aka
    the jump terminal] feeds down BOTH sides of the fusible link
    block, but only one of those sides has the 100A fuse part
    which Toyota refers to as the DC/DC fuse. A bunch of other
    subfeeds and stuff come off each side of the link block, so
    some is "downstream" of the 100A link and some isn't. But
    the two big fuses do sit in series between the battery and
    the DC/DC, with the jump post right in between.
    So what is likely to happen when another battery is connected
    backwards between the jump post and ground is this: now the
    car's battery and the new battery are in series, causing a
    24V supply shorted to itself. That should immediately toast
    the 120A fuse in the back. In addition, there's a high-current
    path through the 100A link, through the DC/DC diodes and output
    transformer, to ground, which you'd expect may zap the 100A
    link pretty quickly. Now, what's left? Lots of stuff, because
    the 100A only isolates half the link block. The unfused half
    feeds various other fuses and distribution points, notably a
    bunch of ABS power and the DOME fuse which if you'll remember
    feeds the memory keepalives for most of the ECUs. And if the 120A
    to the car's battery has blown, now the reverse battery has nothing
    to fight it so everything still connected is now seeing a -12V
    feed with plenty of snots to send substantial currents through
    whatever it's headed for. All well within the reflex time of
    the person who just hooked up and hasn't reacted to seeing the
    big fat spark yet.
    *eep*.
    The topology of this layout is just plain weird. It looks like
    the intent was to have a few things more "closely" connected to
    the DC/DC and others electrically nearer the battery, but for
    the overall layout to not really protected itself against this
    sort of thing seems rather deficient. Unless every device that
    receives 12V has its own internal reverse protection, it seems
    like a bunch of stuff is gonna suffer. Perhaps including that
    little control input for the DC/DC, as well as an ECU or two.
    Almost makes me want to try and add *more* fuses, although I
    can tell you no tow-truck monkey is coming anywhere near my car
    with jumper cables without strict supervision in the first place.
    Perhaps it would be better to add several reverse-connected high
    current diodes in strategic places, so the car could crowbar
    itself at multiple points and at least some of the major component
    feeds could have a fighting chance of only seeing -0.6 volts
    instead of -12 if the unthinkable was to ever happen.
    _H*
  16. Patrick Wong
    18,210
    6,526
    Hi Hobbit,
    Thanks for figuring out exactly where the dedicated jump start terminal is situated. Regarding the unthinkable -12VDC, it happened recently. Please see the following string: http://priuschat.com/forums/care-ma...8502-12v-battery-replaced-wrong-polarity.html
    In this case, the ETCS and DOME fuses popped along with the DC/DC fuse. The 120A fuse at the battery did not pop. No permanent harm seems to have happened to the OP's vehicle, so the ETCS and DOME circuits may already have crowbar diodes installed, perhaps within an ECU. My guess is that any ECUs that draw power from other fuses have series diodes at the 12V input terminal to prevent damage from a botched jumpstart.
    In your disassembled inverter photo, you identified other parts besides the diodes that had burnt and obviously failed. I am wondering whether those parts might be related to the voltage sense line that runs to the battery.
  17. hiremichaelreid
    hiremichaelreid New Member
    451
    Ottawa/Aylmer, Canada
    I
    But if the 12v Prius battery is dead enough to need a jump, wouldn't it's internal resistance be high enough that 120 amps could not flow ? At 24 volts that would be anything higher than 0.2 or one fifth of an ohm.
  18. Godiva
    Godiva AmeriKan Citizen
    10,339
    20 pages, no codes and no quote?
    Have it towed to another dealer. Is there another near by?
  19. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    GEE-zus. I just got in, and it's *way* to early for a drink, but in this case I think I will make an exception
  20. GinnyErns
    55
    Idaho, USA
    OK my friends....here is the "estimate"....it isn't even an estimate it is a sheet of paper that says additional repair authorization. First line says Fuse Link Part# 82620-47050
    and $59.82 but they are not charging me I guess because it is not in the total column. Second line says inverter Part#G9200-47120 with 8 hrs of labor total cost $4236.52. Third line is coolant part # 00272--sucz but no cost in total column. Forth line says battery part #2880-21170 for $138.70 and had warranty -battery defective in the total column which then was scratched off and they charged me ...put in total col. under warranty.
    then there is a mysterious fee of $401.25 with no description on it. No where did they give a grand total. and no where did they describe what was really wrong with my car like I asked them to do. Funny that battery is last. So seems to me there is some evidence that the batter failed....and they were going to cover the fuse link and battery under warranty. How they know I have a bad inverter is a mystery because I never authorized anything so they haven't put any new parts in.
    Here are the test results as best as I can pull off the freez frame reports:
    1. Gateway Codes: B1200, 1207, 1271 Icon A......has to do with smart key and ECU
    not sure if this is normal or bad....no indication on the report
    2. SRS Airbog codes: B1650 and 1660.....don't know why they test that or why the sheet for it is in my package.
    3. HV System Malfunction C1310....Icon C........DTC 156..............on the detail sheet it listed IG1 voltage zero, and IG2 voltage 11.93
    4. Open Circuit IG1/IG2 says C1242 .......DTC87 & lists IG1 vol. 0 and IG2 vol. 11.77
    5. POA08 DC/DC converter status circuit says detail code # 3 is 264
    6. P0A09 DC/DC converter status ciucuit low input says detail code #2 591
    Sure sounds suspicious to me that they know the inverter is bad.....and they never addressed the battery as to why the car didn't start in the first place. And don't know why the battery was defective???? and what casued that.
    If you are there Patrick.....any interpretation of the data above would be helpful.
    Thanks
