I bought a 2009 Prius with 230,000 Miles.
Discussion in 'Gen 2 Prius Main Forum' started by Simbaboy, Jan 4, 2017.
  1. jadziasman
    jadziasman Prius owner emeritus
    1,355
    488
    District 6
    Really cheezy looking wheel covers on those snows, Simba. I'd 86 them before heading out
    Simbaboy likes this.
  2. Simbaboy
    Simbaboy Active Member
    134
    112
    Mid-Michigan
    Got the car and like it a lot. It looks very nice and no visible rust. I took the car to Walmart with the Winter tires/wheels that I just bought. They charge me a total of $10 to take off the other set and place these ones. I had asked the tech to let me see the car once it was up in the air--normally they don't but he pretended he needed to show me something. No rust at the bottom of the car either.
  3. William Redoubt
    William Redoubt Senior Member
    1,228
    1,172
    Coronado Island, California
    Maybe he's not interested in picking up fat chicks.
    jadziasman and Simbaboy like this.
  4. jerrymildred
    jerrymildred Senior Member
    11,517
    14,149
    Tampa, FL
    No rust seen while up on the rack is great. Good job on scoring the snow tires, too!
    On the Driver's door lock, the same thing happened with my wife's '07. Check to see if the power lock works at all by using the switch in the arm rest. If that doesn't work, the power lock can be replaced. It's finicky to get the new one in, but I managed it.
    And FWIW, I've seen way worse wheel covers. ;)
  5. Simbaboy
    134
    112
    Mid-Michigan
    Thank you.
    I will see if I can find a youtube video on replacing the switch. Then, I will either hit the Stealership or ebay for a new switch.
    Drive to work for the 1st time in the Prius. 8 Miles each way. 14 deg F ambiet temp. Did nor use heater or defrost the first 5 minutes. MPG was 39. I will take it.
    Receipts from Seller show a tuneup about 100,000 Miles ago. I will get a carfax and decide on further maintenance.
    Thank you all. The wheel covers are ugly but as a baby boomer, I like them too.
    Simba
    jerrymildred likes this.
  6. Mendel Leisk
    41,394
    Forget the tape. Will just gum things up. There's always lights on the dash anyway, for this-n-that.
  7. jerrymildred
    11,517
    14,149
    Tampa, FL
    It's probably not the switch. That would be too easy. :D It's most likely the motor, which is a bit of a pain, as I said. Too bad we're not closer to each other. It's easier to demonstrate than explain.
  8. Simbaboy
    134
    112
    Mid-Michigan
    Here is the Prius I got.
    I filled up my tank today and got it to burp--I am ashamed of myself. Really!
    I hated the fact that the "consumption' graph on the energy display reset itself. I guess I will get a true range with a full tank.
    Simba
    davecook89t likes this.
  9. jerrymildred
    11,517
    14,149
    Tampa, FL
    Sure looks clean!! Have fun.
  10. Moving Right Along
    Moving Right Along Senior Member
    720
    576
    If you click on my (or anyone's) Fuelly signature(s) and scroll down the page, you'll see a list of all the fill-ups for that car, MPG for each fill-up, gas used, and how many miles were driven. That will give you some idea of how other similar cars are doing for comparison. Also, keep in mind there will likely be less miles per tank in the winter, due to the contraction of the fuel bladder.
  11. douglasjre
    douglasjre Senior Member
    2,177
    717
    Null, NL
    It's worth under half what he's asking. Likely a flipper. Check name on title
  12. rjparker
    rjparker Tu Humilde Sirviente
    10,125
    6,287
    Texas Hill Country
    Congratulations on your purchase of the 2009. My Silver 2008 looks almost the same (but has a pin stripe down the sides) and is also still immaculate inside and out. Had Michelins put on when it was new and always run full synthetic oil. Gets about 47 mpg overall but we are down south. I like the radio and interior trim quality a little better than my 2012 v. The v probably rides smoother on the freeway but that's the biggest everyday advantage aside from the v's decent voice commands on the gps and phone interfaces.
  13. Simbaboy
    134
    112
    Mid-Michigan
    I spoke to the Seller if the car recently and he says no 12V battery replacement in the last 5 years and last tune up was at 150K Miles. The car has 230K Miles and runs excellent with no issues (only driver side lock).
    I am thinking of taking the car fo full service to either a Toyota dealership or a Midas Auto Center where I trust the guys.
    What say you? The previous owner has only done air and cabin filters and regular dino oil changes.
    Thank you,
    Simba
  14. Moving Right Along
    720
    576
    Standard maintenance schedule for replacing spark plugs is at 120,000 miles, so it could stand to be done again at this point even though it's been less than that since the last one. There are folks in the forum that suggest draining and filling the transmission fluid every 60,000 miles, so that could stand to be done as well. And replacing the 12v battery every 5 years is another recommendation you'll see often. Basically, preventative maintenance is almost always a good idea so if you want to have a full service done, go for it.
  15. jerrymildred
    11,517
    14,149
    Tampa, FL
    I think the Toyota dealership might be a safer suggestion for repairs since you're not into wrenching. The Prius is mostly pretty easy to work on, but it does require some specific knowledge not common to regular cars plus needing Toyota's software for full diagnostics. Unless the Midas shop you're thinking of is familiar with the Prius or eager to learn about it, I'd be reluctant to have them do more than basic stuff.
    That said, not every Toyota service department is all that great either. I haven't gone back and re-read the whole thread to see if that's already been covered, but maybe there's a way to ask around in your area to see what people think of the nearest dealership's service department.
  16. Simbaboy
    134
    112
    Mid-Michigan
    I think the the Toyota Dealership is a good bet. They are the only game in town and have a decent reputation--Spartan Toyota in Lansing. Michigan.
    I am thinking spark plugs, transmission fluid, transaxel fluid, and new battery. MIDAS might be cheaper but not in the short run. I hope the dealership does not try to oversell their service as that is a major turn off.
    Thank you all.
    Simba
  17. dolj
    dolj Senior Member
    8,437
    4,288
    Wellington, New Zealand
    The consumption graph resets every time the car is turned back on. The miles run resets itself every time you fill the tank. The Average MPG is only reset (on a 2006-2009) when you press the reset button on the screen. (Note also that the miles run resets too).
    Same thing by a different name.
    If the guy from whom you bought it was not a mechanic, have them do a full underbody inspection and inspect the brakes. If it hasn't been done in a long while have them clean the brakes, lube the slide pins (on the disc brakes) and adjust all the brakes. Also have them check the brake fluid and replace if necessary. Should be done anyway if it hasn't been done in the last two years.
    #37 dolj, Jan 13, 2017
  18. Simbaboy
    134
    112
    Mid-Michigan
    LOL--changed my own cabin filter and am on my way to DIY engine overhaul. NOT!
    It looks like it really needed to be done.
    Thanks for all the encouragement I am getting on this forum.
    Simba
    Danny13pruisc3 likes this.
  19. bisco
    51,891
    transmission/transaxle would be one and the same. how about engine coolant, pump and belt, and inverter coolant?
  20. jadziasman
    1,355
    488
    District 6
    You should consider doing these services yourself since all you need are basic hand tools, a funnel, plastic tubing, and ramps or a jack and stands (you can pick these up at Harbor Freight cheap). None of these services is difficult for a novice to handle. YouTube videos abound and show how to do each one of these.
    If you go the other route prepare yourself for Spartan Toyota's bill. I estimate that you will be paying about $600 for parts and labor, probably more with charges for "shop supplies" and tax. If you DIY, it would cost you about $240 total for the battery ($170), transaxle fluid ($40), and the spark plugs ($30).
