I bought a 2009 Prius with 230,000 Miles.
Discussion in 'Gen 2 Prius Main Forum' started by Simbaboy, Jan 4, 2017.
  1. Simbaboy
    Simbaboy Active Member
    134
    112
    Mid-Michigan
    You make some great suggestions.
    Thank you,
    Simba
  2. Simbaboy
    134
    112
    Mid-Michigan
    I just dropped off my car at my Mechanic's house.
    I don't have any issues with the car but it needs a little pampering:
    1. spark plugs and PVC valve. (air filter is good and just got a fully synthetic oil change).
    2. Front and rear brakes.
    3. Radiator and inverter fluid changes.
    4. serpentine belt.
    Is there anything else you experts think I should get done while he is doing above work.
    Thank you all,
    Simba
  3. dolj
    dolj Senior Member
    8,361
    4,260
    Wellington, New Zealand
    I would only clean and inspect. If they were within Toyota's spec as far as pad thickness and rotor thickness/runout, I'd leave them alone. No need to spend money unnecessarily.
    If the coils haven't been replaced in the last 100,000 miles, I'd replace those with OEM coils or the Denso equivalent aftermarket. I would not use cheap junk aftermarkets for the coils (or spark plugs for that matter).
    if it has not been done in the last 1000,000 miles, I'd drain and fill the transaxle with Toyota ATF-WS.
    I presume you've already done an oil and filter change, but if not I'd do that as well.
    #123 dolj, Jan 20, 2023
    Simbaboy likes this.
  4. Simbaboy
    134
    112
    Mid-Michigan
    The car was ready and I picked it up.
    It ran perfect before and it runs perfect now.
    He showed me the rear drum brake pads - -there was hardly any pad thickness left but yet the brakes functioned very well. I only replaced because it was time.
    The only thing left will be some front tires (the rear tires were replaced about 10K Miles ago. Or if I get a decent deal I may replace all 4 and go slightly bigger tires as I got the car lifted late last year.
    Simba
    dolj likes this.
  5. Simbaboy
    134
    112
    Mid-Michigan
    The car just went over 300,000 miles.
    I really like this car - - I am dealing with a P0420 code but will get that solved soon I hope (I have ordered a new O2 sensor and a O2 Sensor 90 degree spacer).
    As it has begun snowing and icy road conditions I have had Walmart place my Winter wheel/tire combo mounted.
    I am not planning to sell this car as its probably not worth much in the market. I just keep the car on a battery tender if not using the car for over a week.
    Really like my 2009 Prius -- fantastic car that I bought and thank you all for your advice over the years.
    Simba
