I broke down 3 miles from home :(
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by iskoos, Jun 13, 2023.
  1. iskoos
    iskoos Active Member
    415
    254
    Orlando, FL
    Hi guys,
    My beloved 2010 Prius III gave up last night. I was about 3 miles from home leaving a parking lot. Started with electric and then the ICE kicked in. Nothing extraordinary at first but a few hundred yards later when I stepped on the gas, I heard some weird noise and lack of power from the gas engine. I let go of the gas and the noise went away. The ICE was still running but kind of idling. I stepped on the gas again and the same happened. This time I pushed it a bit more and started hearing the unmistakable sound of knocking. :(
    It was worse when you push the pedal more. I wanted to see if I could make it home. I found a sweet spot where the knock was barely audible and the car was moving at a very low speed (around 30mph). Drove about a mile in this state using the HV battery as much as possible. Stopped at the light; ICE off and 5 bars on the HV battery. I was about 2 miles away. Light turned green, and I started moving (battery at first). Then the ICE kicked in. Same issue and it felt it was getting worse. Pulled into a gas station a few hundred yards later. Popped the hood to see if anything looking unusual. I checked the coolant level and it seemed okay. I couldn't see anything obvious. I decided to continue. Left the gas station on battery (still around 5 bars). If it was a few years ago, I could have made it home from that point on EV mode slowly. But my HV battery is very week now. I can't even get a mile out of it. Anyways, I am on the main road again on battery power but then I had to kick the ICE as the battery dropped to 3 bars. Right at that moment, the CEL finally lights up on the dash. Engine started knocking as soon as it fired up and knocking continued. I kept driving at below 30 mph this time with the hazard lights on. The car had no power at all, the engine knocking terribly and getting worse, and I only had about a mile left to arrive home. If it was someone, I would probably recommend not driving it anymore but as I thought about the steps involved to get this car towed to my home, I took the risk and all the responsibility and decided to get there. Soon, I got off the main road and with just a little over half a mile left. I was driving in the neighborhood roads; I was driving as efficiently as possible. I had to run a few stop signs. Not proud of it but I couldn't afford to stop. Luckily roads were pretty empty (around 10:00pm) I was moving barely at 20 mph so it was very easy to stop if needed.
    In the last few hundred yards, knocking got so bad and my battery is at 2 bars. So, no way of shutting down the ICE. I arrived with the ICE running the HV battery at 3 bars; I parked the car on the street and shut it off. Popped the hood again and when I leaned down, I got some burning smell. Not very strong but it was there. The engine wasn't hot. The burning smell went away quickly.
    I got my scanner and read the only trouble code P0302 (Cylinder 2 Misfire Detected). It was very obvious that it was a misfire but I was surprised to see only one cylinder. It felt like there was only one firing out of the four. Freeze frame data showed the coolant temp at 181F when the code was set. I know the engine didn't overheat and I don't think this is simply a defective coil or injector (I wish it was). I am thinking I blew the head gasket.
    BTW, it is at 199k miles.
    I am going on a trip in 2 days. I won't have much time to spend on it, but I have to have a plan for my return. Luckily, I have a backup ride and won't be grounded. But I will be missing my 60+ mpg ride a lot. :(
    So, let me know what you guys think.
  2. TinyTim
    TinyTim Active Member
    418
    243
    Seattle
    Did you look under the car to make sure your catalytic converter was still there and not stolen? I would check to make sure that it's still intact.
  3. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,099
    Columbia, SC
    It's not always the head gasket. It's just as likely you have a bad spark plug. Investigate and troubleshoot.
  4. Brucetafer
    Brucetafer Member
    126
    60
    Orlando Florida
    my 2013 with 141k miles sounded like a box of rocks, literally like all the pistons were destroyed.. EVEN Toyota said needed new engine, $12,100 in repairs.. I replaced all 4 coils (2 were bad) spark plugs, cleaned the EGR and its been running like brand new for the last 3 years and 20k miles later.. so don't freak out just yet... easiest way to check and see if there is mechanical damage is to run a compression test on tech stream or a good scan tool..
    don't freak out bra!!! we got your back, enjoy your trip
  5. iskoos
    415
    254
    Orlando, FL
    Well, I heard a cat theft became pretty common but do you really think that someone will steal it in a Home Depot parking lot in 15 minutes?
    It is not impossible for sure but if so, the car would scream but the engine wouldn't miss. It would probably be crazy loud.
  6. iskoos
    415
    254
    Orlando, FL
    I replaced all 4 plugs in 2018. They have about 50k miles on them. If it turns out to be spark plugs, I would be stunned but at the same time very happy.
  7. iskoos
    415
    254
    Orlando, FL
    Thanks man, I will perform some diagnostic checks today/tomorrow for sure. This turning out to be an ignition system related issue would be like a Xmas gift.
    She sounded bad last night. Hoping there wouldn't be a mechanical damage.
  8. ColoradoBoo
    ColoradoBoo Senior Member
    1,356
    984
    Monument, Colorado USA
    Yikes sorry that happened but I agree with the comments that it might not be all that bad...will require some diagnostics....gotta get her over the 200K mark for sure!!! (Break in point!!) :)
  9. Eddie25
    Eddie25 Active Member
    503
    213
    MI
    Where did you get them from? Counterfeit plugs are an issue and 50k is near where they might last, so I wouldn't rule it out by any means.
  10. Brucetafer
    Brucetafer Member
    126
    60
    Orlando Florida
    ill throw a penny into the mall fountain for you! lol..
    iskoos likes this.
  11. iskoos
    415
    254
    Orlando, FL
    I got them from an ebay seller back in 2019; he had a good rating. They came in an OEM packaging and looked original Denso plugs. But that definitely is not a proof that they couldn't have been counterfeit.
    I will pull the Cylinder #2 and check.
    I had a plug went bad on me before on a 4-cylinder Ford. It was missing but was still drivable and wasn't knocking at all. When I pulled the plug, I saw a crack on the ceramic body.
    I had an ignition coil went bad on me on a 6-cylinder BMW and it was missing for sure but still perfectly drivable and wasn't screaming.
    Still hoping for the best but getting ready for the worst.
  12. iskoos
    415
    254
    Orlando, FL
    Well, I was definitely hoping to roll the 200k without a major incident. I was very close. Dang it.
    But I will do my best to bring her back on the road.
    ColoradoBoo likes this.
  13. Eddie25
    503
    213
    MI
    Well you can't give eBay ratings after a certain amount of time so counterfeit spark plugs are the perfect crime. In my opinion that should be the first thing you check. Actually, I would replace them with plugs from a chain store or dealership either way. Trust me, I dealt with this (from eBay as well). I still have the counterfeit ones, they are a perfect match except for the SUPER worn out tip.
  14. ChapmanF
    19,058
  15. Brucetafer
    Brucetafer Member
    126
    60
    Orlando Florida
    I got my 2013 for 300 bucks
  16. ChapmanF
    19,058
    Did that include repairs?
  17. Brucetafer
    Brucetafer Member
    126
    60
    Orlando Florida
    nope I spent over 500 bucks to bring it up to snuff, egr clean, brand new oem coils and plugs, fluids etc.. so all in under 1000
  18. Mendel Leisk
    42,376
    One thing, if you had a horse that came up lame, would you force him to keep going? Your dogged determination to get yourself and the car home without a tow may have made a borderline engine a write-off.
  19. TMR-JWAP
    6,404
    6,099
    Columbia, SC
    Now I'm leaning toward plugs even harder.....
    Brucetafer likes this.
  20. iskoos
    415
    254
    Orlando, FL
    Hi guys, thanks for all the comments. I thought I would at least pull and show you that plug but couldn't do it today. I was very busy all day getting ready to leave town for several weeks. But I will do that tomorrow and post a picture.
    I need to get this car back in garage. It is currently on the street. Today, I was thinking how to do this without running that engine again. I am low on HV battery, it won't let me pick "EV" mode. But then I remembered I discovered a way to not let the ICE come on. When the car is in neutral, it won't start the engine till you put it into the gear no matter what the state of charge is on the HV pack. I think it is because it knows that it won't be able to charge the HV pack in "N" mode. Simply there is no reason to waste fuel. I will do this to get the car into the garage tomorrow. Then pull the #2 plug out.
