I broke my charger that came with the car.My best options for replacement?
Discussion in 'Prime Plug-in Charging' started by Rajeev, Jul 15, 2019.
  1. Rajeev
    Rajeev Junior Member
    moorpark
    I ran over my Charger rendering it completely unusable. I have been in the market for a replacement one. I used to use a standard 110v outlet in my Garage to charge the car before I broke the charger. Is there a safe option in Amazon?I see some for as low as $199 but not sure if I have to get a 220V outlet installed in my Garage before I buy it. Advise?
  2. Rob43
    Rob43 Senior Member
    1,373
    1,048
    VA, BMW Race Car, BMW R1200R, BMW 330Ci, Ford F350
    2013 Prius v wagon
  3. Rajeev
    moorpark
    Hi Rob,
    Are you saying I need both the Leaf charger and the Conversion Pigtails ? Sorry I am not that familiar with the technology. A bit more detail would be really appreciated.
  4. Tha_Ape
    Tha_Ape Active Member
    271
    161
    Washington, DC
    I bought one of those $199 (bougeRV) ones so I could keep my stock one in the car. The one I got plugs into a 240V outlet (NEMA 6-20) and charges at 16A. It also comes with an adapter to plug into a standard outlet (NEMA 5-15). It also comes with a carrying case, but I just leave mine hanging on the wall.
    I use it both ways, for instance, it's on 240V now since I'm about to go grocery shopping soon. When I get home for the night, I'll put it on 120V for overnight charging.
  5. NSXT
    NSXT Active Member
    137
    118
    Toronto, Canada
    2018 Prius Prime
    Someone in amazon stated this: "I just used it as a level 1 charger. This charger a way faster than the one come with the car, about 30-40% faster."
    Is that true?
  6. Rob43
    Rob43 Senior Member
    1,373
    1,048
    2013 Prius v wagon
    Nope, the "Max" amperage is a 12 amp draw, this based on the 80% rule.
    Example: 15 amp circuit (15Ax0.80=12A).
    Your OE Toyota EVSE operates the same way.
    Rob43
