I Can't Get My 2012 Armrest Off!! Help Me!
Discussion in 'Gen 3 Prius Accessories and Modifications' started by spongebob, Jun 10, 2012.
  1. spongebob
    spongebob Not paying 'THE MAN' so much for fuel anymore!
    46
    armrest cover 1.jpg armrest back.jpg Ok, I'm at wits end. I want to cover the lid with a faux leather..... I've read all the posts. I've tried and tried. I just can't get the top part / lid to come off.
    This is what I'm doing. Lifting front about an inch. Pushing back. Nothing. Pushing and wiggling to the point I thought it might break. Anything else? I pressing the release too, but I don't think that does anything, right? I don't see any screws at all. ARGH!
    thanks
    bob
  2. 32kcolors
    32kcolors Senior Member
    5,683
    952
    124
    Redondo Beach, CA
    I take it you're trying to open it? Use more momentum when sliding it backwards to get it to lift up. It's a learning curve, but if you slide it backward too slowly it tends not to work.
    EDIT: I see you have the 2012 so the above doesn't apply. Others with the 2012 can advise you.
  3. k.s.c
    k.s.c Junior Member
    73
    SW Florida
    doesn't open. I've tried.
  4. Kore971
    Kore971 PEDD-CESC
    106
    58
    Downey
    The 2012 armrest only lifts up, there is only one compartment on the top, (not two separate ones), are you trying to remove it from the vehicle?
  5. bielinsk
    bielinsk Gremlin
    505
    115
    Anaheim
    2013 Chevy Volt
    Yea, not sure what you are trying to do with the armrest.
  6. spongebob
    46
    I'm trying to take off the lid and cover it with a faux leather / leather to upgrade the look and make more comfortable. Thanks
  7. bielinsk
    bielinsk Gremlin
    505
    115
    Anaheim
    2013 Chevy Volt
    Ah, so you want to physically remove the armrest. I don't have any info for you on this, but I would be interested to see your results. I wish the armrest came a little bit more forward for me to rest my elbow on (and was a little softer)
  8. Jimbo69ny
    Jimbo69ny Active Member
    712
    107
    Ithaca, NY
    There is a compartment in the lid? I thought it looked like there should be but I didnt see any lever for one. How does it open
  9. Joe Augenbraun
    Joe Augenbraun New Member
    1. There is no compartment in the lid
    2. To remove the piece that gets upholstered, pry it gently on the side. It is a separate piece from the bottom piece that is simply snapped in.
  10. Steve Type-4
    Steve Type-4 Trading HP for MPG
    174
    101
    SoCal
  11. OkCorrell
    OkCorrell Junior Member
    Are there any mods out there that allows us Prius owners to utilize all that wasted space in the 2012 armrests? There is so much room that is not used for anything. It seems pretty ridiculous...
