I can't start my 2008 Prius without inserting the key into the slot, Help!
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by RichardSam, Jan 7, 2015.
  1. RichardSam
    RichardSam Junior Member
    17
    Abuja, Nigeria
    The FOB flashes light and clicks when i press the panic button. My main concern for now is for the car to start with the FOB in my pocket.
  2. usnavystgc
    3,159
    990
    Tucson, AZ
    If the panic button is stuck, it could prevent your car from starting with the fob in your pocket. If its not stuck and your switch is in the right position, the only other faulty area would be the internal proximity sensor in your car.
    koolingit likes this.
  3. Eclipse1701d
    Eclipse1701d Prius Enthusiast
    645
    224
    Nature coast, Florida
    Three Touring
    If that was the case, why would the door unlock with SKS? Do you have the second FOB for the vehicle, or did you purchase it with one? I would tend to believe the fault is with something in the vehicle and not the FOB if the doors unlock without the key... Does anyone know if there are multiple FOB sensors? One for outside to unlock the doors and another sensor in the vehicle? If so, maybe the internal sensor is bad? Could it be as easy as a blown fuse or a disconnected sensor?
  4. JC91006
    16,768
    8,565
    Does your car have a salvage title? Since you bought your car second hand, it may be something the previous owner did.
    I did read somewhere the sensor is in the center console, so if that has been changed/damaged, it would probably be the cause of your problem.
    #24 JC91006, Jan 8, 2015
  5. bisco
    51,937
    perfect, at least you've eliminated one potential cause. what happens when you try the second fob another potential problem thats easily eliminated is the new fob battery. check the voltage, sometimes they're bad out of the box.
  6. miscrms
    miscrms Plug Envious Member
    2,079
    526
    Phoenix, AZ
    It certainly sounds like it could be the internal proximity sensor. The fact that you can get in the car with the smart key seems to say the fob and exterior sensors are working, but its a separate sensor that says the key is inside the car and its ok to start.
    If you have two fobs, you might try leaving one inside the car (in the cup holder say) and then getting out and trying to lock the drivers door with the smart key button (with the second fob in your pocket). If it lets you lock as usual, that may be another indicator that the internal sensor is faulty. If it detects a fob inside the vehicle it should just give you a long warning tone and refuse to lock with the smart key button on the door (though it will still lock with the fob button I believe).
    Pages 4 and 5 on this document give you an idea where the sensors are at twhat their detection ranges should be:
    http://www.toyota.com/t3Portal/document/om/OM47614U/pdf/sec_01-03.pdf
    JC91006 likes this.
  7. JC91006
    16,768
    8,565
    excellent trouble shooting ideas
  8. miscrms
    2,079
    526
    Phoenix, AZ
    Could be, but I've found the LED brightness on the FOB to be a decent indicator of battery health. When mine were low I couldn't see the LED at all for many months before it finally quit working. I didn't even realize there was an LED on the Gen 2 fob until I changed the battery ;)
  9. bisco
    51,937
    especially if you keep it in your pocket all the time.:) i didn't realize the led was an indicator of battery health, thanks!
  10. edthefox5
    edthefox5 Senior Member
    10,096
    4,833
    Clearwater, Florida
    the button under the steering wheel that says KEY must be out.
  11. bisco
    51,937
    ed, if that button is in, will the door open with the key in your pocket?
  12. edthefox5
    10,096
    4,833
    Clearwater, Florida
    Button that says key:
    In sks is off. Fob only opens doors by pressing fob
    Button. Interior light does not come on when u approach and car will only start with fob in hole
    Out is full sks. Car starts with fob in pocket.
  13. RichardSam
    17
    Abuja, Nigeria
    The FOB shows a bright red led and i only turn the SKS button off when some one advised me to do so, but i have since turn it on.
  14. RichardSam
    17
    Abuja, Nigeria
    I dont have a second FOB, but i intend to buy from ebay and programme it for the car. Then i will know if it is the FOB or the car sensor. Thanks.
  15. bisco
    51,937
    all the best!(y)
  16. TonyPSchaefer
    14,816
    2,501
    66
    Far-North Chicagoland
    If you don't have a second fob, then just roll the windows down.
    Roll the windows down, shut the car off, use the armrest button to lock the doors, leave the fob in the car, get out, shut the door.
    If the car immediately unlocks the door, then the internal sensor has detected the fob.
    If the car does not unlock the door, the internal sensor is not functioning. Reach in, get the fob. and use it to unlock the doors.
  17. JC91006
    16,768
    8,565
    The armrest button locks the car regardless if it detects the fob......I've tried it LOL
  18. TonyPSchaefer
    14,816
    2,501
    66
    You are correct but that's not the point in this case. Not at all.
    The point I am trying to get across is that the car should detect the fob and UNLOCK the doors if you accidentally lock the fob in the car.
    Re-read my two "if" statements.
  19. JC91006
    16,768
    8,565
    My point is I've tried this and the car actually locks the fob inside.....it doesn't UNLOCK the doors.
  20. TonyPSchaefer
    14,816
    2,501
    66
    Clearly, we need a third-party to test this. I have accidentally attempted to lock my keys in my car on numerous occasions and the doors ALWAYS unlock. In my case, the keys are in my coat, I take my coat off, leaving it - and the keys - in the car. The doors always unlock.
