I don't know what to do, fix? junk? sell? 2006 Prius
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by azrider, Apr 22, 2016.
  1. azrider
    azrider New Member
    Goodyear Arizona
    The car has around 180,000 miles on it. I say around because the combination meter is off most of the time. Thats not my biggest concern, it is with the brake actuator that needs replaced. Toyota wants $1900 to do it, I cant find any good info on the net about replacing it on my own. So it sits. When I drive it, the brakes are rock hard and dangerous, not to mention a constant warning beeping sound from car.
    Im mechanically inclined, but how do you find Toyota Prius in a salvage yard without calling everyone? Is there a website that finds cars and parts? I don't even think I can sell it to anyone, except for parts, but its really a good car except for a couple things wrong, definitely not scrap worthy. Its even got the replacement batteries in it.
    Any help would be greatly appreciated, I'm just worn out searching for answers on the internet.
  2. S Keith
    S Keith Senior Member
    799
    330
    AZ
    2003 Prius
  3. Patrick Wong
    18,210
    6,517
    Autobeyours.com or eBay for used Prius parts
    Techinfo.toyota.com for repair manual info
    You will need Mini VCI to bleed the brake hydraulic system after replacing the actuator.
    You can probably save $1500 by DIY so don't be afraid to purchase the items and documentation listed above.
  4. ericbecky
    ericbecky Hybrid Battery Hero
    4,452
    3,359
    Madison, Wisconsin
    There are threads here on Priuschat on how to replace the brake actuator.
    Like this one Brake Actuator Replacement | PriusChat
    Use the search box here on Priuschat. (upper right hand corner) Do a search for brake actuator
  5. azrider
    azrider New Member
    Goodyear Arizona
    thanks alot. I'm overwhelmed by all the info, just need to find a step by step with pictures. Anyone know how to find out the exact part #? Call up a dealership?
  6. azrider
    azrider New Member
    Goodyear Arizona
    I tried to pm you but it won't let me since I'm new
  7. tony2ltr
    tony2ltr Member
    165
    67
    North Branford, CT.
    I pmd you
    XT1585 ?
  8. azrider
    azrider New Member
    Goodyear Arizona
    shannon burchardi, one word, at google mail. ( no space between shannon and burchardi that would be great. First thing first, have to find out where that buzzer/chime is located!! Its another one of my searches that i don't have an answer too. Its ringing non-stop because of all this and drives me crazy.how come I can't put in my correct email?
  9. goldfinger
    goldfinger Active Member
    535
    403
    Buffalo
    Next time you're at the dealer ask to see the "show room". They have new cars in there.
  10. exstudent
    exstudent Senior Member
    2,214
    905
    Torrance, CA
    STOP DRIVING THE CAR!
    What else does the car need to do (lack of brakes) and say to you (annoying ringing)?
    Stupidity is getting yourself injured or killed, knowing the condition the car is in.
    Tragedy is when your actions injure or kill innocent people.
    This isn't paint by numbers. The Toyota repair manual comes very close.
    Patrick already told you what to do in Post #3
    Get the factory repair manual. This will be the best $15 you can spend.​
    Looking at your situation objectively, it may be best to hire this out. I'm sure your life is worth more than $1900.
    Mechanical aptitude-questionable.
    Resourcefulness-low.
    You were given the failing brake actuator diagnosis while at the dealership. You could have inquired on the part cost and part number, at that time, or with a phone call anytime later.
    In post #4 above, references your same problem. The person who did the repair tells you how he found the part: "I sourced a used part near me from car-part.com (search for ABS pump)." Yes, multiple part numbers would show-up, but you could call your local Toyota parts department to see which part number is correct.
    Commitment to repair-questionable.
    Post #4 above again: your same problem and the repair procedure. Did you read it? If so, have you ordered miniVCI and a temporary subscription to Toyota TIS or AllDataDIY, as that person did? If no, why not?​
  11. tony2ltr
    tony2ltr Member
    165
    67
    North Branford, CT.
    I'd like to mention something Far overlooked by most mechanics and owners. Brake fluid has a lifespan of about 18 months to 2 years. It is hygroscopic, which means it slowly collects moisture over time. Moisture boils at 212°F, brake fluid depending on dot 3,4,5 has a boiling point roughly between 380°F and 500°F. Additionally, this moisture corrodes the solenoids, slaves, lines, and abs pump, AND the pedal stroke simulator/master cylinder). The darkness of the fluid comes from worn seals and corrosion, but perfectly clear fluid can have wayyyy too much moisture as well. Before you go crazy and start swapping parts, bleed the whole system through with brand new fluid (as soon as you open a bottle of brake fluid it starts to go bad) and as previously mentioned, to do this well, you need a techstream or master tech. Although in a pinch I have been successful not using the tool by removing the abs pump relays and pumping the pedal a few times to discharge the pressure. This BIGGEST problem with doing these brakes in my opinion is recalibrating the linear valve offset. You have to bleed these gently, because if you go too fast without the scantool, it will lock off that portion of the hydraulics, thinking that there has been a loss of pressure. If that happens, you have to reset the abs memory. This is a complicated procedure even for good techs. It is a pain. The use of many (even high end)non factory scan tools can cause the loss of the linear valve calibration.
    After all this, I have found that noise has completely disappeared after a complete fluid service, I've only had a couple come back. Bad fluid causes brake system failures most of the time, I haven't looked lately, buy I don't think there is a service campaign or updated part number for this (can anyone verify?) If there is, the part was faulty, if not, it is most likely wear from polluted fluid. Parts stores sell litmus strips for testing brake fluid moisture. I use them regularly and have found 90% of the cars I work on have unacceptable levels of moisture in the fluid. That hard pedal can be a bad pump though, and I know a lot of them are replaced. Also, if your cap bank is bad, that will also cause the abs pump to have a difficult time keeping up. Preventative maintenance is really important for getting these cars into the +200k range
    XT1585 ? XT1585 ?
