I don't recommend the aftermarket battery from newpriusbatteries
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by scottie1134, Sep 23, 2019.
  1. NortTexSalv04Prius
    NortTexSalv04Prius Active Member
    915
    115
    I have load tested and measure capacity if that qualifies for USED you tell me.
    rayluo likes this.
  2. RobH
    RobH Senior Member
    2,385
    991
    70
    Sunnyvale, California
    I think the most difficult part will be the order number.
    dubit likes this.
  3. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    No if it has never been installed and hasn't been sitting around for 3 years not charging or something, I will take it back. It would be the first return for a reason that's not (a) car got totaled before delivery or (b) decided to sell the car and not install new battery. You pay to ship it back, you get $1400 back refunded to your original purchase media like the card you used. This is a first I am hearing of this and we specifically test capacity multiple times and end to end loading on modules at the factory.
    I'd be curious what your load testing and capacity testing are. Because all of our calibrated equipment shows them to test above 6.5Ah a piece, which is exactly what we design for. The final piece of test equipment to get those numbers is a Keithley battery simulator and tester, purpose built for testing batteries to 6 digits of accuracy.
  4. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    Discharge capacity for the first versions. Over 6.5Ah just as specified. Our newer versions are actually slightly higher capacity and lower internal resistance than the first generation (beta testing) and then again from the Version-2 kits.
  5. donbright
    donbright Active Member
    241
    151
    33
    oklahoma
    If this is the only bad review, then my confidence in my purchase has not waned.
  6. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,091
    Columbia, SC
    @scottie1134
    Do you have any apps that you can use to monitor the battery parameters? It would be interesting to see what the car is giving you for charge and discharge limits for the battery.
    As a 3rd party viewer, and essentially a lifetime auto DIYer, I have to agree that your symptoms do not make sense to be a battery issue. Even a well used battery at 10% capacity will still go hammer down full speed 108 mph. The battery should be providing very little energy once the car is up to speed. The Atkinson cycle engine is very low torque at low rpm and has difficulty getting the car moving from a standstill, but once she's rolling that little engine will get it done. You have something else going on if your car can't maintain speed or drains the battery when at speed.
    It takes air, fuel, ignition and an exhaust path. One of those isn't where it needs to be.
    @2k1Toaster
    I would be happy to be a third party tester if desired.
    #26 TMR-JWAP, Sep 24, 2019
  7. NortTexSalv04Prius
    915
    115
    FYI
    Okay Mr. "Toaster"
    Nov 27 2018-Dec 17 2018 Reference transaction Web ID 122487129 NewPriusBatteries
    Can you please provide a return address
    Thank you [email protected]
    #27 NortTexSalv04Prius, Sep 25, 2019
  8. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    I sent you a PM as I can't find your order so I have asked for more identifying information so I can see what's going on. But you two are the only two people who have ever said you've had negative experiences. The only negative feedback we get is from instructions. Some people say they are the worst instructions in the world. We get more people that say the instructions were crystal clear and recommend our instructions as a general disassembly guide and how it was so easy to just follow step by step. So... I don't know. But the only consistently negative feedback I have received is on the instructions and we always try to answer questions quickly and send pictures which seem to help.
    In scottie1134's case, it is not the battery. This is obvious to anyone who claims to be a Toyota certified tech as he does.
    If NortTexSalv04Prius's battery fails spec testing when new, we will replace it. This was from 9-10 months ago and I have not heard anything about it until this week. You are still in warranty but I am curious how you come to your testing conclusions and want to get to the bottom of it. If you're using lab equipment that's very different than the Dr. Prius app or running the defroster with an egg timer (no joke, had someone try to tell me original battery capacity by this method completely ignoring other car drains).
  9. NortTexSalv04Prius
    915
    115
    My New Prius Batteries has not sat...
    I will pay to ship return.
    Please provide return address
  10. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    Well if it hasn't sat, and hasn't been used, I don't understand what state it is in. I still don't know your order number. Also still don't know what the problem is.
  11. NortTexSalv04Prius
    915
    115
    Are you going to honor your previous posts and statements?
    Mr. Toaster
  12. NortTexSalv04Prius
    915
    115
    Can I return to the following address
    1915 Hunters Point Lane
    Colorado Springs, CO 80919 ?
    YES
    I have provided you Mr. Toaster
    A transaction number, date range transaction, and complaint about quality.
    I am going to return to above address and will await your response.
    #32 NortTexSalv04Prius, Sep 25, 2019
  13. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    If it is not used and has not been sitting then it can be returned. How you've done this for 9 months I don't know and am now skeptical. I figured you had recently ordered it, not a year ago. I still don't know your order number. If you have a problem that is under warranty then you get a warranty replacement. But I still don't know your problem.
    It is very unusual to sit on a product for almost a year without complaint and then try and return it. You can also email me if you'd prefer.
  14. Skibob
    Skibob Senior Member
    2,912
    1,502
    Northern California
    Doesn’t he pretty much say he used them in this post, or am I reading it wrong?
    rayluo and NortTexSalv04Prius like this.
  15. NortTexSalv04Prius
    915
    115
    FYI
    Mr. Toaster
    I am restating the actions I am going to follow
    Return New Prius Batteries Pack cylindrical style to your website contact address of and in Colorado.
    and will follow up on the referenced number dated 11/22/2018 2449215 of which you can not recall or have record of
  16. TMR-JWAP
    6,404
    6,091
    Columbia, SC
    @scottie1134
    You mentioned that you have techstream. Would you post a photo or screen capture of the hybrid battery live screen? It would be interesting to see the information displayed. We could definitely fill in some gaps.
  17. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    You're welcome to ship it there but we have a no refunds policy. Period. So you won't receive any money back.
    I make exceptions when there are problems out of a customer's control like a wrecked vehicle or something else. We have a warranty. If your pack is installed and throw a code, you'd be the first. But we'd start a warranty claim. I am still unsure if your pack is new and unused or used. That dictates warranty or goodwill return (no obligation) or nothing.
    Your transaction ID is what I am guessing that number is. Has absolutely nothing to do with our store. It's made randomly as a payment processing. We don't process payments. Our order system is based on a 3 or 4 digit number. For standard web orders your's will be a number between 100 and 9999 that's unique to you.
    I still have not received an order number. A name. An email address. Or what the problem is.
    rayluo likes this.
  18. dolj
    dolj Senior Member
    8,438
    4,288
    Wellington, New Zealand
    @NortTexSalv04Prius, can I suggest you stop using a public forum to conduct your private business.
    Please use the contact details of newpriusbatteries.com and email them directly with all the information that that business requires in order to help sort your problem.
    I don't know what you hope to achieve by conducting your business in public, except to highlight a shortcoming of business acumen.
    Many thanks.
    Flyboy314, rayluo, M43S7RO and 5 others like this.
  19. RobH
    RobH Senior Member
    2,385
    991
    70
    Maybe that transaction number is from Alibaba. The device is something that sort of looks like the real thing, but isn't. It must be producing under 3Ah to deliver such poor performance.
    Skibob likes this.
  20. Kam2
    Kam2 Junior Member
    33
    new york
    @scottie1134 Try to run injector cleaner, and also take out the air Mass flow sensor and clean it, I think that maybe the issue.
    It could also clogged catalytic converter.
    strawbrad and 2k1Toaster like this.
