I finally got around to replacing the lame factory tire repair kit
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Ken Blake, Jan 7, 2013.
  1. Ken Blake
    Ken Blake Active Member
    351
    180
    Portland, Oregon
    I removed this:
    and replaced it with this:
    Everything fit in the original cubby, inside the bag, on top of the towel.
    The cover sits flush, just as with the stock kit:
    I now have a little more confidence that I can repair a flat, in the event that using the complimentary roadside assistance is impractical or inconvenient.
    iPad ? HD
    Satch, PriusCamper and lensovet like this.
    49,001
    well done!(y)
    Ken Blake and PriusCamper like this.
  3. PriusCamper
    PriusCamper Senior Member
    10,934
    4,430
    Pacific Northwest, USA
    Or you could buy an extra full-size wheel and bolt it to the roof? LOL...
  4. golfguy
    golfguy Junior Member
    Phoenix, Arizona
    I just bought a can of fix a flat to save my bacon ;)
    vvillovv and PriusCamper like this.
  5. PriusCamper
    10,934
    4,430
    Maybe a contest to design the coolest looking 5th wheel mount on the back of a plugin Prius? An opportunity to improve mpg via boat tails? Big tails and wings are the future of high MPGing...
    vvillovv likes this.
  6. delrey
    delrey Member
    280
    SF Bay Area (East Bay)
    Sorry, I can't really tell what you replaced it with, can you tell us in text? Is it the suggested replacement from the PIP FAQ? Or something else?
    Thanks!
  7. Johnny C
    Johnny C Member
    162
    16
    Boston
    The pics are in his "attached files".
  8. nickb
    nickb Junior Member
    45
    Soprano State
    I leave it there and carry a motorcycle air pump (very small and lightweight) and a regular tire repair kit.
  9. lensovet
    2,614
    495
    Burlington, NJ
  10. bielinsk
    bielinsk Gremlin
    505
    115
    Anaheim
    2013 Chevy Volt
  11. ny_rob
    ny_rob Senior Member
    1,968
    813
    L.I.- NY
    You may want to add a small set of needle-nose pliers, small diagonal cutters, a kneeling cloth, and a few pairs of the blue nitrile disposable gloves to your set.
    I've repaired a few tires with the plug kits- they work great, but threading the wick through the needle is a really tight fit (use needle-nose pliers for that job to pull the wick through) and the wicks are extremely sticky and messy (use gloves). Once you've set the plug in the tire- use diagonal cutters to cut it flush with the tire surface so it doesn't get pulled out by road friction.
    vvillovv, Ken Blake and lensovet like this.
  12. Ken Blake
    351
    180
    Portland, Oregon
    VIAIR 85P portable air compressor
    RoadPro 12V battery clip on and cigarette lighter adapter (for connecting straight to the jump start posts)
    Slime 1011 Tubeless Automotive tire sealant (sensor safe)
    Slime 1034-A T handle tire plug kit
    1 pair Mechanix gloves
    1 towel (for kneeling on)
    1 LED headlamp
    I'm going to add a pair of needle nose pliers (with integrated cutter) and some nitrile gloves per NY_Rob's suggestion (Thanks!)
  13. retired4999
    2,652
    625
    Eau Claire, Wi.
    Add just a cutter also, some times you can't cut close enough with a needle nose. :)
    vvillovv and Ken Blake like this.
  14. Ken Blake
    351
    180
    Portland, Oregon
    I chose the VIAIR 85P because I saw it recommended on some 4WD Off-Road forums. Those guys are constantly airing down their tires for more traction off-road, and then they have to reinflate them when they are done 4 wheeling. That means they use portable compressors often, so they need one that is durable, and can handle tires with a much larger volume of air than a 15" Prius tire holds. They probably have more weight resting on those tires while they're being inflated too.
