I find the cause of my problem...finally!
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Prius92, Jul 6, 2025.
  1. Prius92
    Prius92 Active Member
    592
    121
    Iowa
    In all honesty the design of the battery in the 2nd gen is terrible. For starters the foam they used on air sealing areas is very low density and as such degrades in high heat environments and is damaged/torn easily.
    The sheet metal they used is way too thin for the amount of weight involved and warps/bends easily.
    You can't just buy the foam they used, either. The list price of the intake duct is $188, for literally no more than $10 worth of plastic and foam.
    Personally, I think they should have used duct work that had flanges with rubber seals.
  2. ChapmanF
    18,056
    That's the usual story for a lot of weird-shaped, largely-empty dealer auto parts:
    $  9.00 plastic
    $  1.00 foam
    $ 30.00 shipping
    $ 50.00 warehouse space
    $ 98.00 cool logistics system that gets it to any dealer by 10AM tomorrow
    $188.00
    #42 ChapmanF, Jul 14, 2025
  3. Hayslayer
    Hayslayer Active Member
    387
    216
    It's all about mass production and using a system that is 'good enough'. I'm pretty sure Panasonic engineers and Toyota engineers know exactly what the end product needs to be and design the 'item' to meet those needs. I think a Gen 2 Prius HV battery typically lasting 13+ years and 200k+ miles is pretty reasonable. If they got fancy with everything, add 20k to the price of every car.
    As for parts? That's why ebay, this enthusiast forum and many other enthusiast forums exist...............
  4. Prius92
    592
    121
    Iowa
    Since y'all were worried about the foam or backer creeping over a module, I ran my borescope through the other side before assembly.
    Clean as a whistle. I checked every inch and no spray foam came through or pushed the backer farther back over a module.
  5. pasadena_commut
    pasadena_commut Senior Member
    2,584
    765
    Southern California
    Is friction all that is holding that backer foam in place?
  6. Hayslayer
    387
    216
    I think you misunderstand. Not worried at all. It's not my car. I'm just stating what is happening based solely on the photos you provided, while being 1000+ miles away thinking about the 100's of Prius batteries I've built......it's your car, you're entitled to do anything with it that you wish.
  7. Prius92
    592
    121
    Iowa
    I ended up ordering new intake and exhaust ducts because I tried 2 different kinds of foam and neither squished enough to fit.
    Even with the foam half missing, the battery is finally cooling down again!
  8. Brian1954
    Brian1954 Senior Member
    2,137
    828
    South Central PA, USA
    You said that you ordered a new battery cable to replace the cable shown in post #1. Did you install the new cable, and did the new cable help with the problem that the car was having?
    #48 Brian1954, Jul 25, 2025
  9. Prius92
    592
    121
    Iowa
    Yes, I installed the new cable. That wasn't the cause of the overheating, it was due to missing foam air passages that keep air from getting into the electronics section.
    That cable still needed replaced, was completely corroded end to end.
  10. xw20_driver
    xw20_driver Junior Member
    89
    46
    PNW
    Here is the correct part number for reference 74473-47010 Battery Spacer. I ordered it at my local Toyota dealer parts counter for $9.30. I failed to transfer it from my old core when I installed the new HV battery.
    mr_guy_mann, dolj and Brian1954 like this.
