I found the missing 4" (vertical) in the trunk. It is below the battery.
Discussion in 'Prime Main Forum (2017-2022)' started by RonMc5, Oct 11, 2017.
  1. jaqueh
    jaqueh Active Member
    341
    199
    San Francisco
    Incredible photos. That is a serious amount of wasted space.
    I wonder what that foam bit does. Is it strong enough to support the battery from flexing under heavy loads? Why didn’t they add more support? So much open space makes it seem very precarious.
  2. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    It's the size of a regular Prius spare tire and about 2/3 of the thickness of one.
    jaqueh likes this.
  3. john1701a
    john1701a Prius Guru
    12,818
    5,303
    58
    Ever consider the possibility that Toyota may be exploring getting into aftermarket sales?
    Think of what a battery-pack upgrade would involve...
    offib, HPrimeAdvanced and jaqueh like this.
    51,937
  5. Trollbait
    12,539
    Only if you're a bear.
    I suspect it is more to prevent the bottom panel of the pack from flexing and making noise while the car is in motion.
    jaqueh and Prodigyplace like this.
  6. Mendel Leisk
    41,457
    Yeah the pics kinda put this to bed, battery bears (speaking of bears) directly on the main subfloor, bridges over the spare tire recess.
    jaqueh likes this.
  7. HPrimeAdvanced
    HPrimeAdvanced Senior Member
    2,304
    3,519
    Anaheim, CA
    Only if you're an octopus who's a member of the NRA!! Har,har, harumph!!
  8. bisco
    51,937
    you could slide some slender luggage in there, looks a bit like the model 3 trunk.
    GT4Prius and HPrimeAdvanced like this.
  9. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    My thought, immediately.
    So.......how.....do you access this view?
    HPrimeAdvanced likes this.
  10. Lee Jay
    5,850
    4,036
    See post 138.
    You could never get a spare tire in there without removing the battery.
    Mendel Leisk and HPrimeAdvanced like this.
  11. RonMc5
    RonMc5 Member
    89
    73
    Santee
    Thanks, I tried finding a diagram of where the hybrid bits are located, but ended up guessing. As for the jack that is only under one corner of the seat. The rest is all empty space.
    You have to remove the trunk rug, Pop off the trim piece around where the trunk latches and the pieces to the left and right of that, then remove the storage well immediately inside the trunk (one bolt for that I think). Then you can stick a camera down there.I also removed the left and right storage covers and wells. I suggest a trim removal kit.
    I think the foam looking stuff is for sound deadening. It is pretty hard. The battery is supported at all four corners by some sturdy plastic looking bits.
    #151 RonMc5, Oct 20, 2017
    Andyprius1 and HPrimeAdvanced like this.
  12. Andyprius1
    2,327
    859
    Cool CA
    Thank You.
  13. offib
    offib Member
    162
    95
    Dublin
    Four Touring
  14. Andyprius1
    2,327
    859
    Cool CA
    Toyotas Engineers really screwed up on this one. Overall it's a great car. But, no spare?, no room for a spare, very restricted trunk, one small glove box. Sometimes I feel like I'm in some ancient 2 seater open, English sports car. But, 60-200 mpg is hard to beat!
    HPrimeAdvanced, jaqueh and offib like this.
  15. john1701a
    12,818
    5,303
    58
    Toyota plans ahead. Think about reusability or a mid-cycle upgrade.
    Not backing themselves into a corner like another automaker did...
  16. HPrimeAdvanced
    2,304
    3,519
    Anaheim, CA
    Yeah, and pigs fly!!
    offib and bisco like this.
  17. Trollbait
    12,539
    Except this time they didn't.
    Planning ahead would have meant designing the chassis for the plug in with the bigger battery that is harder to find space for, and then the engineers would have had an easier time packing in the components for the hybrid.
    Instead they went backwards. As a result, the Prime loses as much interior space over the Prius Two Eco as the C-max Energi loses over its hybrid sibling, and that chassis wasn't even designed as a hybrid.
  18. GT4Prius
    GT4Prius Active Member
    530
    412
    Cumbria, UK
    Excel
    The 4th Gen and Prime chassis is not designed specifically for hybrid. It's the Toyota TNGA architecture.
    TNGA explained: engineering for the future - Toyota
  19. bhtooefr
    bhtooefr Senior Member
    1,396
    1,489
    Newark, OH, USA
    The floorpan, however, is specifically for the 4th-gen.
  20. john1701a
    12,818
    5,303
    58
    Looking forward, they clearly did plan for bigger. Notice the market expectation for mid-cycle upgrades with minimal price change.
