I got a new toy for my 2012 PiPa today...
Discussion in 'Gen 3 Prius Audio and Electronics' started by Ken Blake, Mar 15, 2013.
  1. Ken Blake
    Ken Blake Active Member
    351
    180
    Portland, Oregon
    The AA battery is for scale. This will hide away nicely in the rear storage compartment, under the floor, while providing more than enough power to drive a 10" sub. Now I just need it to warm up in PA so I can buy a custom sub enclosure for the right side cubby.
  2. ny_rob
    ny_rob Senior Member
    1,968
    813
    L.I.- NY
    Nice!
    Just curious- where/how are you mounting the 10" sub?
    Any photos?
  3. Ken Blake
    351
    180
    Portland, Oregon
    There's a guy in PA who makes a custom cubby enclosure. His board name is MGB4Tim. He has a page showing the fabrication process and finished product:
    Gen 3 Prius right Subwoofer Enclosure
    Unfortunately, his shop is unheated, and so he had to stop making them over the winter. I'm hoping he starts up again soon.
  4. ny_rob
    1,968
    813
    L.I.- NY
    Wow- that's awesome!
    Let us know how it sounds when it's hooked up....
  5. Ken Blake
    351
    180
    Portland, Oregon
    Yeah, it looks like he does real quality work. He was advising another PC member on fabricating their own box, and he mentioned that it "should be strong enough to stand on". That's the kind of product I want in MY car. ;)
    Now I just have to decide what driver to purchase. I'll need a 10" dual voice coil sub, with each coil at 2Ohms in order to take full advantage of the amp.
    Boston Jim likes this.
  6. Bill Norton
    Bill Norton Senior Member
    1,861
    612
    MONW, Ks.
    Yeah MGB4Tim,
    You have people standing in line for your Sub Enclosure !!!
    Hire a local kid to do the lay ups, get a wood burning stove in the shop !!;)
    Does anyone know of another source for this type of sub enclosure?
    Ken Blake likes this.
  7. mrstop
    mrstop PWR Mode
    742
    329
    109
    Cincinnati, OH
    Wish there was a pre-made driver's side sub enclosure. It seems that that would be a better location to maintain access to the battery.
  8. Ken Blake
    351
    180
    Portland, Oregon
    Hopefully you won't ever NEED access to the battery, whereas you are more likely to need access to the flat repair kit on the driver's side. Either way, the sub enclosure Tim makes is held in place by gravity and friction, so it's no big deal to move it out of the way to get to the battery.
  9. Bill Norton
    1,861
    612
    MONW, Ks.
    Yeah, securing it could be an issue.
    I think I read about using the hook side of Velcro works ok.
    If Tim ever gets back into production I'll have to come up with something to keep it in place while I'm pulling close to 1G lateral forces on the cloverleafs... ;)
    I agree about the left hand cubby would be the preferred location.
    Why is there no business out there producing these?
    There are dollars to be made...
  10. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    I made mine with Tim's input... didn't turn out nearly as well but it was my first time glassing. The worst part was taking the mold as I did it in the winter in the attached garage which stunk up the entire house for a couple of days. :(
    I did use a strip of thick Velcro (loop-side) on the underside which holds it securely in place.
    Used a Hertz 10" single coil driver. Mated with a JL HD 900/5 amp, is totally awesome. The biggest issue I had was making it too big (volume-wise). Had to cut it down and add material to cut down the size. It would have been less obtrusive if I got it right the first time.
    Good luck!
