I got a PIP!!
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Jordanhiggins2002, Feb 18, 2019.
  1. Jordanhiggins2002
    94
    39
    Socal
    Didn’t even know there was a hybrid app. I don’t think I need to see all information the battery and car is doing but it was cool to see once.
  2. Jordanhiggins2002
    94
    39
    Socal
    When you come to park your Prius can you just turn it off or do you have to press park first?
  3. jerrymildred
    jerrymildred Senior Member
    11,517
    14,170
    Tampa, FL
    Just turn it off. It'll put itself in park. Although, I often put it in park and then look over my stats before shutting it down.
    Jordanhiggins2002 likes this.
  4. Jordanhiggins2002
    94
    39
    Socal
    I have noticed I do that also. I was curious if you could just power off. That’s pretty cool you can just come to a stop press power over and e brake and your good. I donthe r brake almost subconsciously now.
    jerrymildred likes this.
  5. jerrymildred
    11,517
    14,170
    Tampa, FL
    Lots of people recommend using the emergency brake with all cars, but as for putting it in park, the car does that on its own if you don't do it. Pretty cool, I think. ;)
  6. Jordanhiggins2002
    94
    39
    Socal
    Ya it’s awesome and another great feature if your in a hurry.
    I just got in my car all charged up and why does it read 14.2 miles of ev? Though we only got like 10.2??
  7. CraigCSJ
    CraigCSJ Active Member
    287
    144
    San Bernardino, CA
    Car is guessing how far it will go based on past driving.
  8. Jordanhiggins2002
    94
    39
    Socal
    Seriously? That is amazing...
    So that means I drive pretty conservative right? I try to extend those ev miles as much as possible.
  9. jerrymildred
    11,517
    14,170
    Tampa, FL
    Yup. The best it can do is guess that your next trip will be similar to the previous one. That's not always the case, but the car has no way of knowing your plans. It's like they say in the stock market, past performance is not necessarily an indication of future performance.
    Same is true of the distance to empty indicator. I just got back from a trip to North Carolina. The DTE indicated over 500 miles of range when I left home. Due to rain and 20-35 mph cross winds and driving 70-75 mph instead of city speeds, I got under 400 from miles that tank. Each tank on the trip predicted a lower DTE as it was adjusting to the "new normal."
  10. Jordanhiggins2002
    94
    39
    Socal
    Thank you for the write-up and everyone else for your help. This forum is awesome. I just got back from Vegas from socal for work and I got 58mpg going there and 78mpg coming up. (lots of downhill coming home)
    Yea Right and jerrymildred like this.
  11. Jordanhiggins2002
    94
    39
    Socal
    I cleaned the egr tube, it did not have a much exhaust as I thought it would for 100k. I then took off the right rear tire to inspect the caliper bolts and previous owner/dealer must have lubed them up as they were completely clean and perfect grease like someone just did that maintenance last week. I did not inspect the front tires as I suspect those were done a well.
  12. Jordanhiggins2002
    94
    39
    Socal
    Mine came with the Toyota oem 110v plug. How do I locate a 220v plug for faster charging?
  13. bisco
    52,863
    ebay, amazon, etc.
    there are lots of threads here on what model people chose, cost, features, where they got it and why
  14. Jordanhiggins2002
    94
    39
    Socal
    Why does the connector look like it has a 220v attachment or unattached that is?
  15. jerrymildred
    11,517
    14,170
    Tampa, FL
    Not sure what you mean. Can you post a picture? Mine just has a regular 120V plug on it.
  16. Jordanhiggins2002
    94
    39
    Socal
    It seems like it has an adapter on it or something
  17. jerrymildred
    11,517
    14,170
    Tampa, FL
    Thanks for the picture. That's not an adaptor. It's factory original. Here's mine.
