I got caught out....
Discussion in 'Gen 3 Prius Fuel Economy' started by GrumpyCabbie, Oct 27, 2012.
  1. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    I thought I was switched on regarding fuel economy issues, but even I got caught out the other week.
    Took my car for its annual safety and emission test the other day, which it passed. But noticed that along with the cold weather, my fuel economy was poor and I mean bad; 46 mpg UK (38 mpg US). I couldn't work it out, I was doing the same daily route, my tyres were new and I'd only just checked the pressures not long ago. But when I double checked them this morning they were all at 30 psi! So it looks like the garage that did the safety check took it upon themselves to reduce the pressure from the recommended (I only have them 1 psi over) to 30 psi for some reason only known to themselves!
    So despite being ultra keen on correct psi's, I got caught out.
    Perhaps in future it would be prudent for everyone to ALWAYS check their pressures whenever the car has been worked on.
    sdtundra likes this.
  2. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Yeah, pretty much. I even told the service people not to mess with the pressure and they did anyway.
  3. a priori
    a priori Canonus Curiosus
    3,083
    408
    23
    Chicagoland (West)
    Ditto!
  4. sdtundra
    sdtundra Senior Member
    1,314
    194
    Sacramento, CA
    Yup, told dealer not to adjust the tire pressures, he said alright and wrote it down, got the car back and drove home and once i pulled into the garage noticed they didnt look right, almost flat. 30 front 32 rear....Wth?
  5. GrumpyCabbie
    6,722
    2,121
    45
    North Yorkshire, UK
    I could understand if they reduced them from say, 44psi down to the recommended 36psi, but they seem to just tag all cars as 30 psi all round.
    Perhaps we should reduce their bill by the same percentage? That might attract their attention :whistle:
    Andyprius # 1 and DadofHedgehog like this.
  6. greekchampion04
    95
    27
    happened to me too... took it for an oil change and they bled out my tires and did not reset the oil light. yay.
  7. Mendel Leisk
    42,355
    Same thing happened to me with Honda dealership, just a few years back. At least they were very flexible, quickly raised the pressures when I caught it, before leaving. If there's anything worse than someone undoing your preferences, it's getting a sermon as well...
  8. Jonny Zero
    Jonny Zero Giggidy
    1,388
    352
    Austin, TX
    My guess is that they did reduce it to the recommended spec, while tires were HOT. Once they cool to room temp, you know the rest...
  9. GrumpyCabbie
    6,722
    2,121
    45
    North Yorkshire, UK
    By 6 psi???? I don't buy that.
  10. Jin
    Jin Blizzard PRIUS 2010, Nav+ solar roof
    174
    West Virginia
    Just what is the recommended PSI for our tires? Mine was 30 PSI over the weekend, I decided to get pump it to 40 PSI, I read on the tire it says the max input was 44 PSI so.... I wonder if this is ok.
  11. dhanson865
    dhanson865 Expert and Devil's advocate
    851
    188
    TN, USA
    You are fine at 40 PSI no matter how you fill it.
    If you want to go higher with the PSI then you need to make sure you have an accurate gage and you pay attention to outside tempature and how long since the car was driven before checking the pressure.
    You might want to keep the rear tires 2-3 PSI lower than the front though instead of doing 40 all the way around consider 42 front/40 rear or 40 front/38 rear.
    Jin likes this.
  12. subjective
    subjective Member
    203
    30
  13. subjective
    subjective Member
    203
    30
    Sorry, don't know what caused the anomaly, It must have been Dracula intervening. Sorry
  14. Jin
    174
    West Virginia
    What is the reason for lower pressure on the rear tires? Better traction control?
    I also realized mine was always at 30 PSI, but I didn't do anything til I read up on increase MPG by increase the tire pressures.
  15. GrumpyCabbie
    6,722
    2,121
    45
    North Yorkshire, UK
    Not sure about the US spec cars but the UK versions have a sticker on the inside of the drivers door with the recommended pressures. Maybe being a Japanese built car this sticker might be inside the passenger area on US cars?
    It's only been a few days since I noticed the reduced pressures and already my trip average mpg is starting to creep back up.
  16. Codyroo
    Codyroo Senior Member
    1,826
    515
    Pleasanton, Ca
    Balance of the car. I believe the front tires are inflated by 2 PSI more than the rears to compensate for the extra front weight of the car.
    You'll get more even wear and much better MPG's with your tires near the max PSI than at 30 PSI.
  17. Codyroo
    1,826
    515
    Pleasanton, Ca
    That would be quite a temperature difference to get those numbers.
    Ideal gas law = PV = nRT where P = Pressure and T = Temperature in Kelvin (Celcius + 273).
    P1 = T1
    P2 =T2
    For this exercise (and my errors will be pointed out and corrected) lets assume that V, n, and R are constant and equal 1. Let's assume they did set to 36 PSI @ unknown temp and you found it at 30 PSI at 59F (15C = 288Kelvin)
    Thus, For a 6 PSI change
    36/30 = x/288 Kelvin. 36 PSI(288 Kelvin)/30 PSI= x = 345.6 Kelvin = 67.6C (154F).
    That would take a 100 degree farenheit change. I don't think the tires get that warm......
  18. Britprius
    Britprius Senior Member
    5,194
    1,924
    Herefordshire England
    In the Uk it is illegal to have tyre pressures that are more or less than 10% of the manufacturers recommended pressures.
  19. ItsNotAboutTheMoney
    ItsNotAboutTheMoney EditProfOptInfoCustomUser Title
    2,287
    460
    Maine
    I do. There's a signifciant change. Recommended is 34, so it only takes tire temperature that'd raise it by 4 for them to mess it up. I got caught out the same way when I had my new tires installed.
    They might not have been off by 4: part of the effect could have been additional autumn temperature drop.
  20. Codyroo
    1,826
    515
    Pleasanton, Ca
    Interesting, I didn't know that. How/when do they confirm this?
    But even still, it doesn't impact Jin (who is in Maryland).
